(please read) Pasti transfers using bare bones method
using just a 1040STfm, a ran into countless errors of the various kind. only by reformatting and initializing "Pasti Transfer Disk" following each Pasti transfer, was i able to reduce errors to zero.
*edit
i'm not sure if this approach necessarly helped. perhaps not. i believe i got lucky 6x and that's all i needed
*edit
- Mug UK
- Administrator
Re: (please read) Pasti transfers using bare bones method
Sounds a bit odd .. one for Ijor to answer when he pops back
- Klapauzius
- The Klaz
Sounds like a duff PC floppy drive to me...
http://www.klapauzius.net
ok i just want to make clear errors were recieved on the ST side
the errors were:
possible disk damage (not true)
no disk present (not true)
disk write protection (not true)
the errors were:
- Mug UK
- Administrator
Have you got an external drive you can try instead with the same disks?
muguk wrote:Have you got an external drive you can try instead with the same disks?
sorry. if it's any consolation, all my images were made free of errors. not once was i prompted with retry/cancel. i was meticulous about that.
- Mug UK
- Administrator
I do all my PASTI images via a SatanDisk so only errors occur when it can't read the disk etc.
Exactly when are you getting those errors?st dragon wrote:ok i just want to make clear errors were recieved on the ST side
the errors were:
Do you have something "unusual" on your ST software or hardware setup? Which TOS version?
Are you using DD (and not HD) disks?
With the little information available, I would say it does look about some kind of floppy problems on the PC. Yes, you get the errors on the ST, but it might be because of the PC floppy drive.
ijor wrote: Are you using DD (and not HD) disks?
transfer disk i was using could've been HD although i'm not certain.
Muguk wrote:I do all my PASTI images via a SatanDisk so only errors occur when it can't read the disk etc.
yeah i don't think i'll be buying more stashes off eBay until i aquire that SatanDisk lol
