Sinclair QL
Sinclair QL
Postby Sorgelig » Tue Oct 31, 2017 12:17 pm
This core is supposed to support secondary SD card, but i cannot test it. There is no much original info about QL-SD i could find. It's unknown what exact FAT format is required. Also i couldn't find original QL-SD ROM dump. The only QL-SD ROM exist is one from MiST version. From my experience with MiST cores requiring direct SPI SD access, most of them has special re-work where SD card initialization procedure is stripped out. So, there is a chance that QL-SD ROM from MiST version also modified this way.
So, i'm looking for original QL-SD ROM(or confirmation that MiST version of ROM is original) and someone who can help me to test it.
May be someone already used this core on MiST and knows how to prepare and use SD card (i even couldn't make SD work inside this core on MiST).
alexh
Re: Sinclair QL
Postby alexh » Tue Oct 31, 2017 1:05 pm
I'm not a QL user but my Google-Fu is strong.
Here is a developer page with downloads including the manual, hardware and software sources (The software source includes a manual on how to re-build the ROM)
http://www.dilwyn.me.uk/qlsd/
The current developer of QL-SD, Paul Veltjens, seems still active, his last post on the QL forums was 1 month ago.
http://qlforum.co.uk/search.php?author_id=772&sr=posts
It seems he is still making and selling them here :
https://www.sellmyretro.com/offer/detai ... or-QL-3703
Gehstock
Re: Sinclair QL
Postby Gehstock » Tue Oct 31, 2017 1:16 pm
Edit: to late
alexh
Re: Sinclair QL
Postby alexh » Tue Oct 31, 2017 1:20 pm
This webpage seems to provide something called QLE which was built to support the original MiST
http://sinclairql.net/repository.html
http://sinclairql.net/downloads/THE_DIS ... e_MIST.ZIP
Re: Sinclair QL
Postby Sorgelig » Tue Oct 31, 2017 1:22 pm
alexh wrote:I'm not a QL user but my Google-Fu is strong.
not so strong because you didn't find anything i don't know already. And none of these links have QL-SD ROM.
I have sources, but it's supposed to be built on QL. It requires a lot of time to find all required apps for QL and then the way to transfer sources from PC to QL... It's probably easy when you are familiar with QL, but i'm not.
What i'm actually asking is original QL-SD ROM.
Re: Sinclair QL
Postby Sorgelig » Tue Oct 31, 2017 1:26 pm
alexh wrote:http://sinclairql.net/downloads/THE_DISTRIBUTION_qle_MIST.ZIP
this is for MiST! As i've wrote above, there is a chance that MiST version of ROM is specially tweaked exactly for MiST way of work with SD card.
alexh
Re: Sinclair QL
Postby alexh » Tue Oct 31, 2017 5:46 pm
I appreciate all the hard work you do. Really do. Had you put what you had already found in your initial post then I wouldn't have posted it or I may have looked harder for you.
I am sorry I was not able to find the ROM. It's not something that anyone other than the person who makes the QL-SD really needs. As I mentioned he would be the best place to get the ROM from.
The QL emulators do not appear to emulate the QL-SD hardware and so don't require the ROM. Instead they seem able to use QL-SD images because they have parts of the same software which is in the ROM (i.e. the file system) compiled into the emulator (e.g. https://github.com/SinclairQL/uqlx-fork)
Maybe a good QL enthusiast can rebuild the ROM for you now they know where the sources are.
Sorgelig wrote:this is for MiST! As i've wrote above, there is a chance that MiST version of ROM is specially tweaked exactly for MiST way of work with SD card.
I KNOW ;) I posted it on the chance you may not know about it and WHEN you are able to get QL-SD compatibility in MiSTer you'd have something to try.
Re: Sinclair QL
Postby Sorgelig » Wed Nov 01, 2017 1:17 am
Did anyone use QL-SD on MiST?
Re: Sinclair QL
Postby Sorgelig » Wed Nov 01, 2017 1:59 am
May be it's better to leave the core as-is. It seems no much QL fans are around.
If someone is willing to help with adding SD card support, then let me know.
danielb
Re: Sinclair QL
Postby danielb » Wed Nov 01, 2017 5:55 am
Sorgelig wrote:Did anyone use QL-SD on MiST?
I have the QL-SD working on Mist.
It appears to work very nicely.
D.
alexh
Re: Sinclair QL
Postby alexh » Wed Nov 01, 2017 7:59 am
Sorgelig wrote:none of these links have QL-SD ROM.
http://www.dilwyn.me.uk/qlsd/qlsd-drv_release.zip
I think this file was zipped with an unusual version of ZIP because the directory names have been suffixed to the file names. Anyhow there is a file called "sdcard_SDCARD_BIN_exe" I *think* this is the output file from a make (i.e. the ROM)
I'm pretty sure that this is a QL-SD ROM.
It's not the same as the one in the MiST package which contains very similar strings but is dated 2011 (this one is dated 2014)
Re: Sinclair QL
Postby Sorgelig » Wed Nov 01, 2017 9:27 am
i know about "sdcard_SDCARD_BIN_exe" and already looked inside long time ago.. unfortunately it's not ready for ROM integration. If you will look at beginning of last 16KB of MiST version, you will see it has loader inside. This exe has no loader at beginning. So, it doesn't look like ROM ready, but binary which probably intended to run from OS/Basic.
alexh
Re: Sinclair QL
Postby alexh » Wed Nov 01, 2017 10:40 am
The corresponding "_map" file (which I took as being the log file during the last build) says "SDCARD_QLROMEXT" which (from the QL-SD-BUILD.pdf) I took as being a build for a QL-SD ROM.
Sorry it is not what you're looking for.
Jungsi
Re: Sinclair QL
Postby Jungsi » Wed Nov 01, 2017 12:21 pm
I've asked over at the QL-Forum:
http://www.qlforum.co.uk/viewtopic.php? ... &start=100
Here is the statement:
The QL-SD ROM that comes with the MiST core is the original one. It is the very same thing that is built into the original
Atari: 1040 ST/STFM/STE, Mega STE, Falcon, TT - GigaFile, SuperSatan, Ultrasatan, EtherNEC, NetUSBee, Unicorn, CosmosEx
Sinclair: ZX81, 48k, +48k, 128k,+2, +3, QL - DivIDE+, DivIde 2k11, Interface 1, Microdrive, Interface 2, Spectranet, Datel+D, Interface 1bis, ZXpand
http://www.jungsi.de
Re: Sinclair QL
Postby Sorgelig » Wed Nov 01, 2017 12:35 pm
Jungsi wrote:I've asked over at the QL-Forum:
thanks! One unknown factor less.
Then i will play with MiST version to make a working SD card.
mfro
Re: Sinclair QL
Postby mfro » Wed Nov 01, 2017 4:14 pm
alexh wrote:I think this file was zipped with an unusual version of ZIP because the directory names have been suffixed to the file names.
That's pretty normal (for QL archives) as this is basically how QDOS (the QL operating system) handles "directories". "dirname_filename", max. 36 characters.
desin24
Re: Sinclair QL
Postby desin24 » Thu Dec 14, 2017 11:28 pm
thanks for your hard work Sorgelig
i have troubles accessing the QL_BDI.bin file
so is it supported (yet ) ?
where sholud it be in the root or in QL subdir
what name should it have (the core is looking for boot.vhd file )
thanks in advance
Markus
desin24
Re: Sinclair QL
Postby desin24 » Wed Feb 21, 2018 9:24 am
with the I/O board i was finally able to test the QL
with the second SD Card
it works only if CPU speed =normal
there is a new driver called SDQL that uses QXL.win files
the most common file container for nearly all QL platforms
it comes from here http://www.wlenerz.com/QLSD/
Rom file here https://www.kilgus.net/soft/minerva_1g98_qlsd.zip
Sample qxl.win here
SD WIN.rar
thanks in advance
Markus
desin24
Re: Sinclair QL
Postby desin24 » Sun May 06, 2018 3:25 pm
new drivers for a QXL.win on the second drive
sources from here http://www.wlenerz.com/QLSD/
ready made boot.rom containing rom and driver
and QXL.win files from here :
https://www.dropbox.com/sh/cz8zt5hc92o8 ... 322aa?dl=0
rename it as boot.rom or boot0.rom in the QL subdirectory
Markus
desin24
Re: Sinclair QL
Postby desin24 » Sun May 06, 2018 3:30 pm
sorgelig :
Selected file QL/boot0.rom with 65536 bytes to send for index 0.0
Selected file QL/boot1.rom with 32768 bytes to send for index 0.1
FileOpenEx(open) File:/media/fat/QL/boot2.rom, error: -1.
what are the conditions for boot1.rom and boot2.rom to be valid
or are they just placeholders ?
thanks in advance
Markus
Re: Sinclair QL
Postby Sorgelig » Sun May 06, 2018 6:42 pm
MiSTer is universal platform and not everything supported by specific core.
Please follow the readme for QL.
