Problem with Saint 1.99d and pasti
keili
Postby keili » Thu May 19, 2005 8:16 am
I've been told, that pasti-images larger than 1MB are not accepted by Saint.
ecureuil
Postby ecureuil » Thu May 19, 2005 1:14 pm
It's a same case for Steem. Imo It's a limitation of dll for some reasons, i think.
Bye
Postby ijor » Thu May 19, 2005 3:07 pm
Hmm, I have no problems loading huge Pasti images under Steem. I just tried loading a 2Mb image. Just in case I tried both a separate file and inside a zip, both ways worked fine.
I do get a crash under Saint. Didn't yet investigate if the problem is in the Dll or in Saint. Even when it works ok under Steem, it might still be my fault. Don't worry, either way we'll fix this shortly enough.
Thanks for the report. And if you have more details, please let us know.
leonard
Postby leonard » Fri Jul 01, 2005 8:36 am
humm have to check this in SainT. I let you know if I find something wrong, but I remember I don't do memory allocation (I think Pasti engine does).
Leonard/OXYGENE.
k2rboys
Postby k2rboys » Fri Jul 01, 2005 4:47 pm
I can confirm, that the pasti-images realised with the 0.4b version of the software if upper than 1MB are not accepted by Saint 1.99d! :cry:
It is not the same case for Steem 3.2 where´s everything is practically Ok!
leonard
Postby leonard » Thu Jul 07, 2005 10:31 am
could you provide me a non working pasti image under saint ? (wich works with other emulatator) ?
Leonard/OXYGENE.
k2rboys
Postby k2rboys » Thu Jul 07, 2005 11:40 am
Yes, give me your e-mail address please! 8)
Postby Mug UK » Thu Jul 07, 2005 12:33 pm
k2rboys: It's under everyone of his posts under the email button.
k2rboys
Postby k2rboys » Thu Jul 07, 2005 12:51 pm
Have some exemples of larges images at:
http://atari.hable.net/
8)
leonard
Postby leonard » Thu Jul 07, 2005 3:38 pm
Ok I just checked the code and it's fault to SainT, not Pasti. There is a bug wich prevent to load any STX image with no "standard" size (I mean sector*side*tracks). STX file is not supposed to have particular size to support any future extension, so I have to change my buggy code.
I'll fix that bug in the next SainT release.
Leonard/OXYGENE.
leonard
Postby leonard » Thu Jul 07, 2005 10:22 pm
Ok just before my vacations I wanted to fix that nasty bug. You can download SainT 1.99e on my website. Large Pasti image files should work properly now.
Leonard/OXYGENE.
Postby ijor » Fri Jul 08, 2005 2:39 am
Hi Leonard,
Great job!
Have a nice holiday! Don't think too much on sprites, demos, and such while on vacations :)
leonard
Postby leonard » Fri Jul 08, 2005 8:20 am
Héhé no computer there so no sprite or demos :-)
I take plane tomorrow morning, going in Corsica ! (beautifull island of the world :-))
Leonard/OXYGENE.
k2rboys
Postby k2rboys » Fri Jul 08, 2005 10:32 am
Have a nice holiday :!:
Return to “SainT”
