Problem: Erratic Mouse Movement
mfletcher
Post by mfletcher »
I just brought my C-Lab Mk I out of storage to tinker with last night and Im having difficulty getting the mouse to work properly. What happens is when I move the mouse, the pointer moves over to either the left or right hand side of the screen. Up/Down movement is actually a diagonal movement. Ive reseated the mouse and even tried an Amiga mouse (before finding out that theres an incompatibility between Amiga and ST mice). Does anyone know if this is a common symptom of a failing ST mouse or something more serious like the mouse port beginning to fail? Anyone know where I can source a replacement mouse in N America, or worst case repairs?
Mark
Re: Problem: Erratic Mouse Movement
Post by DarkLord »
mfletcher wrote:Hi,
Mark
Since its' been in storage, did you clean the mouseball and rollers?
I know you've probably already done this, but its best to get the obvious out of the way...
mfletcher
Post by mfletcher »
DarkLord wrote: Since its' been in storage, did you clean the mouseball and rollers?
Yep, checked that already; the ball and rollers are clean. I had contacted Best-Electronics about a replacement mouse and they suggested that I try waggling the mouse cable (to see if its a broken connection) or waggling the mouse connector at the mouse port (to see if its a faulty port). Well further investigation revealed that the mouse works in the up-down axis but only moves to the left. Waggling the cable or the connector at the mouse port doesnt change this. Because waggling the connector doesnt change anything, I hope that just means that the mouse is faulty.
Hippy Dave
Post by Hippy Dave »
A fleck of grit may be hiding in the opto-encoders. Open the mouse up and give it a blast of air. Otherwise, it may be a bad solder joint.
simbo
Post by simbo »
check for any resident .acc files
use ctrl alt?? when booting to bypass hdd boot
and try the mouse again
otherwise youll need to resolder the ports on the keyboard
as this error isnt caused by the mouse its the port thats gubbed
Post by wongck »
I get this most of the time while swapping my logitech mouse between TT & falcon. Normally a good push into the socket works.
But I remember that this was happening to my old Atari mouse and it was the internal wires giving way.
mfletcher
Post by mfletcher »
Sorry to resurrect this thread, but I just recently got a hold of a second Atari mouse and it is exhibiting the same behaviour. So Im pretty sure at this point now that its the mouse port at fault.
So, my question is, is there any sites in the US that do Atari ST / Falcon repairs? If not, Im heading back to the UK at Xmas to visit my parents, are their any sites in the UK that could do such a repair?
Please help!
Thanks,
Mark
Paolo
Post by Paolo »
just a quick reply...
If it's a connector problem, as it seems to be, you shouldn't have any problem in doing it by yourself.
It's a matter of removing the case screws and re-solder the connector pins. You don't have to touch anything 'delicate' on the ST board, the connectors are on the edge of the motherboard.
BoNuS
Post by BoNuS »
I bought a second hand Mega STE and it also had a "bad" mouse.
It didn't really want to go down and leftt and right had the shakes ;)
I opend the mouse, cleaned the rollers but also push the little receptors
that count the opening ot the wheels of the mouse a little towards each other.
That fixed it for me, it now work 100% again.
So if you open the mouse you will see (if al goes well) 2 wheels with opening
in them. These are connected to the axes of the rollers.
These wheels move between little light receptors (transparant plastic things)
and they are the one's I mean. Just bent them gently so the distance between
them is smaller and then try it again with the ball in it...
http://bonus.home.xs4all.nl/
Post by joska »
Paolo wrote:just a quick reply...
The joystick/mouse-ports are on the keyboard itself. You have to disassemble the keyboard and resolder the ports.
Paolo
Post by Paolo »
OOPS! Sorry. I was thinking about the *side* joypad ports on the Falcon...
simbo
Post by simbo »
i fixed it perminatly
by removing the older keyboard ports and fitting two ports on the rear of the machine
farvardin
Post by farvardin »
hello,
I have one Atari ST mouse which doesn't work well. It seems the ball has lost its texture so there is less grip on the wheels and the movement is erratic. Is there a way to fix this?
