Enhanced GEM and popup menu
GFA, ASM, STOS, ...
Arne
Post by Arne »
I have almost completed my GEM application just one more thing to do.
I'm using EnhancedGEM Lib 2.20 and Pure C 1.1. I have included a popup via cycle button selection.
This is a screenshot of an EGEM demo application:
When I select an item of the popup menu itself (via clicking on the popup button itself) then my callback functions gets called and I can perform the required action (nothing to do with GEM at all).
But when I press the cycle button the selected item in the "popup button" area changes as expected but my callback isn't called. Any chance to change that?
thanks, Arne
Arne
Re: Enhanced GEM and popup menu
Post by Arne »
Seems I got it. I had to install an event handler to react to the cycle button event.
Event_Handler(EventInit, EventHandler);
static int EventInit(XEVENT* inCycleButtonEvent, int inEventMask)
	(void) inEventMask;
	inCycleButtonEvent->ev_mflags = MU_MESAG;
	return MU_MESAG;
static int EventHandler(XEVENT* inCycleButtonEvent)
	int			myResult = 0;
	if((inCycleButtonEvent->ev_mwich & MU_MESAG) != 0) {
		switch(inCycleButtonEvent->ev_mmgpbuf[0]) {
			case POPUP_CHANGED:
				/* check if inCycleButtonEvent->ev_mmgpbuf[4]/[5] (two 16bit int) point to your XPOPUP struct	*/
				/* if this is the case then the value (as given in the .H file generated by the RCS) is			*/
				/* located in inCycleButtonEvent->ev_mmgpbuf[3]													*/
				break;
			default:
				break;
		myResult = MU_MESAG;
	return myResult;
Don't know if this is the way it's meant to be done but it looks promising.
charles
Post by charles »
good work !
The radioactive half-life : )
Return to “Coding”
