Atari TT030 and system V
chance227
Re: Atari TT030 and system V
Postby chance227 » Mon Jul 08, 2013 12:14 am
wbyte
Thanks for having a go at Marks Image and getting it sorted, good to hear some of you younger lads getting in Atari ASV
I have downloaded the fixed copy of Marks system, and will try to load it up on my machine over the weekend.
I do have a Riebl card already installed and I had no issues with Richards image, so should be cooking with gas from here on.
i did find a diagram years ago with jumper settings for that card, and i was able to sort it out then i will try to get a pic of my card settings
so that you can compare them together.
my 2 cents worth for today
chance227
alexb
Postby alexb » Mon Jul 08, 2013 8:55 am
chance227 wrote:i did find a diagram years ago with jumper settings for that card, and i was able to sort it out then i will try to get a pic of my card settings so that you can compare them together.
Yes, that would be helpful - my Riebl card works fine with both NetBSD/atari and Linux/m68k - but ASV just doesn't seem to like it, and I have no idea why that is.
chance227 wrote:Thanks for having a go at Marks Image and getting it sorted, good to hear some of you younger lads getting in Atari ASV
Oh well, for me, all of this comes a bit late... I had been searching for an ASV installation for well over a decade, but when those images finally showed up here in 2006, my general retro-foo had already been weakened a lot, most of the old machines hadn't been turned on for a long time, and screeching old SCSI disks distinctly get on my nerves. So I switch on the TT every couple of weeks to poke at things for an hour or two, to see if maybe this time something falls over in the right place...
tenox
Postby tenox » Tue Oct 08, 2013 4:46 am
Okay so for those who want to run X11 there is how:
http://tenoxvga.tenox.net/
This adapter was made precisely so that I can run Xwindow. Please don't tell it to the Cubase users... :lol:
alexb
Postby alexb » Sun Nov 10, 2013 10:14 am
Ok, yesterday I found out why my Riebl card was never detected by ASV...
In asv_richard, the file /stand/edt_data contains the following line:
*NAME     FLAGS BOARD   IO_ADDR    IO_LEN    MEM_ADDR   MEM_LEN NVEC    VEC     IPL     TYPE    SPARE[4]
LA        -     0       0xfec0fff0      -       0xfec10000 0xee88 -     116     6       3 - - - -
...which, according to the Linux atarilance driver, are the addresses used in a MegaSTe. Of course, my card is configured with what everyone sais are the jumper settings for the TT.
Changed the LA line to:
LA        -     0       0xfe00fff0      -       0xfe010000 0xee88 -     116     6       3 - - - -
...and hey! - I have networking in ASV!
tenox
Postby tenox » Sun Nov 10, 2013 10:33 am
Well done!
So what are the jumper settings for TT?
I will be installing my Riebl card in just a few days.
alexb
Postby alexb » Sun Nov 10, 2013 10:58 am
I use the riebl settings from the NetBSD/atari FAQ: http://www.netbsd.org/ports/atari/faq.html#riebl
Can't get routing to work atm (there is a default route in the table, but I still can't reach any system outside the local network)... Now to bootstrap a more recent gcc ;) (I think maybe something in the line of 2.7.2 might work...)
[edit] I don't remember if the kernel got reconfigured automatically after I changed the edt_data - file... If it doesn't, boot with an -r on the kernel command line from the boot loader...
alexb
Postby alexb » Sun Nov 10, 2013 11:33 am
Turns out gcc 1.40 in ASV is good enough to compile gzip 1.2.4 :)
# ./gzip -V
gzip 1.2.4 (18 Aug 93)
Compilation options:
DIRENT UTIME STDC_HEADERS HAVE_UNISTD_H
[edit] ...and gcc 2.7.2.3 still contains a configuration for m68k-atari-sysv4:
# ./configure --prefix=/usr/local --program-suffix=-2.7.2.3 --disable-nls --build=m68k-atari-sysv4
Using `./config/m68k/m68k.c' to output insns.
Using `./config/m68k/m68k.md' as machine description file.
Using `./config/m68k/atari.h' as target machine macro file.
Using `./config/m68k/xm-atari.h' as host machine macro file.
Merged t-svr4.
Merged c++ fragment(s).
Created `./Makefile'.
Merged t-svr4.
Created `cp/Makefile'.
Links are now set up to build a native compiler for m68k-atari-sysv4.
(I'll have a look at newer gcc's someday, but I seem to remember that 2.7.2.3 was the last one that could be built without lots of fiddling around on m68k-sun3-sunos4...)
alexb
Postby alexb » Sun Nov 10, 2013 3:06 pm
By the way, asv_mark actually seems to be the more recent version. (No, didn't boot it yet, just had another look at some of the strings in the image files...)
asv_richard:
@(#) /usr/local/bin/gcc, version 1.39-05
Gnu C compiler
Tue Aug 27 17:52:43 EDT 1991
asv_mark:
@(#) /usr/local/bin/gcc, version 1.39-06
GNU C Compiler
Fri Jun 19 13:58:18 PDT 1992
tenox
Postby tenox » Mon Nov 11, 2013 4:01 am
Awesome work!
I'll help you out with porting efforts once I get my system up. I have to install the upgrades first!
viewtopic.php?f=88&t=25687
tenox
Postby tenox » Tue Nov 12, 2013 7:31 am
How is your jumper array C set?
My card had one jumper out - like this:
alexb
Postby alexb » Tue Nov 12, 2013 6:38 pm
C is all closed on mine. B is close/open/close. I have my card configured for AUI (A to top), and use an AUI/TP transciever. Contrary to the NetBSD FAQ, that one needs D in the top position, because otherwise the transciever isn't powered.
I didn't fully walk through the network configuration, but it seems the init scripts want an entry with the configured hostname and an associated IP address in /etc/hosts, and an appropriate entry in /etc/networks if you don't want classfull addressing.
gcc compilation bombed out with an internal compiler error in stage 1, so it seems that one needs another intermediate step.
mdivancic
Postby mdivancic » Sat Nov 16, 2013 7:54 pm
Guys:
How do I use the Image file on a Mac or PC or maybe even my Falcon running Mint? I have a PC running Windows 7 and a Mac running the latest version of 10. Any help would be great! Thanks!
Mikey
Commodore SX-64
wbyte
Postby wbyte » Tue Nov 19, 2013 3:50 pm
The easiest way is to attach 50pin scsi controller to your pc and boot some live linux dist. Then just write the image using dd.
mdivancic
Postby mdivancic » Tue Nov 19, 2013 11:44 pm
wbyte wrote:The easiest way is to attach 50pin scsi controller to your pc and boot some live linux dist. Then just write the image using dd.
Sadly, no SCSI on the PC side anywhere. Amiga, Atari, Mac and even my C64! :) Could this be installed on a CF card, I'm using a CF adaptor in my TT. I can image the card on my old PC laptop with a CF adaptor.
Mikey
Commodore SX-64
tenox
Postby tenox » Wed Nov 20, 2013 5:31 am
So I've dumped ASV image to a CF card attached via Acard. Normally works with TOS and NetBSD, but I get this:
This is for both Richard and Mark and on 4 different CF cards.
Has anyone successfully booted this from Acard+CF?
mfro
Postby mfro » Wed Nov 20, 2013 7:13 am
tenox wrote:So I've dumped ASV image to a CF card attached via Acard. Normally works with TOS and NetBSD, but I get this:
Never tried this myself.
If it doesn't work, it seems as if your Acard does not implement the SCSI read capacity command correctly (or at least in a compatible manner).
If I remember correctly, early SCSI standards defined a fixed CDB (command descriptor block) length (6 bytes?) while newer standards extended this to variable sizes to be able to cope with extended LBA lengths. May be the ACARD insists on the latter?
tenox
Postby tenox » Wed Nov 20, 2013 8:05 am
Also tried with Artmix CF AztecMonster. But that never works.
Are there any other SCSI to IDE bridges / adapters?
frank.lukas
Postby frank.lukas » Wed Nov 20, 2013 8:25 am
There are SCSI to IDE bridges from Yamaha V769970 and ACARD ...
tenox
Postby tenox » Wed Nov 20, 2013 8:32 am
Thanks for info!
I also found one from SCM MicroSystems PCD-xxx and I-O Data R-IDSC-E/R.
wbyte
Postby wbyte » Thu Nov 21, 2013 3:36 pm
I don't think it will work.
alexb
Postby alexb » Sun Nov 24, 2013 11:33 am
I was using NetBSD/atari to dd the file to another disk (sending the image over network via netcat - so that needs a network card supported by NetBSD).
After some time I just built a PC with a SCSI card from spare parts to write the images, as it's way faster than pushing bits through the bloody Riebl thing...
alexb
Postby alexb » Sun Nov 24, 2013 11:45 am
tenox wrote:Also tried with Artmix CF AztecMonster. But that never works.
For SD cards on an Atari, there's the Gigafile, which works very well as ACSI device (SCSI mode seems somewhat experimental from what I heard).
At least according to the ASV documentation, it should be able to boot from an ACSI device too, but I never tried that (also never seen your error message)...
mfro
Postby mfro » Sun Nov 24, 2013 1:29 pm
alexb wrote:At least according to the ASV documentation, it should be able to boot from an ACSI device too, but I never tried that (also never seen your error message)...
To my knowledge, ASV never had proper ACSI support (although it _might_ be possible to have the root sector on an ACSI disk since the boot code uses DMAread() to get at it).
Where did you find that documented?
alexb
Postby alexb » Sun Nov 24, 2013 10:13 pm
mfro wrote:To my knowledge, ASV never had proper ACSI support (although it _might_ be possible to have the root sector on an ACSI disk since the boot code uses DMAread() to get at it).
Sorry - I thought I had seen that in the release notes somewhere, but upon checking the documentation, it actually sais:
Note that ACSI hard disk drives are not supported by Atari System V.
tenox
Postby tenox » Mon Nov 25, 2013 11:12 pm
I'm currently rounding up a number of different SCSI to ATA adapters and will try with different ones and report.
There also may be an issue with CF cards being reported as removable devices. While this may not matter to TOS it may to ASV. I have purchased couple of industrial CF cards that do report as non-removable media. We shall see.
