Disk Repair Tools ST
Moderators: DrCoolZic, Brume
Cogweasel
Re: Disk Repair Tools ST
Postby Cogweasel » Wed Feb 21, 2018 10:45 am
Cogweasel wrote:
charles wrote:nope just one floppy , it transfers to pc ,
Ok, I know its a PC app, but I got the impression that you needed two floppy drives on your PC to get this to work, according to the text file. A bit confusing that text file, but still doubtful it will work since the FAT probably wont be readable :(
dlfrsilver
Postby dlfrsilver » Mon Mar 26, 2018 5:16 pm
Well either the disk is dead, or it simply has some mould on disk surface, and no tools will be able to process that. One solution is to open the disk in half, check for mould traces on the surface, and use 70% alcohol with extremely soft demak up cotoon for women to gently remove the poo, and then image the disk.
However, if you see vinyle disk like "furrow", the disk mostly can't be repaired.
charles
Postby charles » Mon Mar 26, 2018 9:53 pm
hey that's my trick dlsilver
my other trick is ,
taking the disk apart and using a nice new floppy disk shell
place the old disk inside it ,
this seems to make spin correctily at r.p,m,
as old disks kind warp
The radioactive half-life : )
rcamp48
Postby rcamp48 » Thu Oct 25, 2018 2:50 am
Has anyone tried ST Recover, by the way I am getting rid of my old XP machine for an even older machine that will support both 3.5 and 5.25 disks, I already have the 5.25 inch floppy drive and cable i works but my Bios does not support it. Russ
Now supporting Atari Portfolio , my archives are still being maintained.
BBS is now up again as an Atari BBS, run on PC, cause I sold everything but my Atari Portfolio.
Note: Atari Portfolio IDE CF kits are being made. Get yours today! :megaphone:
Spy Visits Spy BBS is back online at spyvisitsspybbs.com telnet port 1989 web port 1990 :megaphone:
Note the Port number changes !!!!!!!!!!!!!!!!!
RetroMan
Postby RetroMan » Sat Dec 01, 2018 9:38 pm
I agree with those who say that best way of repairing is careful cleaning of floppy disk surface.
Repair SW can fix some errors, but not for instance wore magnetic layer.
MiggyMog
Postby MiggyMog » Thu Feb 28, 2019 11:18 pm
I used to sometimes use f-copy pro to copy a disk to another to fix errors , you can change the step rate to a slower one set retries etc, occasionally this seemed to help. It may also be worth trying a different drive as you may get lucky.
