USB Hub board
lolof
Re: USB Hub board
Postby lolof » Thu Jul 11, 2019 2:32 pm
I am looking for 2X USB connector for the L shape connector.
Does someone know a source. They are all sold on the aliexpress link :-(
damopinn
Re: USB Hub board
Postby damopinn » Wed Jul 24, 2019 7:59 pm
lolof wrote:I am looking for 2X USB connector for the L shape connector.
https://www.aliexpress.com/item/3280699 ... 3c00APeUBe
lolof
Re: USB Hub board
Postby lolof » Tue Aug 06, 2019 7:51 pm
Just saw the reply.
Ordered...
Thank you very much
sofakng
Re: USB Hub board
Postby sofakng » Mon Sep 23, 2019 2:17 pm
Does anybody know if the components listed for the USB Hub v1.0 on the wiki are the same for the latest v2.1 revision?
I'm also receiving my JLCPCBs today with a bunch of mister PCBs but I forgot to order a USB bracket PCB. Doh!!
EDIT: Ok, I've trying to figure out how to view the PCB and I've installed Altium Designer Viewer and I'm looking at the generated BOM. It looks like it includes two "power distribution switches"? U2a and U2b?
Re: USB Hub board
Postby Sorgelig » Mon Sep 23, 2019 3:28 pm
You don't need Altium designer. PDF file contains schematics, notes and PCB view - everything you need.
RealLarry
Re: USB Hub board
Postby RealLarry » Thu Nov 14, 2019 5:10 pm
Is it possible to use a USB soundcard or -bar? I'm using a Dell USB soundbar on MiSTer's USB hub board, but it's working there only if I'm using the USB cable plus 3.5mm stereo jack.
The Dell soundbar is capable acting as a USB only soundcard as I'm having more than one of the same type, which are working quite well with Kodi on other setups.
Re: USB Hub board
Postby Sorgelig » Fri Nov 15, 2019 6:00 am
RealLarry wrote:Is it possible to use a USB soundcard or -bar?
no
RealLarry
Re: USB Hub board
Postby RealLarry » Fri Nov 15, 2019 6:10 am
no
Thanks, but just to satisfy my curiosity: Why not? Missing kernel modules which would fill up space/memory unnecessarily?
Well, I continue to use this setup with extra audio cable then. This is working fine and gives me a nice sound for my MiSTer-in-a-case ... and can be controlled by alsamixer and soundbar's volume control by setting volumectl to 1.
warham
Re: USB Hub board
Postby warham » Fri Nov 15, 2019 7:14 am
RealLarry wrote:
no
what options do you get in alsamixer besides master volume?
Re: USB Hub board
Postby Sorgelig » Fri Nov 15, 2019 7:19 am
RealLarry wrote: Why not? Missing kernel modules which would fill up space/memory unnecessarily?
Because audio path in FPGA has no connection to Linux.
RealLarry
Re: USB Hub board
Postby RealLarry » Fri Nov 15, 2019 7:21 am
warham wrote:what options do you get in alsamixer besides master volume?
I change the sound device by hitting F6 but getting only PCM there.
RealLarry
Re: USB Hub board
Postby RealLarry » Fri Nov 15, 2019 7:22 am
Ah, I see, thanks for clarification!
Billdr
Re: USB Hub board
Postby Billdr » Fri Dec 06, 2019 7:32 am
Sorgelig wrote:You don't need Altium designer. PDF file contains schematics, notes and PCB view - everything you need.
I've been looking around, I can't find this PDF, even after skimming the thread. Maybe I missed it?
Edit: I'm dense. Of course it's in the root directory of the hardware github.
Side note, JCSC was out of NCP380LSNAJAAT1G so I got NCP380HSNAJAAT1G; it seems to be the same component fabed somewhere else. But it was half the price. This is my first attempt at something like this. I'd feel better if someone could confirm these are compatible. The data sheets look the same to me.
Re: USB Hub board
Postby Sorgelig » Fri Dec 06, 2019 10:59 am
Billdr wrote:Side note, JCSC was out of NCP380LSNAJAAT1G so I got NCP380HSNAJAAT1G; it seems to be the same component fabed somewhere else. But it was half the price. This is my first attempt at something like this. I'd feel better if someone could confirm these are compatible. The data sheets look the same to me.
They are not compatible as they react opposite to control signal. High active vs Low active.
Billdr
Re: USB Hub board
Postby Billdr » Fri Dec 06, 2019 5:41 pm
Drats, thanks. Digi-Key has it in case someone else peeks in asking about it.
Heppaz
Re: USB Hub board
Postby Heppaz » Fri Dec 06, 2019 8:44 pm
I have built a couple of the new 2.1 boards and get no joy, all soldering looks good and checks out with no shorts on the FE 2.1.
I am not using the protection have only shorted JP1, is there anything I am missing here?
The Power LED flashes when I power on and then nothing from the init.
Re: USB Hub board
Postby Sorgelig » Fri Dec 06, 2019 9:25 pm
it should work without any additional tweaks.
Power LED will be ON if at least one USB device is connected. And of course USB hub has to be connected to de10.
Heppaz
Re: USB Hub board
Postby Heppaz » Fri Dec 06, 2019 9:26 pm
Sorgelig wrote:it should work without any additional tweaks.
I have a device connected and connected to DE10 correctly.
I dont seem to have 12mhz on the crystal though does this activate after initilaising?
Re: USB Hub board
Postby Sorgelig » Fri Dec 06, 2019 9:48 pm
Heppaz wrote:I dont seem to have 12mhz on the crystal though does this activate after initilaising?
i don't know. I never explored it.
Heppaz
Re: USB Hub board
Postby Heppaz » Sun Dec 08, 2019 10:55 pm
I found the problem, the PSU wasn't powerful enough the power the DE-10 and the USB board.
Doh.
Re: USB Hub board
Postby Newsdee » Tue Dec 10, 2019 5:06 am
Heppaz wrote:I found the problem, the PSU wasn't powerful enough the power the DE-10 and the USB board.
Doh.
What amperage was your old PSU?
Heppaz
Re: USB Hub board
Postby Heppaz » Thu Dec 12, 2019 9:22 pm
Doh.
My DE10 came with an American plug so I tend to use random 5V adapters, most are 2A but I seemed to have used a 500mA. Problem solved with a 2A supply.
MysteryM
Re: USB Hub board
Postby MysteryM » Fri Dec 13, 2019 11:38 am
I'm new to electronics so don't want to risk trying to deduce a parts list for the usb hub. Does anyone have a BOM list handy with links to the components?
MysteryM
Re: USB Hub board
Postby MysteryM » Thu Dec 19, 2019 3:38 pm
MysteryM wrote:I'm new to electronics so don't want to risk trying to deduce a parts list for the usb hub. Does anyone have a BOM list handy with links to the components?
Okay so I've done some homework and spent an hour or so looking at the schematic, and have a list of most of the components that I need to order. I did have one question however, what sizes are resistors R4 to R11? the schematic indicates that they should 510, can I assume that I've read it right and they are 510 ohm resistors?
I've ordered my pcbs already and am just ordering the components now, some of them have already arrived.
Nat
Re: USB Hub board
Postby Nat » Thu Dec 19, 2019 11:05 pm
Yes that is correct, they are 510 Ohm resistors, package size is 0805.
Users browsing this forum: elfbutt and 11 guests
