Newbie questions
Re: Newbie questions
Postby Sorgelig » Tue Jan 08, 2019 4:34 pm
System information will be extended later.
MattE888
Postby MattE888 » Tue Jan 08, 2019 8:48 pm
Does anyone know what size of screw would fit into the DE10 Nano standoffs? I got some M2.5 screws but was too small.
Poobah
Postby Poobah » Tue Jan 08, 2019 9:30 pm
I've been using M3 screws. They aren't exact, but seem close enough.
stepea
Postby stepea » Tue Jan 08, 2019 9:38 pm
MattE888 wrote:Does anyone know what size of screw would fit into the DE10 Nano standoffs? I got some M2.5 screws but was too small.
silly question, What size are the standoffs ?
MattE888
Postby MattE888 » Wed Jan 09, 2019 3:06 am
Poobah wrote:I've been using M3 screws. They aren't exact, but seem close enough.
Thanks! M3 seems perfect to me.
BlockABoots
Postby BlockABoots » Sat Jan 12, 2019 2:22 pm
Is it possible to add a feature so you can set a default folder for each core, for example the NES core you can set the default folder for where the roms are so each time you load a game it will automatically open up at that folder?
Postby Sorgelig » Sat Jan 12, 2019 9:19 pm
nope.
may be i will add it at some point
jft
Postby jft » Sun Jan 13, 2019 4:15 pm
BlockABoots wrote:Is it possible to add a feature so you can set a default folder for each core, for example the NES core you can set the default folder for where the roms are so each time you load a game it will automatically open up at that folder?
MiSTer already does this, but the folder names are hardcoded. For example sdcard:/NES/ is where all NES roms would go, and the core starts in that folder.
jft
Postby jft » Sun Jan 13, 2019 4:17 pm
stepea wrote:silly question, What size are the standoffs ?
I do believe they are exactly M3 sized. I have other M3 standoffs and the same screws fit.
stepea
Postby stepea » Sun Jan 13, 2019 5:06 pm
aosuke
Postby aosuke » Sun Jan 13, 2019 10:18 pm
Hey, Im having a surprisingly hard time finding documentation on this. Can you get a vga to rca adapter to work on just a plain old CRT? I have the adapter but i cant seem to get it to work, Im not sure if i need to change the .ini file or if my adapter just wont work. my cord could very well just be old and broken, but i also dont know if i just am not configuring it right
Lodovic
Postby Lodovic » Mon Jan 14, 2019 12:49 am
Is there a way to get the time adjusted to a different time zone when MiSTer is booting connected to the internet?
DrOG
Postby DrOG » Mon Jan 14, 2019 5:50 am
aosuke wrote:Hey, Im having a surprisingly hard time finding documentation on this. Can you get a vga to rca adapter to work on just a plain old CRT? I have the adapter but i cant seem to get it to work, Im not sure if i need to change the .ini file or if my adapter just wont work. my cord could very well just be old and broken, but i also dont know if i just am not configuring it right
It should work, but you have to enable sync-on-green on the IO Board, and edit MiSTer.ini to get component video over the VGA connector: https://github.com/MiSTer-devel/Main_Mi ... MiSTer.ini
Mofe infos here:
viewtopic.php?f=117&t=34955&p=361949#p361949
EDIT
If you want to use a very old TV-set with only composite (yellow) RCA connector, you need to get an external converter as well, see details in the topic linked below:
viewtopic.php?f=117&t=35062
eightbitminiboss
Postby eightbitminiboss » Mon Jan 14, 2019 9:23 am
Lodovic wrote:Is there a way to get the time adjusted to a different time zone when MiSTer is booting connected to the internet?
Yep, if you have and used Locutus' latest update script, it should have also downloaded several new scripts. One of them is named timezone, when you run it it checks your IP and ascertains where you are in the world and changes the time zone for you.
https://github.com/MiSTer-devel/Updater_script_MiSTer
guvner
Postby guvner » Mon Jan 14, 2019 10:35 am
Or he could just follow the directions from the MiSTer wiki and set his time zone manually.
Lodovic
Postby Lodovic » Mon Jan 14, 2019 1:17 pm
Great! Thanks.
SegaMan
Postby SegaMan » Sat Jan 19, 2019 9:20 am
MiSTer update and change log says.
-linux
How can i update linux :angel:
JamesF
Postby JamesF » Sat Jan 19, 2019 10:03 am
del
Postby Sorgelig » Sat Jan 19, 2019 10:36 am
SegaMan wrote:MiSTer update and change log says.
-linux
download the latest release here: https://github.com/MiSTer-devel/SD-Inst ... n64_MiSTer
and run SD installer to update the SD card files.
You can update files manually as well.
SegaMan
Postby SegaMan » Sat Jan 19, 2019 11:18 am
Thx! :cheers:
bitfan2011
Postby bitfan2011 » Sun Jan 20, 2019 4:39 pm
RE: ZX Spectrum core
What folder name should I be using for the ROM location on the primary SD? The core doesn't default to the correct location the way some others do. Cheers
Postby Sorgelig » Sun Jan 20, 2019 9:15 pm
Spectrum
high5
Postby high5 » Mon Jan 21, 2019 11:00 pm
Hi, is there a way to map german keyboard layout to MiSTer and the other cores?
In extend I am using a multimedia keyboard where F1-F12 keys have to be accessed by pressing FN+F-key. Is there an easy way to change FN+F-key to F-key and visa versa.
E.g. F2 is home button, FN+F2 is F2-key - I would like F2 = F2-Key and FN+F2 = home.
Postby Sorgelig » Tue Jan 22, 2019 12:01 am
There is keyboard remap function in Menu core.
djmartins
Postby djmartins » Tue Jan 22, 2019 2:42 am
jft wrote:I do believe they are exactly M3 sized. I have other M3 standoffs and the same screws fit.
Closest American size to M3 is 4-40, I can check later if this is a problem for someone.
Users browsing this forum: crocky, Dacide, dshadoff and 17 guests
