Cannot save Cubasefiles
jojje67
Postby jojje67 » Mon Nov 06, 2017 6:38 pm
When saving Cubase files nothing happens. Anyone using Cubase (2 or 3) with CosmosEx and got this working?
dbsys
Re: Cannot save Cubasefiles
Postby dbsys » Mon Nov 06, 2017 8:41 pm
jojje67 wrote:When saving Cubase files nothing happens. Anyone using Cubase (2 or 3) with CosmosEx and got this working?
Can you give more details, please?
Which computer? Which TOS? ACSI? SCSI? Where are you trying to save to, USB stick or SD card? Which kind of files are you trying to save? Thanks.
Atarieterno
Postby Atarieterno » Mon Nov 06, 2017 9:22 pm
Save to PC folder shared?
Which driver and format for SD or Pendrive?
Cubase and CosmosEx work fine, perfect.
jojje67
Postby jojje67 » Mon Nov 06, 2017 9:44 pm
Atarieterno wrote:Save to PC folder shared?
1040 STe, 4MB, TOS 1.06
Saving to PC shared drive (can create folders and files from TOS or other programs)
Even tried saven to USB-stick.
Cubase does not complain but nothing is written.
jojje67
Postby jojje67 » Mon Nov 06, 2017 9:46 pm
I have no clue how to use the SD-card. But I tried both Shared drive and USB-stick.
Atarieterno
Postby Atarieterno » Tue Nov 07, 2017 1:20 am
Try these things:
- Peter Putnik's drivers or HD Driver work very well.
- Install the CacheXX and FolderXX patches for your STe.
jojje67
Postby jojje67 » Tue Nov 07, 2017 6:53 am
Atarieterno wrote:Try these things:
Where do I found all those files?
Atarieterno
Postby Atarieterno » Tue Nov 07, 2017 12:07 pm
The patches:
http://www.avtandil.narod.ru/tose.html
The drivers are creations of two good Atarians and you can buy the one you prefer; I think that both authors participate in this forum and one of them is "Atarizoll".
Here you have their respective pages:
http://atari.8bitchip.info/pphdr.php
http://hddriver.seimet.de/en/
I hope that your STe does not have the so-called "bad DMA". Then we would try something else ...
jojje67
Postby jojje67 » Tue Nov 07, 2017 5:36 pm
Atarieterno wrote:The patches:
But as I understand, hddriver is only needed if I gonna use the SD-card?
Now I just need CosmosEx to mount... it has some problems...
Atarieterno
Postby Atarieterno » Tue Nov 07, 2017 7:02 pm
You have also mentioned the use of Pendrive.
I guess you have the CosmosEx with the latest update.
jojje67
Postby jojje67 » Tue Nov 07, 2017 8:11 pm
When I ran folder100.prg did it complain about it didn't find /auto/foldrnnn.prg
jojje67
Postby jojje67 » Tue Nov 07, 2017 8:12 pm
Atarieterno wrote:You have also mentioned the use of Pendrive.
Yes... I use the latest update.
Atarieterno
Postby Atarieterno » Tue Nov 07, 2017 10:01 pm
Do not have problems copying or moving files and folders?
Are the data corrupted?
jojje67
Postby jojje67 » Wed Nov 08, 2017 9:46 pm
Atarieterno wrote:Do not have problems copying or moving files and folders?
I have no problem reading or writing data outside Cubase. Can copy or move without any problems.
edingacic
Postby edingacic » Wed Nov 08, 2017 10:18 pm
maybe you are not saving it right try saving .all format?
Atarieterno
Postby Atarieterno » Thu Nov 09, 2017 3:07 pm
It's very strange what happens to you, I use CosmosEx with Cubase and I have no problem.
Do you use an original Cubase?
Do you use the cracked version 2.01 MCA?
Do you use any 3.xx cracked version, that are all unstable?
edingacic
Postby edingacic » Thu Nov 09, 2017 8:44 pm
you have to make arrange window active when you save
Return to “CosmosEx”
