TT Base ram to 8 MB
Moderators: lp, moondog/.tSCc., Moderator Team
- Atariator
TT Base ram to 8 MB
Hi all,
Created a PCB that allows the replacement of the onboard 16 chips with a PCB that plugs in on the original sockets, and accepts two 4MB 72 pin SIMMs
Only change on the motherboard that is needed is the soldering of a wire to pin 34 of the ST-RAM MMU. Making it super easy to go back to stock if needed.
The fotos are of the 2nd version of the PCB (if you look closely on the foto you can see trace-cuts for instance), the final version is coming next week.
And as default I always have to order more than I need, so I have 8 PCB left over, anyone interested?
(Be aware that this PCB may not fit into all TTs since there are different version of the mainboard, and will also interfere with the Original Harddisk if it still fitted)
PS: I first need to assemble/test the new PCB, so I can add some of the assembly instruction to this post.
(Including the links to the materials)
PS: The tally so far:
czietz: 1
derkom: 2
Gaiyan: 1
DoG: 1
czietz: 1
derkom: 2
Gaiyan: 1
DoG: 1
- Atari Super Hero
Re: TT Base ram to 8 MB
That's interesting !
The only problem is the soldering (most of all, you have to disassemble the VME case).
Is it possible to use a Minigrabber instead? Or does the signal of pin 34 appear elsewhere on the motherbaord? (into the ST RAM connectors?)
So, if I understand well, you have to unplug every RAM chip from the 2MB of the motherboard and plug your PCB instead, is it right?
Guillaume.
Guillaume.
- 10 GOTO 10
nice project.
few years ago Simbo modified original 4MB ST-RAM card to 8MB
ATW800/2 / V4sa / Lynx I / Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm / SM124 / SC1435
http://260ste.atari.org
- Captain Atari
Hi Xevious. I'm always interested in TT upgrades and would be happy to help you unload two of the extra boards.
- Hardware Guru
- Atariator
Moulinaie wrote:Hi,
Guillaume.
So yes, remove all the original chips, and insert this board in place. And no, this pin is not present elsewhere on the board, at least not in the schematics and the board I've seen so far.
BTW: Removing the VME case is very simple. Especially when the TT is already stripped down
- Captain Atari
I'm not sure I would say "Making it super easy to go back to stock if needed" in that case.Xevious wrote: So yes, remove all the original chips, and insert this board in place.
- Atariator
Cyprian wrote:nice project.
Yes, saw that
2 x 4MB simms can be had for ~10 Euro on Ebay. I've purchased both EDO and FPM, and both seem to work.......
- Atariator
derkom wrote:I'm not sure I would say "Making it super easy to go back to stock if needed" in that case.Xevious wrote: So yes, remove all the original chips, and insert this board in place.
Ok, in my case the chips are in sockets, so I only need to remove those 16 chips and insert my board. And the reverse is done when going back to stock.
- Hardware Guru
... newer Atari TT boards has the 16 pieces 256kBx4 chips solder in with no sockets. Solder a wire at the TT SMD MCU is not so easy.
- Atari God
Two questions:
1. Is that board for the DIL or SMD style ST-RAM-board?
2. Why that wire? The upgrade by Simbo and the one from Lynxan do not need that extra wire.
I am interested in up to three of these boards, dependimg on question 1.
1040STFM in PC-Tower (PAK68/2, OvrScn, 4 MB, 1GB SCSI, CD-ROM...) * 2x Falcon 030 * Falcon 060 * 3x TT030 * many 260 /520/1040ST(F)(M)(+) * 520/1040STE * many Mega ST * 2x Mega STE * Stacy * STBook * 3x SLM605 * 3x SLM804 * SMM804 * SH 204/205 * Megafile 30/44/60 * SF314 * SF354 * 5x Pofo * PC2 * PC3 * PC4M * ABC286 * ...
- Hardware Guru
Onboard ST Ram is always 256kx4 DIL 20pin
The PCB Layout fits with PGA Mainboards. SMD Board have solder in Dram without sockets ...
- Atariator
frank.lukas wrote:Onboard ST Ram is always 256kx4 DIL 20pin
Yup this is one of the boards where this solution will not fit, as I mentioned in the OP.
- Atariator
1-> DIL socketed chips.1st1 wrote:Two questions:
2-> To access the MAD9 line that effectively quadruples the memory (Extra RAS/CAS Address line combination)
- Captain Atari
I am interested in one board.
- Atari God
I have to check. I have three TT, one is DIL, the other is SMD, the 3rd I don't know, just got it recently and did not open it yet. But I still don't understand that cable, Simbo and Lynxman's modification work without such a cable.
Is it still possible to place the harddisk between the PS/2 SIMMs?
And what would one of these boards cost?
- Hardware Guru
Simbo and Lynxman work and Upgrade are for the optional 2MB DIL ST Ram Board. So you have in total 10MB ST Ram, what is the max ...
This Thread is for the ST Ram on the Mainboard ...
- Atariator
Answer to you first question:1st1 wrote:I have to check. I have three TT, one is DIL, the other is SMD, the 3rd I don't know, just got it recently and did not open it yet. But I still don't understand that cable, Simbo and Lynxman's modification work without such a cable.
So the MMU used on the motherboard is AFAIK the same as used on the RAM daughter boards. On the motherboard ATARI physically didn't connect the line that is needed to adress the full space (MAD9), hence the need for that extra line.frank.lukas wrote:Simbo and Lynxman work and Upgrade are for the optional 2MB DIL ST Ram Board.
Regarding the space for the hardisk: no (EDIT: Thinking about this, maybe if using those angled SIMM socket. Creating a '\_/' shape where the HDD can sit in between?)
Cost: 10 Euro.
- Atariator
Would be interesting to see if a fully modded daughterboard with a mod like this can enable maximum of 16MB?frank.lukas wrote:....., what is the max ...
- Hardware Guru
16MB ST Ram is not possible. 10MB is max because of the VME Bus Address Space.
- Atari God
The price is fair, but if I can't install the harddisk with this extension, then no, thanks.
- Atariator
Np, less beer for me1st1 wrote:The price is fair, but if I can't install the harddisk with this extension, then no, thanks.
- Hardware Guru
May be use 72 PIN RIGHT ANGLE SIMM SOCKETS. I do not know of Left Angle Sockets ?
- Atariator
Update: Board is in production.Xevious wrote:Hi all,
Created a PCB that.....
- Atari Super Hero
Any news?
James
James
TT030 - Light/Storm/Thun 256mb TT ram 10mb ST ram card(Lynxman) Nova(frank lukas) Mach32 2mb. 250gb SSD
MegaSTE - monSTer (alanH) RGB2HDMI(pixelk) 68kHC cpu - IDE CF 8gb internal.
MegaST - ICD ADspeed & Compatibility Plus
Phoenix ST - Exxos remake board - Lightning Storm Cloudy.
1088XEL, 800 incognito
Bikerbob's BBS on FoReM ST 2.51c bbsclubhouse.ddns.net:1040
