[ZX Spectrum Core] New Update
slingshot
Re: [ZX Spectrum Core] New Update
Postby slingshot » Mon May 20, 2019 7:48 am
jamesrc wrote:
slingshot continuing to make all my MiST dreams come true. Good god! Do you ever sleep? :D
Ehh, cannot sleep enough :)
DanyPPC
Postby DanyPPC » Mon May 20, 2019 1:39 pm
Willow Pattern Adventure doesn't load. Reset ad end.
It's a 48k game and it loads in BASIC 48.
CSW converted file works.
slingshot
Postby slingshot » Mon May 20, 2019 5:45 pm
DanyPPC wrote:Willow Pattern Adventure doesn't load. Reset ad end.
I've converted the tzx to csw with TZX2WAV, it still resets at the end.
DanyPPC
Postby DanyPPC » Mon May 20, 2019 6:05 pm
I have a CSW converted from another TZX.
Anyway it's not a prolems. It was just for report only.
Thanks for this new function of ZX Spectrum core. :cheers:
slingshot
Postby slingshot » Mon May 20, 2019 6:49 pm
It works in emulators only if I select 48k mode (128 48k mode doesn't work). Seems it's the ROM - needs the original 48K one, but in the core, even the 48K mode uses the ROM1 from the Spectrum 128K.
I've added the original 48k ROM (and some more TZX features):
https://github.com/gyurco/ZX_Spectrum-1 ... 190520.rbf
Forgot to mention: need a new spectrum.rom!
https://github.com/gyurco/ZX_Spectrum-1 ... ectrum.rom
DanyPPC
Postby DanyPPC » Tue May 21, 2019 9:01 am
You are a Genius ! :cheers:
Lroby74
Postby Lroby74 » Tue May 21, 2019 8:42 pm
i have a lot of .TRD files and they won't load.. while .DSK files works fine
slingshot
Postby slingshot » Wed May 22, 2019 8:11 am
I have lot of .TRD files which work.
I guess you are in +3 mode, since using .DSKs. The Beta interface wasn't compatible with the +3, probably most of the software on TRDOS disks also not.
desUBIKado
Postby desUBIKado » Wed Feb 05, 2020 11:22 pm
Hi Slingshot,
I have been dividing the spectrum.rom file into the individual roms that compose it, so that I can replace the Spectrum 48K (16K), 128K (32K) and +3 (64K) roms, as seen in these images:
Would it be possible to add in the OSD of the Spectrum core three new options such as the "Load Kernal * .ROM" of the Commodore 64 core?
This would allow you to change roms without having to edit the mist.ini file, but simply select them from the OSD.
The options could be something like:
  • "Load rom * .16K"
  • "Load rom * .32K"
  • "Load rom * .64K"
And the files with the rom would have as filename extension their size: 16K, 32K and 64K. For example:
SP128.32K ; Spectrum 128 English
BBCBAS.32K ; Emulador de BBC BASIC
SEBAS4.32K ; SE Basic IV Anya
P3EMMC.64K ; ZX Spectrum +3e EN (DivMMC) 1.43
PLUS3.64K ; ZX Spectrum +3 English
DERBYP.64K ; ZX Spectrum 128K Derby++ 64K
PRETTY.16K ; Pretty BASIC 48K (Basic in color)
SP48K.16K ; ZX Spectrum 48K (original rom)
GW133.16K ; ZX Spectrum 48K Gosh Wonderful 1.33
LG107.16K ; ZX Spectrum 48K Looking Glass 1.07
INVES.16K ; INVES Spectrum+
METK95.16K ; Microdigital Eletronica TK95
Do you think it's a good idea?
slingshot
Postby slingshot » Thu Feb 06, 2020 8:13 am
Not impossible, but you should provide the patch (as you addressed the question to me - I won't work on it in the near future). However I wouldn't name the ROMs after their size, but their function. (e.g. .+3, .128, .48 for example).
Chris23235
Postby Chris23235 » Thu Feb 06, 2020 9:44 am
Just curious, as I am not at my MiST at the moment, isn't the specific Rom loaded, whenever a specific machine is selected? What would be the benefits of selecting a Rom manually?
EDIT: Nevermind, I now realise, that it is about the custom Roms in the list.
desUBIKado
Postby desUBIKado » Thu Feb 06, 2020 6:18 pm
slingshot wrote:Not impossible, but you should provide the patch (as you addressed the question to me - I won't work on it in the near future). However I wouldn't name the ROMs after their size, but their function. (e.g. .+3, .128, .48 for example).
I have named you because I thought you were the main maintainer, because I don't have the knowledge to make that modification. I only propose the idea and if someone seems interesting and has the knowledge and time to carry it out, great. For now I have it solved by editing the mist.ini file, but it is more uncomfortable.
Your idea that the filename extensions were .+3, .128, .48 seems right to me.
I hope I have not bothered you.
slingshot
Postby slingshot » Fri Feb 07, 2020 4:13 pm
I think the word "maintainer" means that he makes sure that it won't break, but new things are not necessarily coming from him.
desUBIKado
Postby desUBIKado » Sat Feb 08, 2020 6:01 pm
slingshot wrote:I think the word "maintainer" means that he makes sure that it won't break, but new things are not necessarily coming from him.
OK, I get it.
By the way, I have published a post on this subject (in Spanish) in case someone wants to see it and find it useful
Users browsing this forum: sebdel, squid4 and 4 guests
