Amstrad CPC 6128/664 (NEW)
slingshot
Re: Amstrad CPC 6128/664 (NEW)
Postby slingshot » Fri Feb 22, 2019 10:15 am
Those are two different cores from two different authors.
Higgy
Postby Higgy » Fri Feb 22, 2019 1:47 pm
Slingshot - are you going to incorporate ManuFerHi tape loading input (from audio sounds)?
seastalker - glad your enjoying Pinball Dreams, hopefully we will get some Youtubers reviewing it soon :D
slingshot
Postby slingshot » Fri Feb 22, 2019 2:09 pm
Higgy wrote:Slingshot - are you going to incorporate ManuFerHi tape loading input (from audio sounds)?
If there's a demand, maybe one day. I cannot test it. In theory you can load from the UART pin right now, just won't have sound.
DanyPPC
Postby DanyPPC » Fri Feb 22, 2019 2:48 pm
But could be possible to have an option to load directly CDT files on menù like on MiSTer ?
slingshot
Postby slingshot » Fri Feb 22, 2019 3:23 pm
DanyPPC wrote:But could be possible to have an option to load directly CDT files on menù like on MiSTer ?
Of course. If you write a TZX/CDT parser in Verilog (on MiSTer, it's done in the ARM CPU).
DanyPPC
Postby DanyPPC » Fri Feb 22, 2019 3:32 pm
Ah, ok. It's not so important, I prefer to load dsk.
It was only a curiosity :wink:
@Slingshot: Could you take away this other doubt?
slingshot
Postby slingshot » Fri Feb 22, 2019 4:11 pm
DanyPPC wrote:Ah, ok. It's not so important, I prefer to load dsk.
I think I already answered that question earlier in that topic.
DanyPPC
Postby DanyPPC » Fri Feb 22, 2019 5:16 pm
Yes, you are right. :wink:
Peg4a
Postby Peg4a » Sun Feb 24, 2019 10:01 am
Hi all ;)
Thanks for this great core.
Can somebody explain me where can I put my amstrad azerty keyboard rom to suit my keyboard ?
I know the rom amstrad.rom is a combined rom how to modify it ?
slingshot
Postby slingshot » Sun Mar 03, 2019 12:35 am
Peg4a wrote:Hi all ;)
https://github.com/sorgelig/Amstrad_MiST#boot-rom
slingshot
Postby slingshot » Wed May 15, 2019 9:00 am
For the masochistic users, who wants to load original tapes, I've added a simple CDT player to the Amstrad core. Tested successfully with some CDTs from cpc-power.com, but it's possible that not all features covered (as TZX format is much more complicated - but the files are smaller - than TAP files for the Commodores).
Until it lands in Sorgelig's repo, you can grab it from https://github.com/gyurco/Amstrad_MiST/ ... 190514.rbf
If there's a CDT which doesn't work, please report.
DanyPPC
Postby DanyPPC » Wed May 15, 2019 11:13 am
Oh thanks, many cdt files have to test :wink:
Lroby74
Postby Lroby74 » Wed May 15, 2019 11:18 am
slingshot wrote:For the masochistic users, who wants to load original tapes, I've added a simple CDT player to the Amstrad core. Tested successfully with some CDTs from cpc-power.com, but it's possible that not all features covered (as TZX format is much more complicated - but the files are smaller - than TAP files for the Commodores).
Thank you!!!
I've tested with success loading of games directly from a real tape via real cassette recorder,
but i will try to load a CDT file too! :D :D :D
DanyPPC
Postby DanyPPC » Thu May 16, 2019 4:22 pm
Tested some cdt files, Arkanoid II doesn't load.
RobeInie
Postby RobeInie » Thu May 16, 2019 9:45 pm
Thank you !!
I am going to test some CDT files.
slingshot
Postby slingshot » Fri May 17, 2019 5:38 am
DanyPPC wrote:Tested some cdt files, Arkanoid II doesn't load.
Check the new release (and hide Multiface).
DanyPPC
Postby DanyPPC » Fri May 17, 2019 6:17 am
Ok, thanks.
DrOG
Postby DrOG » Thu Jul 18, 2019 4:36 am
-deleted-
slingshot
Postby slingshot » Thu Jul 18, 2019 10:45 am
That's not the core which is this topic about.
DrOG
Postby DrOG » Thu Jul 18, 2019 7:08 pm
Sorry, my bad!
Removed the link.
vebxenon
Postby vebxenon » Wed Oct 02, 2019 12:02 pm
Batman Group has relesed the final version of Pinball Dreams, and it works perfectly using this core :D :cheers: ¡Enjoy it!
https://twitter.com/BATMAN_GROUP/status ... 6710730752
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Users browsing this forum: desUBIKado and 6 guests
