I pronounce it 'trak'. I've heard some t-trak's..
Just wait for TTRAK Turbo edition
I actually didn't know; really?distantminds wrote: ↑Fri Mar 26, 2021 9:38 pm cool that you had a play - i'm a fan of your work as you know![]()
Yes, I mean that one. The issue with the big yellow crosshair is that there's no way to see where in the square you are, because you don't see your precise cursor position. So as you're drawing, you only know that you got too close to the border of the wrong cell once you've drawn it in. However, this is mostly an issue when drawing horizontal lines, so thanks for the ALT modifier! I hadn't found out about that yet.distantminds wrote: ↑Fri Mar 26, 2021 9:38 pm i'm not really sure I understand some of your feedback - which envelope editor do you not know where your cursor is? if you're talking about the main volume/timer/noise grid.. well, there's a big yellow crosshair showing you where your cursor is! If you want to restrict vertical movement so you can draw a straight line, then hold down ALT as you draw.
This is exactly what I mean. (but not for the main volume sequence editordistantminds wrote: ↑Sun Mar 28, 2021 10:06 pm I did some work recently to stop the user selecting other buttons when rolling over from the main volume sequence editor..
Thanks!wietze wrote: ↑Mon Mar 29, 2021 9:55 pm @607: https://www.youtube.com/watch?v=ldGRJTG ... nel=evldhs
I followed this and get the following if I play octave 1. https://drive.google.com/file/d/1mhA926 ... sp=sharing I set the tick speed to C8 before demonstrating.distantminds wrote: ↑Wed Jul 22, 2020 5:29 pm To start with, set the first 4 steps of the timer waveform to 1,0,1,0. The 1 represent an octave shift. The first and third values are shifts *up*, and the 2nd and 4th are shifts *down*
I wanted a legato arpeggio with an (also legato) echo (I don't mean the arpeggio effect here, just regular arpeggiated chords). Needed all 3 YM channels for that instead of just 2.distantminds wrote: ↑Wed Mar 31, 2021 3:24 pm hmmmm.....
very interesting! I'm curious to know your application![]()
are you using Linkto defined at an instrument level or ad-hoc using LXX? Either way, I can't repro the above.. it just carries on until it's interrupted by the next note. I just remembered the bug you found previously btw where the link-to repeats when using LXX. Feel free to send an example of the issue to ttrakinfo@gmail.com
To stop playback? Space! To stop an instrument sounding when you're auditioning notes? Use the note-off key - Enter on the numeric pad, or alternatively the hash key. You can use the same key in record for a note-off.607 wrote: What is the key for Stop? I don't think I ever managed to find out, but having to press Enter twice to get a note to stop is really annoying, as it changes the cursor location and starts playing back the pattern.
Stuff happens607 wrote: TTRACK just crashed for me.I'm not sure exactly what I was doing. I was testing the link-to feature and also using the frequency modulation, and pressed escape to return from the instrument editor to the song editor, and then both got drawn over top of each other and it wouldn't accept user input anymore (but I kept hearing the instrument playing back).
I'd be so stoked for you to make a track in TTRAK so if I can help/fix something, I will..607 wrote: I'm not giving up yet!I would like some clarification on the link to feature though, as it could be useful for what I'm working on.
'fraid so!607 wrote: TTRACK has just one effect per channel at a time, right? This is very normal, but MaxYMiser has spoiled me.![]()
Excellent work with the script mate. I've nearly finished .WAV import now also..607 wrote: Edit: Forgot to say: the script worked for me! I wasn't sure what frequency to export the samples at, but 19200 played back at the third highest note sounded pretty close. It wasn't exactly the same frequency, though, so if you've done the maths, maybe you could share the solution to playing samples back at the intended frequency.![]()
Thanks, Enter on the keypad works! Saves me a headache.distantminds wrote: ↑Sat Jun 26, 2021 7:34 pm To stop playback? Space! To stop an instrument sounding when you're auditioning notes? Use the note-off key - Enter on the numeric pad, or alternatively the hash key. You can use the same key in record for a note-off.
Ah, I found the source for my confusion, I think. The Ixx command isn't persistent, it is only in effect for as long as that step is active. I guess that makes sense. I used a workaround for my issue, which prompted a feature request down below!distantminds wrote: ↑Sat Jun 26, 2021 7:34 pm are you using Linkto defined at an instrument level or ad-hoc using LXX? Either way, I can't repro the above.. it just carries on until it's interrupted by the next note. I just remembered the bug you found previously btw where the link-to repeats when using LXX. Feel free to send an example of the issue to ttrakinfo@gmail.com
I guess I should save more often.distantminds wrote: ↑Sat Jun 26, 2021 7:34 pm Stuff happensThe latest version is very stable, but it's possible to crash due to CPU overload. I talked about this on the website - do you restrict the range of certain timer effects to reduce the risk of crash, or do you let it all hang out? I let it all hang out
Wild freq mod with an expensive timer effect could for sure crash the editor.
Okay, thanks! Do you reckon the high frequency causes it to crash?distantminds wrote: ↑Sat Jun 26, 2021 7:34 pm 19200 is spectacularly expensive for an STFM digidrum! Madmax era digis are more like 4000hz iirc. If you want to play a sound back at exactly (or close to) the right pitch, you'll have to match the pitch of one of the notes. Maybe try C7 (4186hz)..
I took a quick look at the tracker code implementation of link-to and yeah i think there's some logical decisions in there that are making life difficult for you. If you're specifically looking to use it as a retrigger (in the case of your snare drum example) then you could enable it at the instrument level, and then use the instrument speed code IXX to set a really slow speed so it doesn't repeat..
607 wrote: I guess I should save more often.I did just find the 'CPU safe' option, I guess I could use this if I want to limit the crashes?
Yeah very likely it's CPU utilisation causing crashes. There is some work in the code to slowly turn off certain things as the CPU use ramps up (you're seeing that with the cursor and mouse pointer disappearing!), the CPU Safe idea went further and limited the highest possible timer frequencies of each channel, but for now i've turned this off. Needs more thought!607 wrote: Okay, thanks! Do you reckon the high frequency causes it to crash?
In any case the short test I just made causes some strange behaviour in the editor (look at the cursor in particular). I'll send it to you, have a look.I guess that this is because of the high CPU load? I love that the screen flashes at the end.
Mate, i noticed this myself yesterday whilst working on WAV import! I was so confused as I'm sure it used to work 'properly' before607 wrote: I came across an apparent bug, I suppose you probably know about it already, but I don't know of a known bugs list so I'm just noting it in case you don't.It seems that when you load a digidrum, it gets saved to the sample number of the instrument number, regardless of what is specified at 'use'. So if I want instrument 6 to use sample 2 but haven't loaded in sample 2 yet, I have to do that from instrument 2, even if I have set sample 2 at instrument 6.
There's a COPY INST and PASTE INST feature in the instrument editor.. Is that what you mean?607 wrote: I'd like to be able to copy one instrument to another.
Ok interesting! i'll add it to the backlog. Should be easy to include.607 wrote: Second, I'd like to be able to turn off the preview play that happens when editing. I think it's quite useful that you hear what notes you're entering when working on melodies, and it's very useful that when you tweak an effect you hear the result right away. However, when I was working on these rapidly repeating snare drums, I really didn't fancy hearing them any time I changed a number.I just turned down the volume now, but that meant that I had to turn it up when doing actual playback, and turn it down when dialing in more. It would be a quality of life feature to have a toggle to completely disable playback in edit mode.
