Jumper settings for TEAC FD-235hf 3291
catmando
Re: Jumper settings for TEAC FD-235hf 3291
Post by catmando »
I found this which may help
Jumper settings for the Teac FD-235HF3240
A1 - B1 DS0 Drive select 0
B1 - C1 DS1 Drive select 1
A2 - B2 DS2 Drive select 2
B2 - C2 DS3 Drive select 3
A4 - B4 RY34 Ready output on Pin 34
B4 - C4 DC34 Disk Change output on Pin 34
C3 - C4 DC2 Disk Change output on Pin 2
C4 - D4 DC4 Disk Change output on Pin 4
A3 - B3 HA density set automatically
B3 - C3 HI2 density set by HD IN on pin 2
C3 - D3 HO2 density (HD OUT) output on pin 2
D3 - D4 HO4 density (HD OUT) output on pin 4
D1 - D2 LHI ---or---
D2 - E2 LHI HD IN low is high density
D1 - E1 LHO ---or---
E1 - E2 LHO HD IN high is high density
E2 - F2 HMK half mask for INDEX/READ-DATA
F3 - G3 NMK no mask for INDEX/READ-DATA
F1 - G1 IR LED on when: (Drive Select AND Ready)
G1 - G2 ML motor on when: (Motor ON AND LED on)
E4 - F4 ACD disable auto-checking
G3 - G4 REN disable auto-recalibration
E2 - E3 HF ---or---
E3 - E4 HF must always be in for this version of drive
Atari STFM
Post by exxos »
Maybe you can take a image of the drive jumpers how you have them now, then crazy thought, just take all the jumpers out other than the DS one.
Looking at the doc there is also some MOTOR ON jumpers.. does the drive actually spin up when the floppy light is on ?
Post by exxos »
I would look into those 3 and for now remove all other jumpers.
catmando
Post by catmando »
G1G2 - gives me the drive icons, the motor spins and syncs the drive light with the light on the keyboard, but no data
Atari STFM
catmando
Post by catmando »
I'm not sure the automatic density is correct, see this doc here http://www.atari-forum.com/download/file.php?id=5560
Atari STFM
catmando
Post by catmando »
exxos wrote:A3 - B3 HA density set automatically
I tried this combo, still no data
Atari STFM
catmando
Post by catmando »
I found this Amiga info which mentions working combos for TEAC
Atari STFM
catmando
Post by catmando »
I found this info here
The diagram gives a little more information that I've been missing
Atari STFM
catmando
Post by catmando »
Think I've tried every combination of jumper positions on my Falcon and STE now, still no closer to solving this, the drive partially works on both machines in that I can get the platter to spin, the drive head to move and the drive lights to go on when reading the disk, but I can't get a file directory to show on either machine.
Here are my findings so far.
STE
Jumper must be set to DSO using A1B1
Floppy cable must be twisted so the tab on the IDC connector faces downwards (either remove the tab or force it to fit)
Falcon
Jumper G1G2 must used otherwise Falcon doesn't see any floppy drives
Floppy cable connects as normal so the tab on the IDC connector faces downwards (either remove the tab or force it to fit)
Other findings
G3G4 - Resets the drive head position when the drive is powered on
Atari STFM
Post by exxos »
It sounds like you are going though all the problems I did years ago. I did get mine working to a point but ultimately gave up with it. They are really not worth the trouble IMHO.
catmando
Post by catmando »
exxos wrote:It sounds like you are going though all the problems I did years ago. I did get mine working to a point but ultimately gave up with it. They are really not worth the trouble IMHO.
I've seen a couple of posts on the net claiming that they work on Amiga's so maybe I'll hang onto it in case I happen to acquire one at some stage.
Atari STFM
