ericgus
Postby ericgus » Tue Feb 19, 2019 6:49 am
kolla wrote:@ericgus
And I have two V2 cards. They always offer what is described...ish. But what's described may of course change at Gunnar's whim.
True but so far, when it has, its change has always been for the better.. worse case, just stick with a prior core release that best suits you.
fpgaarcade
Postby fpgaarcade » Tue Feb 19, 2019 6:54 am
I've isolated the M68K problem in 68000 mode, I hope to get time to fix it this week (but I have a lot on with work).
Writing a high speed CPU is a lot more complex than just executing instructions in a single cycle. The TG68k/M68K execute the majority of instructions in a single cycle already, or the minimum number of cycles with external fetches. With a good cache you get very decent performance.
There are very long combinatorial paths which currently require some back-edge clocking and synthesis/layout constraints to get 28MHz in my design, although it runs a bit faster in the CycloneV and much faster in the Ultrascale. To take it further you have to use techniques they use in real processor designs and have a fetch/decode/execution pipeline and handle the dependencies between these stages. The Apollo core is twin superscaler - the same as the 060 in that it has two execution pipes. I'm looking at the dispatcher in the real 060 and we'll try to model that behaviour, there is good documentation on the allowed instruction pairings.
The 68000 ISA is not designed to make this easy, unlike the RISC-V ISA for example, but it's possible.
We've been modelling the entire 68040/60 instruction set and built a decode table which tells me early on the complete instruction size (with some additional brief decoding). This lets me shift and fetch from the cache the next instruction while decoding the current one. This is one of the most critical timing paths I've found so far and decouples fetch and decode.
/MikeJ
Postby ijor » Wed Feb 27, 2019 2:26 am
fpgaarcade wrote:
ijor wrote:
fpgaarcade wrote:I put the FX68K core into my Amiga design and it works well, although there are some glitches we don't see with the M68K.
I think it's showing up some very subtle chipset issues, but when I get time I'll run with a real 68000 (I have one on a DB) and compare the two.
/Mike
Hi Mike.
No idea if it is related, but a bug that affected BCD instructions was recently fixed. Please update to the new version: https://github.com/ijor/fx68k
ah cool, will do ! Thanks.
Another bug fix was just released. This one affected the ROXR instruction. Please update again :)
beatchef
Postby beatchef » Wed Feb 27, 2019 9:35 am
The readme for Minimig-AGA_MiSTer on GitHub mentions the download page being http://somuch.guru/minimig/minimig-mist/ which I went to and was slightly confused about but put the file on my Mister and of course the core crashed. I did work out that I should go into https://github.com/MiSTer-devel/Minimig ... r/releases and download the latest file there eventually :lol: I love it, thank you so much
high5
Postby high5 » Sat Mar 09, 2019 11:04 pm
as there have been discussions on how to transfer files from/to MiSTer-minimig I thought I would share the way it's working out for me.
I am using .hdf files on MiSTer, my desktop is running Windows. Using SFTP Net Drive (free) to mount MiSTer filesystem as a network drive in Windows I can attach the hdfs to Winuae and do my changes there and enjoy them directly on MiSTer. No trouble so far.
https://www.nsoftware.com/sftp/netdrive/
BlockABoots
Postby BlockABoots » Sat Apr 06, 2019 3:13 pm
So have posted an issue ive had with the screen size on the Miniming core a few times and each time its been suggested to use the screen adjust option in the core options to make the screen fit the height of my TV screen but ive never been able to get the screen to move down further than about just over half way down the screen. When i try and move the screen down all it does is bring the top of the screen down (so it squishes the image) and not actually move the screen down at all.
Ive posted a video showing the issue (please excuses the audio not sure what happened)......
https://www.youtube.com/watch?v=S8P6RbL ... e=youtu.be
So is there a way to get the screen to move down further so the game screen fills on the vertical axis or am i missing something??
mahen
Postby mahen » Sat Apr 06, 2019 3:32 pm
BTW, just wondering, is there somewhere an experimental build of the Minimig core with the TG68 replaced by some other 68k implementation, as I heard there are 2 or 3 of them being worked on ? :-)
Postby Sorgelig » Sat Apr 06, 2019 6:55 pm
BlockABoots wrote:Ive posted a video showing the issue (please excuses the audio not sure what happened)......
what's the game?
From the video it's unclear do you use HDMI or VGA output. Screen position adjustment affects only HDMI output. On VGA you will get only wider or narrower blanking without changing the position/size.
Postby Sorgelig » Sat Apr 06, 2019 6:59 pm
mahen wrote:BTW, just wondering, is there somewhere an experimental build of the Minimig core with the TG68 replaced by some other 68k implementation, as I heard there are 2 or 3 of them being worked on ? :-)
Currently there is only one open source alternative 68K implementation - it's FX68K. It doesn't support 68020 mode, so it's not suitable for Minimig.
breiztiger
Postby breiztiger » Sat Apr 06, 2019 7:25 pm
But amiga 500, 600 and 2000 only have 68000 :cheers:
Most games works with this computers and ks 1.3
A a500 core with cycle exact cpu should be good, perhaps a600 with ecs and ide also
BlockABoots
Postby BlockABoots » Sat Apr 06, 2019 8:04 pm
what's the game?
The game is Shadow Of The Beast, im using HDMI.
When i go to the adjust display optin in the Minimig core, if i keep pressing down of the controller the screen squashes down from the top (so its kind of making the screen widescreen), it doesnt move the screen down at all
albconde
Postby albconde » Sat Apr 06, 2019 9:27 pm
BlockABoots wrote:When i go to the adjust display optin in the Minimig core, if i keep pressing down of the controller the screen squashes down from the top (so its kind of making the screen widescreen), it doesnt move the screen down at all
Test with "alt" + "down" to increase the size of the image in the down part
with only up or down you only move the position of the upper side of the image , with alt + up or down you move the botton .
Similar with left and right
z00pster
Postby z00pster » Sat Apr 06, 2019 10:33 pm
I'm interested if anyone has had much luck using the Minimig core with Workbench 3.1.4 and the 3.1.4 rom? I can get the vanilla install to work but when I installed BestWB (http://lilliput.amiga-projects.net/BestWB.htm) I'm getting this error "ramlib program failed 800004". It's set up as a maxed out A1200 system.
John
knc
Postby knc » Sat Apr 06, 2019 11:22 pm
z00pster wrote:Hi,
John
yeah i am using 3.1.4 on mister with BestWB i can not remember if it was the same error i had after first running it on mister
but after editing the startup-sequence all was fine
BlockABoots
Postby BlockABoots » Sat Apr 06, 2019 11:38 pm
Thanks, ill give that a go
z00pster
Postby z00pster » Sun Apr 07, 2019 6:58 am
knc wrote:yeah i am using 3.1.4 on mister with BestWB i can not remember if it was the same error i had after first running it on mister
Great that you worked it out. Would you mind sharing the startup-sequence edit? PM me directly if that is easier. I'm also going to try another optional add on from EAB forum. It wouldn't be Amiga without startup-sequence edits! ;)
z00pster
Postby z00pster » Sun Apr 07, 2019 8:29 am
So it turned out to be the 68020.libs used by BestWB, so renaming that so it wasn't used got everything working. For anyone interested there is good add-on pack that can be used on a plain Workbench 3.1.4 installation here: http://eab.abime.net/showthread.php?t=94493&page=10
z00pster
Postby z00pster » Sun Apr 07, 2019 8:43 am
Anybody having problem with mouse double clicking on Workbench? I'm wondering if it might be my USB hub as I've seen the same problem in the Mac and ST cores. Tried three different mouses - two wired and one bluetooth - without any luck.
mahen
Postby mahen » Sun Apr 07, 2019 9:49 am
Ah, I must have overlooked some important bits of information, my bad.
I thought JimDrew referred to one (not public yet) and there was some ambiguous statement regarding a M68K implementation. Some people on the thread didn't know if it referred to a real chip or a re-implementation. I'm pretty sure someone mentioned a slightly modified TG68 with some fixes. Mike ?
Anyway, back to dumb user lurking mode :-) Sorry for the stupid questions ;)
laserdisc
Postby laserdisc » Mon Apr 08, 2019 12:12 am
z00pster wrote:Anybody having problem with mouse double clicking on Workbench? I'm wondering if it might be my USB hub as I've seen the same problem in the Mac and ST cores. Tried three different mouses - two wired and one bluetooth - without any luck.
I'm having this issue after updating the linux + main_mister (MiSTer_20190406), reverting to back to MiSTer_20190404 did the trick and now it's working normally again.
z00pster
Postby z00pster » Mon Apr 08, 2019 10:15 am
Looks like the release today fixes a mouse issue so I'll wager it fixes the problem. Will test tonight.
troydm
Postby troydm » Mon Apr 08, 2019 12:02 pm
Few games unfortunately aren't working or crash in a weird way corrupting hard drive (in WHDLoad case), for example Desert Strike (tried both WHDLoad and adf images, game crashes after title screen when starting campaign). I've managed to corrupt my hard drive twice, one time extracting zip archive via xad and another time starting a WHDLoad game (called Epic). Not sure over how this happened but workbench restarted and hdd was giving tons of header checksum errors, had to reformat it.
Also I've configured internet and ftp server inside Workbench 3.1 using AmiTCP-bin-30b2.lha, AmiPPP122u.lha, New8n1.lha and wu-ftpd-37.21.lha from aminet. Not perfect but works okey allowing to upload files directly via ftp client over network into the Amiga workbench with 10kb/s speed. If anyone is interested I could write a guide on how to do it
jemismyname
minimg amiga image
Postby jemismyname » Tue Apr 09, 2019 12:40 am
hi, I am trying to get started with using amiga on the MISTer (i have never used amiga, but i have MISTer+SDRAM setup and working). I also have a kickstart rom v3.1... it comes with 2 different files...
"Kickstart - ROM0 (USA, Europe) (v3.1 Rev 40.068) (A3000).rom"
"Kickstart - ROM1 (USA, Europe) (v3.1 Rev 40.068) (A3000).rom"
the wiki says to rename the kickstart rom to "KICK.ROM"
but which one? does it matter? what is the difference?
can someone tell me about a good newb setup for amiga? Or a good explanation of this? I think i also need a hard disk image?
I'd like to run a full desktop environment, but i also just want to play games...
thanks
BBond007
Re: minimg amiga image
Postby BBond007 » Tue Apr 09, 2019 2:09 am
jemismyname wrote:hi, I am trying to get started with using amiga on the MISTer (i have never used amiga, but i have MISTer+SDRAM setup and working). I also have a kickstart rom v3.1... it comes with 2 different files...
If those two 3.1 ROMS are only 256K in size then it is likely that those are dumps of the (two) actual ROM chips for an A3000 - like you would use if you were going to use an EEPROM burner to make physical ROMs to install into a real Amiga 3000.
jemismyname wrote:but which one? does it matter? what is the difference?
If what I suspect is correct, you would need to combine them into a single 512k file.
Even if you did that, it is possible that A3000 ROMs don't contain the correct "scsi.device" for the Gayle's IDE controller. I'm not sure about that - still, I would suggest finding a (512k) Kickstart ROM for the A1200.
jemismyname wrote:I'd like to run a full desktop environment, but i also just want to play games...
If you intend on playing games using the 3.1 Kickstart ROM then you will also want the full desktop environment (installed on a HD image) so that you can run games converted to the whdload format - many ADF (disk based) games are only compatible with the 1.3 ROM unless run from the HD with whdload.
http://whdload.de/
Hope that helps.
troydm
Postby troydm » Tue Apr 09, 2019 12:13 pm
You can use same kickstarts that FS-UAE is using:
https://fs-uae.net/docs/kickstarts
Before trying to configure/install Workbench 3.1 on Mister I highly suggest you trying to do in FS-UAE just to get hang of it, because some essential knowledge is required about using Amiga. Just follow their documentation:
Also good guide about installing Workbench 3.1:
http://guide.abime.net/home3.htm
And superb customization guide after you've installed Workbench 3.1:
https://devtty.io/2018/07/computing/how ... kbench-os/
Users browsing this forum: DrGnadz, nightshadowpt and 8 guests
