Changing the root password?
robdaemon
Postby robdaemon » Sat Mar 09, 2019 3:46 am
Hi there,
I tried to change my root password on the MiSTer after logging in, and after a reboot, I could no longer login.
After the reboot, it was attempting to force me to change the password again but would not complete the change. I ended up backing up my SD card and running the installer again.
Attached is a screenshot from putty when I did it.
I'd really like to change this password - I don't like leaving things on my network with a default password.
fry
Re: Changing the root password?
Postby fry » Sat Mar 09, 2019 5:15 am
How did you change it? The normal method ("passwd" command) worked fine for me.
Better yet, just disable password logins in /etc/ssh/sshd_config and use an SSH key.
Locutus73
Postby Locutus73 » Sat Mar 09, 2019 10:46 am
Just for your info: if you want to harden MiSTer Linux a bit, you could try security_fixes.sh here https://github.com/MiSTer-devel/Scripts_MiSTer or already in your /media/fat/#Scripts if you use the updater. As usual: use it at your own risk and don’t blame me if you lock yourself out or if your MiSTer gets self conscious and starts a war against the human race.
Anyway passwd obviously works and copying linux.img from the installer on the SD reverts back all Linux changes.
Regards.
Locutus73
robdaemon
Postby robdaemon » Sat Mar 09, 2019 5:14 pm
fry wrote:How did you change it? The normal method ("passwd" command) worked fine for me.
I used passwd - it worked fine until a reboot.
robdaemon
Postby robdaemon » Sat Mar 09, 2019 5:15 pm
Locutus73 wrote:Anyway passwd obviously works and copying linux.img from the installer on the SD reverts back all Linux changes
passwd doesn't obviously work, as that's how I got into this situation to begin with.
I didn't know about copying the linux.img over though, that helps a lot. I'll try out the security script you mentioned too.
Locutus73
Postby Locutus73 » Sat Mar 09, 2019 6:11 pm
That’s really weird.
robdaemon wrote:I didn't know about copying the linux.img over though, that helps a lot. I'll try out the security script you mentioned too.
Let us know how it ends, the script uses passwd as well.
Regards.
Locutus73
Users browsing this forum: comatron, kublai, Peredonov, spunkworks and 5 guests
