common Rf issues with nemesis + many chipset accelorators
Moderators: lp, moondog/.tSCc., Moderator Team
simbo
Re: common Rf issues with nemesis + many chipset accelorator
Post by simbo »
http://cgi.ebay.co.uk/1-8-ZIF-Hard-Disk ... 2617620217
i found this to complete the cable i made
the cable is setup as
ide cf master
sccard slave {switched power}
ide hdd 1.8" 60GB slave power switched from a broken ipod via the connector above
i liked this connector as it has a standard molex power and 50pin ide
cdrom drive ide 8 speed also slave and power switched and just fits in the case ,,,as it has two 5 1/4 " bays
on is use for a new floppy i got from atari freeks .com
i used 4 two ways switches for power
as i left one incase i needed another drive
i was thilled when the 1.8 worked and i got a working fat setup to 8 parts and one big ntsc for pc interchange
this is placed in an internal case i can clip onto the top of the rack
for the nemesis i added a 55mhz ttl clock oscillator and a ttl selector to allow me to use
16/20/25bus and 32 48 or 55 mhz chipset clocks
ill take some pics this weekend when i get back to it
but looking good !!!
and a nice reuse of what is a good ide drive ,, just needs a small adapter and a box...
if anyone needs a 55mhz crystal oscillator can square 4 pin pm me
EvilFranky
Post by EvilFranky »
Did you ever get round to doing some benches when clocked at 55Mhz? :D
simbo
Post by simbo »
not yet ive just had no time
ill get around to it soon
ive added the selector control and i can choose 48 or 55 mhz main clock
from a switch on the front of the rack
ive still to sort out the inside and mount the sdcard etc etc etc too much still on my case just now
:lol: winter for my own machine i feel
EvilFranky
From some of the forum posts I have read, it seems like you are very busy with other peoples stuff! :)
