Temperatures / CT60 Instability
piku
Re: Temperatures / CT60 Instability
Postby piku » Wed Jan 31, 2018 5:23 am
The plot thickens. It's a thing bug i was triggering. This is aranym...
https://www.youtube.com/watch?v=His4lq3 ... e=youtu.be
Just double click that disabled button with memory protection and poof.
I think ace tracker module playing could have been the cause of many issues. Kernel 1.17.0 with aniplay is so far rock solid at 92MHz. Even Jinnee is running. I maybe had a stable system before but I was using the thing bug as a stability indicator.
Latz
Postby Latz » Wed Jan 31, 2018 3:04 pm
mikro wrote:What you can do is to pray that the ship with my Atari stuff wont sink. ;-)
I will!!
In fact i could not sleep well with the knowledge that my Falcons were
...alone...in the dark...somewhere on the ocean... :cry:
I cross my fingers for you that it all goes well. Perhaps use a military steel box for shipping, water resistant, highly shock absorbing
with gel or air cushions, 3 times sealed...and don´t forget some bodyguards, watchdogs, GPS sender, ... :wink:
Latz
Falcon/CT60 90MHz, 14+128 MB RAM, CTPCI/Radeon 9250/RTL8139, Carte Eiffel+LCD, 80GB IDE HD, DVD-RW.
Postby mikro » Wed Jan 31, 2018 10:55 pm
Latz wrote:Perhaps use a military steel box for shipping, water resistant, highly shock absorbing with gel or air cushions, 3 times sealed...and don´t forget some bodyguards, watchdogs, GPS sender, ...
I would have certainly reconsidered it if I hadn't shipped all the stuff three months ago already. ;) In fact, I should hear from the company sometime this month, I guess I'm going to give them a call. It's a complex delivery, Brisbane -> (truck) -> Sydney -> (ship) -> Poland -> (truck) -> Slovakia. But hey, way cheaper than air mail. :) My biggest worry is the box, while it isn't a cardboard box, I still couldn't afford to ship something like a wooden/metal crate because of weight (30 kg limit per box).
piku
Postby piku » Thu Feb 01, 2018 1:32 am
Very interesting. I have confirmed that 1.17.0 is absolutely stable for me and all 1.19 variants I have on my machine are absolutely UNSTABLE. Does anyone have a recommended known stable latest release kernel? I plan to use this machine to develop and build parts of RPMint which is my latest project so it might be best to leave it in the stable condition it's in.
Postby wongck » Thu Feb 01, 2018 6:35 am
Yeah, read about your new project on mintlist. Great move. :)
I have an autoupdate script, at my web site, using Sparemint RPM as a base for version checking.
I need to update the script to check github now before it works again.
I guess you should use the most stable mint release that works best for you.
Any reason why you need v1,19 ?
My guess is that you mainly just need a shell & gcc, no need for GUI.
Postby joska » Thu Feb 01, 2018 12:59 pm
piku wrote:I have confirmed that 1.17.0 is absolutely stable for me and all 1.19 variants I have on my machine are absolutely UNSTABLE.
I'm using 1.19 on my Falcon/CT60e and have no issues. I'm using a Hydra (ethernec clone) for networking and the Assemsoft driver.
I'm using VanillaMiNT on mine, have you tried that?
Edit: Ok, just noticed that you're using a CTPCI. Are you using a graphics card? I've not heard many good things about CT-TOS-versions with CTPCI-support.
piku
Postby piku » Thu Feb 01, 2018 3:49 pm
Yeah I think the key factor is probably the CTPCI. But I am also using the apparently somewhat rare Ethernat as well. I'm happy to have a good config as it's not like I'm a kernel developer or anything. Now I want to look into replacing NVDI with FVDI which has font smoothing. NVDI fonts on high resolution don't look great at all.
piku
Postby piku » Sat May 05, 2018 3:08 pm
I've figured out that the instability only happens when the ethernat driver is loaded. The question is what do I do? Maybe my ethernat is failing? Maybe ethernat + ctpci is unstable. The switch on the ctpci (bus termination I think) doesn't seem to make a difference. I can force a crash while xcontrol is loading and I move the mouse (memory violation).
EDIT: Nevermind got it to do it without the driver. It just seems less common. Definitely something to do with interrupts.
piku
Postby piku » Sat May 05, 2018 11:27 pm
Does anyone have any actual success using memory protection on a CT60/CTPCI falcon with a modern kernel?
Postby wongck » Sun May 06, 2018 1:57 am
I use mine in non-protected mode. It 's very stable.
Latz
Postby Latz » Sun May 06, 2018 8:07 am
1-19 is working very stable here too, memory protection on or off.
Latz
mzry
Postby mzry » Thu Aug 23, 2018 5:53 am
Make sure you are not just replacing the kernel prg, but have proper installs as I understand the kernal modules, drivers and xaaes needs to be the correct versions too.
Falcon ct60e 060 - 256mb ram - phantom bus and dsp accel // Atari TT - Thunder and Storm IDE 64mb ram - Lightning VME - USB LAN - Ati Mach64 2mb // Atari STM 4160 - 4MB ram - 16Mhz exxos 1.5 booster - Ultrasatan
Return to “CT60 / CT63 Area”
