Sparrow inspection
thothy
Hatari Developer
Hatari Developer
Re: Sparrow inspection
Postby thothy » Sun May 27, 2018 4:15 pm
mikro wrote:As promised, here's TOS 2.07 dump, for the first time in Atari history. :)
Thanks a lot for that dump! I've now committed some hacks to Hatari, so we can now load this TOS version there, too:
https://hg.tuxfamily.org/mercurialroot/ ... 5da396494b
Greenious
Postby Greenious » Mon May 28, 2018 7:12 pm
czietz wrote:How do you get to bit 3 here???
8007   RW   dvim bs_c
            7654 3210
I'd still say the "bus error" bit i is number 5.
Sorry, brain lapse...
viewtopic.php?t=5040
Jeff_HxC2001
Postby Jeff_HxC2001 » Thu May 31, 2018 7:35 am
mikro wrote:. my HxC started to behave...
How ?
Postby mikro » Thu May 31, 2018 3:52 pm
How ?
No worries Jeff, you helped me to fix it on your forum. I guess you will find the information that your Atari ST Manager runs on the Sparrow flawlessly as interesting. :)
Jeff_HxC2001
Postby Jeff_HxC2001 » Thu May 31, 2018 7:55 pm
mikro wrote:
How ?
ok, just got it :D.
Great news for the HxC+HxC Manager + Sparrow compatibility !
Can you send me a picture of the Sparrow running the manager with the HxC ? (And/or post it on the HxC Facebook group ? :
https://www.facebook.com/groups/hxc2001
Postby mikro » Fri Jun 01, 2018 11:54 am
Apologies for the delayed post. As promised, here is a few photos and information I have gathered so far. I'm going to split it into several posts as AF bullies me about the post size, number of attachments etc.
Let's start with the motheboard:
As you can see, it's a typical Sparrow rev.2 board. Custom ICs are nicely presented here: http://www.old-computers.com/museum/pho ... =635&st=1$
The case is, except its unusual colour, rather standard ST/Falcon one (with connectors matching Falcon 1:1 but the floppy side still has the narrow rounded button form)
Postby mikro » Fri Jun 01, 2018 12:00 pm
Misc motherboard components:
It looks like a younger brother to the (in)famous SR98. Not sure whether this was really the original PSU as the original owner had claimed to be it a 110V machine, what is clearly not. Anyways, as you can see, it's a truly ST/E compatible PSU judging from the connector.
Typical oldschool Epson floppy with the rounded button for which people love so much to butcher their Atari cases. Fortunately, Falcon has received "already cut" case.
There hadn't been much of evolution for the 2.5" bracket. :-)
Postby mikro » Fri Jun 01, 2018 12:01 pm
RAM card looks a bit dated, I think even more than the original one found in Falcon. This is a 14 MB model:
While I was at it, I tested a Falcon RAM card and thankfully, it works without an issue:
Postby mikro » Fri Jun 01, 2018 12:05 pm
The last post for now... Sparrow's imperfections. :)
As there are no holes on the case, the bracket has to be mounted purely by screws. And since the screws are too tall, how do you install them? :)
Not sure how much it's visible but the "teeth" of the PSU had to be cut out because the holes are too far away to fit.
Not only the second hole doesn't match...
... there is even a separate metal for that part! :)
Wiring on the back side:
Postby mikro » Fri Jun 01, 2018 12:11 pm
Did I say the last post? All right, two bonus pictures. The Sparrow running the HxC file manager and (thankfully!!!) Parcp-USB:
This has allowed me to do further (software) testing as until now I had it connected to TV a couple of meters away from my laptop, therefore only the HxC was usable, making loading new software incredibly annoying.
There seems to be an issue with the monitor port / circuitry as I not only can't hear the key clicks but also nothing except RGB works. I could test both mono and VGA, I can hear it boot to desktop but there is no image. What is really strange at least as far as VGA is concerned because the seller clearly tested it on VGA. maybe the wiring around the monitor port has broke somehow. I guess I'll leave it as is for now, I can explore the machine as it is now and focus on fixing stuff later.
stormy
Postby stormy » Fri Jun 01, 2018 12:35 pm
Very interesting. Looks like the DSP is larger than the final version, must be an older higher micron version I am assuming. Also is that a full speed 030 in ceramic packaging? I wonder :) Perhaps you need to run Bootconf to tell it to use VGA as default.
Postby mikro » Fri Jun 01, 2018 12:48 pm
mzry: see my previous posts -- I can't use the standard NVRAM tools as they fail to accept the Sparrow as a NVRAM equipped machine. But yes, it's possible the NVRAM is the culprit here.
calimero
Postby calimero » Fri Jun 01, 2018 7:11 pm
Nice posts :)
Does anyone know timeline of Falcon/Sparow development?
When and how planing starts? When they build prototypes...?
