MiSTer updater script
SegaMan
Re: MiSTer updater script
Postby SegaMan » Thu Jan 10, 2019 11:15 am
thx @locutus73
It´s clear now to me :)
Locutus73
Postby Locutus73 » Thu Jan 10, 2019 12:50 pm
Sorgelig wrote:MiSTer.ini is on github since beginning:
https://github.com/MiSTer-devel/Main_Mi ... MiSTer.ini
No Sorg, he was referring to the optional updater ini (do you remember you suggested this mechanism?)
Regards.
Locutus73
Locutus73
Postby Locutus73 » Thu Jan 10, 2019 12:53 pm
SegaMan wrote:thx @locutus73
Thank you... but it isn't still clear to me how making the README more noob user friendly...
Regards.
Locutus73
MattE888
Postby MattE888 » Thu Jan 10, 2019 1:44 pm
Locutus73, your instructions are very clear and I didn't have any problems. So I'm totally fine how it is! However, if you are wanting to super polish the documentation, it could be more consistent with how the MiSTer files and documentation are presented. The MiSTer has a totally separate ini file that is linked to, that can be downloaded. If the updater script documentation had a separate ini file to link to and for people to download, that would be more consistent with the MiSTer files and documentation.
edit: I just noticed that esmith13 was recommending this too. My only real addition to his request is that I'm pointing out that consistency with the MiSTer files and documentation(by including a separate downloadable ini file) is probably a good thing.
Also, thanks so much for adding core filters to that ini file. Very nice!!!!
SegaMan
Postby SegaMan » Thu Jan 10, 2019 6:43 pm
Regards.
Locutus73
I think a finished (downloadable) example of update.ini/mister_updater.ini file on your github page could be helpful. :angel:
Locutus73
Postby Locutus73 » Thu Jan 10, 2019 7:02 pm
ini examples added.
Regards.
Locutus73
SegaMan
Postby SegaMan » Sat Jan 12, 2019 6:56 pm
Ok, one thing to know for me :angel:
When i use update.sh
it downloads the latest mister_updater.sh and run it.
Will it than use the mister_updater.ini (i created with my settings)?
Locutus73
Postby Locutus73 » Sat Jan 12, 2019 7:39 pm
SegaMan wrote:Ok, one thing to know for me :angel:
It will use update.ini or whatever you call the script you launch through the OSD.
Regards.
Locutus73
SegaMan
Postby SegaMan » Sat Jan 12, 2019 8:43 pm
Ok.
Then i put the user option selection (https://github.com/MiSTer-devel/Updater ... sh#L41-L90) into update.ini and when launching the update.sh it will use this settings?
Locutus73
Postby Locutus73 » Sat Jan 12, 2019 9:54 pm
SegaMan wrote:Ok.
Correct... usually I put only the options I customize in the ini.
Regards.
Locutus73
SegaMan
Postby SegaMan » Sat Jan 12, 2019 9:56 pm
Thx for help :cheers:
Postby Sorgelig » Mon Jan 14, 2019 4:47 am
by the way, to load the rbf you can use command fpga:
fpga <path_to_rbf>
it will load rbf and trigger the reset. So, this loading is a little slower than load through menu, but should be ok for specific needs.
Locutus73
Postby Locutus73 » Mon Jan 14, 2019 8:10 am
Sorgelig wrote:by the way, to load the rbf you can use command fpga:
fpga <path_to_rbf>
Oh, great! Thanx!
Locutus73
Locutus73
Postby Locutus73 » Mon Jan 14, 2019 8:28 am
fpga <path_to_rbf>
With trigger the reset do you mean the FPGA/core reset? Does this command reset/force main MiSTer to reload the ini or do I have to kill and relaunch it? If I have to relaunch MiSTer, do you prefer the rbf to be called first or later (I guess later), I mean something like.
killall MiSTer
/media/fat/MiSTer >/dev/ttyS0 2>/dev/ttyS0 </dev/null &
fpga/media/fat/menu.rbf
For loading a new ini and resetting the main menu.
Thank you in advance.
Regards.
Locutus73
Postby Sorgelig » Mon Jan 14, 2019 10:26 am
just try and you will see.
Locutus73
Postby Locutus73 » Mon Jan 14, 2019 12:51 pm
Sorgelig wrote:just try and you will see.
Ok, as soon as I am home I'll fiddle with it.
Ciao.
Locutus73
Postby Sorgelig » Mon Jan 14, 2019 3:49 pm
You don't need to kill the MiSTer.
Just fpga /media/fat/menu.rbf will do everything.
Locutus73
Postby Locutus73 » Mon Jan 14, 2019 7:25 pm
Sorgelig wrote:You don't need to kill the MiSTer.
Thnx, I just tested fpga /media/fat/menu.rbf, but I see on the serial console a full reboot (I see u-boot messages), so it seems equivalent to reboot now, at least if I use menu.rbf; am I wrong?
Regards.
Locutus73
Postby Sorgelig » Mon Jan 14, 2019 8:07 pm
Locutus73 wrote:Thnx, I just tested fpga /media/fat/menu.rbf, but I see on the serial console a full reboot (I see u-boot messages), so it seems equivalent to reboot now, at least if I use menu.rbf; am I wrong?
As i've told earlier, core loading will trigger the reset of HPS part.
Locutus73
Postby Locutus73 » Tue Jan 15, 2019 9:40 am
Yeah I see... It's just that in the first post you just said reset and I was projecting my hope for just a "core reset" or "MiSTer executable reset", not a proper system reset. It's just that some users are asking if there's a way to apply the ini settings without rebooting, but that's not a major issue to me.
Thank you.
Locutus73
high5
Postby high5 » Tue Jan 15, 2019 11:23 am
Hey, thanks for the script. Works like a charm for me. :D
Just a small note from a first time MiSTer and update-script user. After I prepared the SD card I did not update any MiSTer-components manually so the scripts-options was not present in OSD. Did execute update.sh via ssh for the first time and after that everything also works via OSD.
Postby Sorgelig » Tue Jan 15, 2019 2:58 pm
Thank you.
Locutus73
i didn't think about loading the core outside the MiSTer as it's beyond the scope of MiSTer usage. So it's workaround way - so can't expect smoothness of this way.
Actually INI file re-read with every core load. So, if you change some settings in INI and then load the core from OSD then it will use new settings from ini. Probably it will be enough in most cases. If you want to change the settings for current core, then simple kill and load MiSTer will apply new ini settings without reloading the core.
As for loading the core from shell without reset - i will think about it. If you have an idea how to send the command to MiSTer binary - tell me.
Locutus73
Postby Locutus73 » Tue Jan 15, 2019 3:07 pm
New mister_updater.sh:
Version 1.8 - 2019-01-15 - Using /media/fat/#Scripts/.mister_updater as work directory, you can safely delete MiSTer_yyyymmdd, menu_yyyymmdd.rbf and release_yyyymmdd.rar from SD root now; using empty files as semaphores and corrected a minor bug about their target directories; improved user option comments.
https://github.com/MiSTer-devel/Updater_script_MiSTer
Regards.
Locutus73
Shazz
Postby Shazz » Wed Jan 16, 2019 12:01 am
fpga <path_to_rbf>
Would it be possible to add an optional parameter to the fpga command to automatically mount a virtuak disk/rom ?
...8bits are enough...
jayp76
Postby jayp76 » Sun Jan 20, 2019 3:18 pm
@Locutus73
I have a suggestion to your script. Wouldn't it be more user friendly for custom setups to have for e.g DOWNLOAD_NEW_CORES="true" or REPOSITORIES_FILTER="xxx" in a separete file. Because if everybody uses your update.sh script, it automatically uses the default value of said options.
If every user has this in a seperate file, the user could keep his own default values, that are not overwritten by the updater script.
Users browsing this forum: Set and 5 guests
