I'm calling Willy out! SuperVidel info!
leech
Re: I'm calling Willy out! SuperVidel info!
Post by leech »
Damn. Yeah I also would think the lack of Analog signals would be a show stopper as well? I think even with HDMI you can get analog converters, I don't think I have seen any DisplayPort to VGA cables. DVI is the most universal in that regard and has some of the highest bandwidth potential. Too bad there is no such thing as a mini DVI port.
Edit: apperently there IS a mini-dvi port. https://en.m.wikipedia.org/wiki/Mini-DVI
beel1
Post by beel1 »
There are also plenty of micro-HDMI to DVI cable adapters: I don't know the legal aspect but maybe it is possible to use a HDMI plug to output only DVI data (no sound, no CEC...)?
Post by joska »
Put a Mini DVI connector on the SV. The user can then decide for himself how to bring this to the outside
There are many suitable adapters that can be used - mini DVI to VGA, HDMI, DVI, VGA+DVI...
stormy
Post by stormy »
Interesting how peoples ideas of 'molesting' their case is different. For me anything on the back side is fair game, anything that adds to the Falcons usability without messing up the front view. Because lets face it, we use these machines for fun and nostalgia as well, plus some productivity.
The _only_ time I would want to keep a completely unmolested, factory falcon, would be in the case of a factory falcon - with _no_ modern upgrades, just what was available at the time. But where is the fun in that? Okay for a museum perhaps. Or maybe if you want to sell it some day.
For me I want as much modern usability as possible. If that means more ports on the back, then yes. If it means I can use and enjoy my Falcon more, then yes. If I wanted a Museum.. then that is another story.
leech
Post by leech »
I always like to have an original (for full compatibility) and a molested one.
Unfortunately who can afford two Falcons these days? It's hard enough for me to find one with a US keyboard that is under a grand... with all the keys!
alienkidmj12
Post by alienkidmj12 »
this is cool, i defo want on this list :)
willy
Post by willy »
Hi folks.
So, @Silly Venture I was talking to many Falcon Users ... and they confirmed my idea.
It's very simple.
Small box mounted on the backside of Falcon, to the Video port. It will be fixed with screws to the Video port, and will have some support underneath.
A flat cable will be inserted to the box, using the native gap between video port and the case. "The Box" will be equipped with DVI-I port (both Analog & digital signals), Ethernet port, maybe VGA (Analog signals in DVI will be duplicated) and some buttons. Inside "The Box" will be also integrated converter/switcher for Falcon 030 to VGA/RGB signals.
As an result you will get only ONE cable to connect the monitor, in a cost of small box attached to the Backside of your Falcon. I'd say, the box should not be deeper than 1,5"(4cm), its less than VGA adapter :)
BUT ... there is also a challenge ...
Buy Female DB19 ...
I send inquiry to many places, and they do not have any connectors, or are not responding ...grrr....
I got confirmed that IEC has some ... but They are not responding to my Inquiry.
So, if anyone knows where I can buy DB19 female Connectors, please let me know.
The absolute requirement is - minimum 250 pcs. to buy.
Please PM me if you have any info.
It makes no sense to start development until i get these connectors in my hands.
Best regards Willy.
Rustynutt
Post by Rustynutt »
PM sent fwit :shrug:
Post by joska »
Sounds like a very good idea :) Can't help you with the connectors I'm afraid. Maybe you can solder pins directly to the PCB instead?
Rustynutt
Post by Rustynutt »
christos wrote:
jvas wrote:Can't the DVI be replaced by HDMI? Lot smaller.
I think hdmi needs a licence to be purchased. You cant just add it.
HDMI cards out of China bypass HDCP.
Could always go there for production :roll:
leech
Post by leech »
Wow, that sounds actually really awesome. Kind of makes me wish I'd waited to get a SuperVidel, just had no idea when they'd be released. Of course now I have a rack mounted case I have to fit the Falcon in, but that's waiting until after I move...
Ektus
Post by Ektus »
willy wrote: BUT ... there is also a challenge ...
Buy Female DB19 ...
Have you checked out http://www.iec-usa.com/cgi-bin/iec/DB19FS already?
You could ask at http://fctgroup.com/de/produkte-loesung ... ndard.html if they happen to have the 19-pin variant also.
Several other internet shops I've found searching for an hour or so:
http://www.itc-direct.com/en/db-19-f-solder.html
http://electronic-studio.com/index.php?a=13476
http://www.riedl-electronic.at/onlinesh ... e2513e871a
https://smorenberg.com/d-sub-connectore ... emale.html
Regards
Ektus.
viking272
Post by viking272 »
@Willy
This is an interesting article on sourcing and producing DB19 and even mentions Atari:
https://www.bigmessowires.com/2016/06/0 ... connector/
Any luck on getting some?
AdamK
Post by AdamK »
@viking these are males connectiors, Willy needs female ones.
willy
Post by willy »
@All
Some good news.
I got confirmation from 2 (two) places, that they HAVE some usable connectors. I hope i get them soon :)
I'am also in touch with manufacturer in China, but it seems that is too expensive for this relative small project.
br.
W.
Trixster
Post by Trixster »
Fantastic! Preorder thread??! :)
Atari Falcon CT60e | Atari 2600 | Atari Jaguar | A1200 80mhz B1260 Indi AGA2 Ide-fix Express | SNES
A4000/060 CS Mk2 Indi AGA Voodoo3 G3 950Mhz PPC Deneb | A3000/060 WarpEngine CV64 Deneb 486SXLC2 | PS1
Acorn A3020 | A3000 | A420/1 | BBC B | Atom | Master Turbo | A500 | C64 | 3DO | Saturn | PS2 | CPC6128 | X68000
willy
Post by willy »
Sorry. No preorder YET.
It is going so f*** slow ..., and this time its not my fault ,)
One of the companies beat word record with response time: 41 days ... and that was by email. I'm sure that pigeon would be faster.
Post by wongck »
willy wrote: One of the companies beat word record with response time: 41 days ... and that was by email. I'm sure that pigeon would be faster.
no, Virgin Atlantic took 2 months to reply my complain. also by email.
Return to “CT60 / CT63 Area”
