Genesis Core
thelatestmodel
Re: Genesis Core
Postby thelatestmodel » Sat Apr 20, 2019 1:43 am
Is anyone else having issues with Decap Attack? My button mappings work properly in every other game (that I've tried), but in Decap Attack I get weird stuff like C acting as C and Start at the same time, B acting as A, and A not doing anything. D-pad seems to work fine. I've tried a couple of different ROMs, same result.
I see there were some input issues with it in the past, is it still broken?
Re: Genesis Core
Postby Sorgelig » Sat Apr 20, 2019 11:24 am
thelatestmodel wrote:Is anyone else having issues with Decap Attack? My button mappings work properly in every other game (that I've tried), but in Decap Attack I get weird stuff like C acting as C and Start at the same time, B acting as A, and A not doing anything. D-pad seems to work fine. I've tried a couple of different ROMs, same result.
it was fixed some time ago in the beginning of december. Then something broke it again.
I will check.
Re: Genesis Core
Postby Sorgelig » Sat Apr 20, 2019 4:35 pm
what is unclear to me if Genesis (or gamepad) has pull up resistors on gameport or not. If TH is configured as input will gamepad see it as 1 or 0.
ovalfastlx
Re: Genesis Core
Postby ovalfastlx » Sat Apr 20, 2019 7:32 pm
Anyone else has audio distortion or crackling when playing Sonic 3? I need to see if it's my actual mister hardware or the core.
I changed the hdmi 96k and 48k and it doest make a difference.
Here's a video I uploaded. Thanks
[youtube=]https://youtu.be/Lf_R-IAih8o[/youtube]
JamesF
Re: Genesis Core
Postby JamesF » Sat Apr 20, 2019 8:03 pm
ovalfastlx wrote:Anyone else has audio distortion or crackling when playing Sonic 3?
Already reported.
https://github.com/MiSTer-devel/Genesis ... /issues/28
@Sorgelig
I can measure my console ports if you need.
Please guide me what to do.
I also have an oscilloscope.
ovalfastlx
Re: Genesis Core
Postby ovalfastlx » Sat Apr 20, 2019 8:20 pm
Already reported.
@Sorgelig
It thought it was a only sonic 3 but a similar fortress appears on sonic and knuckles. Thanks
Re: Genesis Core
Postby Sorgelig » Sun Apr 21, 2019 6:21 am
ovalfastlx wrote:Anyone else has audio distortion or crackling when playing Sonic 3? I need to see if it's my actual mister hardware or the core.
was it always present or introduced recently? If it was appeared from some build then which one?
Re: Genesis Core
Postby Sorgelig » Sun Apr 21, 2019 6:24 am
JamesF wrote:I can measure my console ports if you need.
i don't think you can just measure it. It requires some test ROM which will output different data to gameport.
Btw, with my latest commit on github Decap Attack works well. Not sure if it brakes any other games. It seems the are no pull up resistors on gameport.
jemismyname
Re: Genesis Core
Postby jemismyname » Sun Apr 21, 2019 6:26 am
oh, i was hearing some weird crunchiness today when i was playing Truxton on the genesis 20190407 version. it was like, right after i would ... i don't remember where i was, but not too far into the game... that game is hard.
I couldn't tell if it was maybe a mixing thing... it sounded like maybe too many sounds were getting mixed together and it was going over digital 0 dB?
It wasn't quite right, but honestly, a real genesis sounds distorted anyway :D
ovalfastlx
Re: Genesis Core
Postby ovalfastlx » Sun Apr 21, 2019 7:01 am
I has been present in all builds that I have used since last Sept 2018. Just that today I got around to put it on video, but it's been noted already.
jotego
Re: Genesis Core
Postby jotego » Wed Apr 24, 2019 10:26 am
Have you heard those noises in the MiST version too?
My Patreon page here.
JamesF
Re: Genesis Core
Postby JamesF » Wed Apr 24, 2019 12:13 pm
It's digital overflow, the mix is just too loud.
Tested with spdif, the input is always close to 0.0db which I can see in my DAW,, and in that particular part in Sonic 3 it reaches 0.0db and clips.
cwbowron
Re: Genesis Core
Postby cwbowron » Sat May 04, 2019 12:17 pm
The latest core (20190503) is broken for me, but the previous release (20190415) works fine. When I load latest, all the lights on my IO board go off and my TV says "No Signal". I'm using HDMI for audio and video.
straddle
Re: Genesis Core
Postby straddle » Fri May 10, 2019 8:55 am
Is the Genesis Core capable of playing of playing 32X games?
lolof
Re: Genesis Core
Postby lolof » Fri May 10, 2019 9:10 pm
20190503 gave me black screen with sound.
Problem solved with 20190510
hyperterminal
Re: Genesis Core
Postby hyperterminal » Sat May 11, 2019 8:41 am
straddle wrote:Is the Genesis Core capable of playing of playing 32X games?
No, and it won't play Sega CD games either nor the normal Virtua Racing. The required hardware won't be implemented any time soon. Not even the mighty Kevtris who programs FPGAs all day for a living was able to pull this off.
Re: Genesis Core
Postby Sorgelig » Sat May 11, 2019 2:10 pm
Not sure why Virtua Racing added in this list. It's pretty much doable if someone would like to implement.
PhantombrainM
Re: Genesis Core
Postby PhantombrainM » Sun May 12, 2019 7:07 pm
Sonic & Knuckles + Sonic 2 (W) [!].md
MD5 3e5e4b18d035775b916a06f2b3dc5031
shows only black screen. It was working, i played it already. Checksum of file checked with a local backup copy.
Grego2d
Re: Genesis Core
Postby Grego2d » Tue May 14, 2019 12:11 am
Attempted an overclock of the 68k for the Genesis mister core today, the result is drastically smoother game play across the board!
In my testing nearly every game benefits from a modest 1.5x increase in speed, Sonic Spinball is a blast at full speed, and Road Rash is a whole new experience. The VDP seems to have no issues with the higher clock speed.
This modification results in audio issues in most games, Spinball and Road Rash II being exceptions. I believe this is caused by an issue with the 68k sending the z80 code/data at this higher clock rate. One solution I thought of would be to use the normal clock speed when accessing the z80. I'll be experimenting with fixes.
Here is a link to the build:
https://ufile.io/561bcics
Specifically I changed lines 138-148 in system.sv to:
      M68K_CLKENp <= 0;
      VCLKCNT <= VCLKCNT + 1'b1;
      if (VCLKCNT == 4) begin
         VCLKCNT <= 0;
         M68K_CLKENp <= 1;
      end
      M68K_CLKENn <= 0;
      if (VCLKCNT == 2) begin
         M68K_CLKENn <= 1;
      end
Grego2d
Re: Genesis Core
Postby Grego2d » Tue May 14, 2019 3:59 am
Couple of attempts and I think I have Z80 communication fixed. Audio is still messed up in most games, but it's improved. I think the remaining issues are caused by the 68k accessing the psg directly, but I'm not sure.
      M68K_CLKENp <= 0;
      if ((!Z80_BUSRQ_N & VCLKCNT == 6) | (Z80_BUSRQ_N & VCLKCNT == 4)) begin
         VCLKCNT <= 0;
         M68K_CLKENp <= 1;
      end
      M68K_CLKENn <= 0;
      if ((!Z80_BUSRQ_N & VCLKCNT == 3) | (Z80_BUSRQ_N & VCLKCNT == 2)) begin
         M68K_CLKENn <= 1;
      end
Grego2d
Re: Genesis Core
Postby Grego2d » Tue May 14, 2019 5:02 am
Last try for the day, slow down all Audio/Vdp accesses, this code is only looking for the 68k to access the ram regions, it would probably be better to slow down the entire opcode not just the write/read portion of its execution... I'm not terribly familiar with genesis so if anyone has any ideas let me have em.
      M68K_SLOW_ACCESS <= !Z80_BUSRQ_N | M68K_A[23:20] == 'hC | M68K_A[23:20] == 'hA;
      M68K_CLKENp <= 0;
      if ((M68K_SLOW_ACCESS & VCLKCNT == 6) | (!M68K_SLOW_ACCESS & VCLKCNT == 4)) begin
         VCLKCNT <= 0;
         M68K_CLKENp <= 1;
      end
      M68K_CLKENn <= 0;
      if ((M68K_SLOW_ACCESS & VCLKCNT == 3) | (!M68K_SLOW_ACCESS & VCLKCNT == 2)) begin
         M68K_CLKENn <= 1;
      end
SegaMan
Re: Genesis Core
Postby SegaMan » Tue May 14, 2019 7:46 am
I am not sure if there is a context.
After updating to latest MiSTer and download the cheat files over update script my Genesis Core (latest version) did not run at all.
Sometimes the games work... most time i got a black screen with "no sync" on my gaming monitor.
slingshot
Re: Genesis Core
Postby slingshot » Tue May 14, 2019 1:27 pm
Grego2d wrote:Last try for the day, slow down all Audio/Vdp accesses, this code is only looking for the 68k to access the ram regions, it would probably be better to slow down the entire opcode not just the write/read portion of its execution...
I read many people overclocked the Mega Drive without much problems, and it just involved a simple 68k clock increase. I've also did it in MiST, didn't notice problems (but mostly tried 3D games only). Btw, VDP will throttle the CPU anyway if it tries to write too fast.
Upd.: the problem with your patch is the sequence of the clock enables. You made n-n-p-p clock enable, but it must be n-p-n-p.
Grego2d
Re: Genesis Core
Postby Grego2d » Tue May 14, 2019 4:28 pm
Did you get it working? If so what was your change? I don't see how that results in multiple of the same pulse.
slingshot
Re: Genesis Core
Postby slingshot » Tue May 14, 2019 4:36 pm
Grego2d wrote:Did you get it working? If so what was your change? I don't see how that results in multiple of the same pulse.
Yes, it works. The change is very simple:
https://github.com/mist-devel/fpgagen/c ... 56ce523b5a
Which game do you have sound issues? I can check it.
Here VCLKCNT 1-PHI2, 3-PHI1, 4-PHI2, 6-PHI1
Users browsing this forum: Peredonov and 10 guests
