paulbnl wrote:Might be worth adding a hdmi_limited=2 option for Limited 16-255.
These are the CSC changes:
0x18 8D-> 8E
0x19 BC-> FE
0x22 0D -> 0E
0x23 BC -> FE
0x2C 0D -> 0E
0x2D BC -> FE
Sorgelig wrote:paulbnl wrote:Might be worth adding a hdmi_limited=2 option for Limited 16-255.
Ok, i will add this change.
Sorgelig wrote:Ok, i will add this change.
JamesF wrote:Thank you paulbnl, it works great!
@Sorgelig
Seems like the SOG resistor+diode injection of csync to the Y (luma), it signal pulls is slightly below 0v so the black shades are clipped when using the VGA adapter with this resistor+diode SOG mod.
The IO boards has a buffer transistor for SOG and does not change the Y signal, but this quick resistor+diode mod does.
Lightwave wrote:
I’m thinking of getting this Rankie pigtail adapter to test, has anyone had any success with it?
https://www.amazon.ca/gp/product/B00ZMV7RL2/
Stremon wrote:Forgive me if it's not the place to ask, but would 240p at 120Hz work with direct video mode compared to the IO board VGA?
I know it's kind of possible to get it working with the HDMI scaler, but it's not great for latency and video mode matching.
Sorgelig wrote:Stremon wrote:Forgive me if it's not the place to ask, but would 240p at 120Hz work with direct video mode compared to the IO board VGA?
Direct Video from its name means video directly from the emulated system without processing. So, if core originally outputs 120Hz, then it will go to HDMI. I never tried 120Hz and i don't know if there is any limitations. I don't have such monitor.
If original core outputs 60Hz, then you have to delay the video by at least one frame. It's like a scaler, it needs to accumulate one frame so it will be able to repeat it 3 times. So it's definitely not for low-lag option.
Sorgelig wrote:It works fine for me.
Make sure you didn't enable menu_pal option.
Otherwise may be your monitor doesn't like some specific resolution..
warham wrote:I tried direct vid in one of the nintendo cores but it shifted the screen like 2cm to the right. I saw someone elses screenshot look the same as mine. Is there a way to adjust screen centering for this? The is on an LCD.
Users browsing this forum: witchmaster and 17 guests
