Sorgelig wrote:As far as i know there are only 2 games in Genesis using interlace mode: Sonic 2 (and only in split screen mode!) and some other game i forgot the name. So it's definitely not a reason to keep a bulky VIP scaler.
Combat Cars
toolb0x wrote:I'm getting a black screen saying "Resolution not supported" with both 20181205 and 20181206 cores. I'm using the default settings in the ini. I have a Samsung 4K TV.
Sorgelig wrote:toolb0x wrote:I'm getting a black screen saying "Resolution not supported" with both 20181205 and 20181206 cores. I'm using the default settings in the ini. I have a Samsung 4K TV.
try the version i've posted there: viewtopic.php?p=360030#p360030
vanfanel wrote:The music problems in Streets of Rage II are still present with the updated PSG engine (JT89). I believe that the channels with wrong notes are from the OPL, not the PSG.
Sorgelig wrote:Even on youtube videos this part sounds weird. It's just music written this way.
Anyway, forget about it - it won't be fixed. It's just 1-2 seconds.
paulbnl wrote:Is it possible to make the core run at original speed (59.92Hz)? I noticed it currently outputs at 60.20Hz
BlockABoots wrote:Does the latest Genesis core use the low latency mode (vsync_adjust=2)?
Sorgelig wrote:paulbnl wrote:Is it possible to make the core run at original speed (59.92Hz)? I noticed it currently outputs at 60.20Hz
what's the difference?
Sorgelig wrote:Many fixes in new releases.
Titan Overdrive - everything is perfect now.
Titan Overdrive 2 - mostly OK. There is unknown cause of audio lag. Arcade scene flickers and won't be fixed (as it useless for games).
Shazz wrote:Sorgelig wrote:Many fixes in new releases.
Any chance to get the Overdirve 2's arcade full screen effect fixed one day ? (I try ^^)
Sorgelig wrote:yes. If you will do this
