68040 40Mhz Upgrade on Milan
Rustynutt
Re: 68040 40Mhz Upgrade on Milan
Post by Rustynutt »
The flash for the MB? Don't mean for the 060 upgrade.
Good to know it will still boot in 040 mode.
PeterS
Post by PeterS »
Rustynutt
Post by Rustynutt »
Yes, that's the early information I read about the flash. Michael said there is no way to tell what package is on the board. I have the box to do so, guess then I could check file sizes.
Rustynutt
Post by Rustynutt »
Peter, have you tried running the CPU (060) 3x the bus speed? We know the 060 easily can be over clocked to say 60 to 75mHz.. I guess then more IC's should be reviewed.
Was thinking of daisy chaining two
https://www.digchip.com/datasheets/part ... DW-pdf.php
The 926 can also output an inverted clock, which could be tested with the Falcon SDMA issues. It keeps a very tight spec on all clock outputs. Going to test this idea soon.
PeterS
Post by PeterS »
My hardware skills don't stretch that far.
I am not 100% exactly what flavour of 68060 I have in the Milan.
Rustynutt
Post by Rustynutt »
Still working in my Afterburner Falcon. It's had so many bus accelerators lot of rework required.
Purchased a pre-built Amiga adapter for the 060 since this thread started.
Also sent one of the DIY 060 Amiga to Neurotoxic, more 060 Mailan's the merrier :)
Soon!
Return to “Hades / Milan”
