new game (need loop fix)
All discussions about the Atari 8bit range of machines.
Re: new game (need loop fix)
Post by wongck »
Frank B wrote: I don't know basic. You'd need a function which returns a value and a calling routine above it with a switch statement or a load of ifs.
I do not know MSX basic.
From what i remember for AppleSoft Basic, there are GOSUB tbat are similar to function.
Also the scope of a variable in Basic is very simple, there is only one... that's global scope. So your return value can be read everywhere.
My guess at my Basic game now as I forgotten it, was that a huge loop using GOTO wrapping INPUT and bunch of IF then GOSUB statements.
Well, wonder if an infant can do of that, what can I say.....
MrPixel
Post by MrPixel »
sorry for that comment. , can you post an example?
Atari: King
Sega: Queen
Nintendo: squeaky clean
Phillips CDI: Agony beam :lol:
Post by wongck »
I guess something like this, just expand on it. Not even sure if it runs.
I am sure there are better example than this....
10 print "Do something >"
20 input A$
30 if A$ = "W" then gosub 100
40 if A$ = "A" then gosub 200
50 if A$ = "S" then gosub 300
60 if A$ = "Z" then gosub 400
70 if A$ = "Q" then print "Bye": END
80 goto 10
100 print "you walked north" : return
200 print "you walked east" : return
300 print "you walked west" : return
400 print "you walked south" : return
MrPixel
Post by MrPixel »
return without gosub in 100
Atari: King
Sega: Queen
MrPixel
Post by MrPixel »
didn't work
Atari: King
Sega: Queen
MrPixel
Post by MrPixel »
MrPixel wrote:it workedk
Atari: King
Sega: Queen
FedePede04
Post by FedePede04 »
did you use gosub or did you use goto?
gosub is like a BSR, JSR, CALL in asm (depend on processor) where you need a return
where goto is like Bra,jmp in Asm
--- Gosub ---
10 gosub 100
20 print'now its my turn'
30 end
100 print ' me first'
110 return
--- Goto ---
10 goto 100
30 end
110 goto 20
FedePede04
btw here is a basic manual for the msx
https://books.google.dk/books?id=Qo-GDA ... sx&f=false
Post by wongck »
Not surprised if it does not work as the BASIC flavour is AppleSoft. :D
Also it is not tested and was off the top of my head.
FedePede04
wongck wrote:Not surprised if it does not work as the BASIC flavour is AppleSoft. :D
hi wongck
the error he is getting sound like he is hitting the a return with out a gosub first
indicate that he did not use gosub or he is missing the loop line in line 80.
as i recall it, the input$ is not good using on the MSX he should be using inkey$ instead of, but else you code is looking good :D
Post by wongck »
Well, Simon, on the other thread, pointed him to some very good games writing resource and that's all in BASIC.
Should not really need this any more, as there are plenty of examples there.
And coming back to say "don't work" while not showing the code or where the error is, really does not help himself.
One can only make a guess at what the problem was and say something, but may be barking at the wrong tree.
really that code snippet of mine is so simple I cannot see where it can go wrong, other than mistyping typo.
FedePede04
you are right wongck
its was also the reason why i wrote and support you code, it is very simple and if you can't make that work, then you have a very long way to go before you can do a game.
it is also the reason that i post the link for the MSX manual, it is filled with code examples so he can learn how to code on the MSX.
one need to start at a place, but to start with coding a game, is maybe setting the bar too high.
edit:
Link to MSX books
http://msx.hansotten.com/books/
Post by joska »
MrPixel wrote:didn't work
What you need to do at this stage is what we did back in the 80's - sit down in front of the computer with a crappy manual and lots of spare time, and start playing with it. Too many of today's programmers "learn" programming by copy/paste from forums and tutorials without making the effort to really understand what their copied code does.
MrPixel
Post by MrPixel »
i understand. i will lean a bit more. thank you all for your help
Atari: King
Sega: Queen
FedePede04
MrPixel wrote:i understand. i will lean a bit more. thank you all for your help
good luck with it, the MSX basic is actual quite good, and i actual consider buying one my self, to learn my son how to code(He keep asking me :lol: )
and use the MSX forum instead of, they probably know alot more, about the MSX that we do here, and have fun while you are learning, these are the most important advice i can give you.
MrPixel
Post by MrPixel »
i appreciate it. can someone look at the Worst of sega cd thread?
Atari: King
Sega: Queen
Return to “The Atari 8bit corner”
