PC Engine core
Re: PC Engine core
Postby Sorgelig » Tue Sep 18, 2018 4:08 pm
Fixed misplaced lines. Tested on Sinistron, Darius, Bomberman 94.
Probably need to re-test the games with misplaced lines. Since the fix is new - the previous results are not reliable.
albconde
Re: PC Engine core
Postby albconde » Tue Sep 18, 2018 5:59 pm
Start testing , misplaced lines seens fixed .
after buner 2 : crash
Andre Panza Kick Boxing bad sprites
Cadash : flicker in game
Davis cup tennis : flicker in game
first misplaced line found "f1 dream" in game the las line is misplaced , you need to play unti the first curve to see.
Re: PC Engine core
Postby Sorgelig » Tue Sep 18, 2018 6:18 pm
after buner 2 - it was always crashed - so far no one claimed to fix this.
Cadash - i've played a little several times and didn't notice flickering. May be i didn't play long enough...
My last fix is targeted solely for misplaced lines - nothing else.
Also i've adjusted the screen centering and visibility according to 240pSuite.
If there will be no new serious problems then it will be a candidate for release
albconde
Re: PC Engine core
Postby albconde » Tue Sep 18, 2018 7:31 pm
for now not big problems .
Hyperdyne sidearms :miss some lines in the botton of the screen
retesting some things . I did not see your last comit
flicker in Cadash if fixed in last version
Andre Panza Kick boxing : black screen now
Puzzle boy :black screen , music work
Rastan Saga Black screen
Davis cup tennis : black screen
madoo Granzort : black screen
Some games has a problen with the first or the last line in gaming area ( f1 dream , pac land or Raiden) but there are playable.
The last update fix some thing but break others , the games are better centered , only sidearms has problems of center on my test
Re: PC Engine core
Postby Sorgelig » Wed Sep 19, 2018 3:17 am
I've made the fix:
fixed: Andre Panza Kick boxing : black screen now
Puzzle boy :black screen , music work - still black screen but game itself is often crash anyway - so skip for now.
fixed: Rastan Saga Black screen
fixed:Davis cup tennis : black screen - game still flickering on lower part.
fixed:madoo Granzort : black screen
Re: PC Engine core
Postby Sorgelig » Wed Sep 19, 2018 4:30 am
Released finally :)
Re: PC Engine core
Postby Sorgelig » Wed Sep 19, 2018 7:25 am
Does anyone has schematics of SuperGrafx?
I wonder how two VDC in real HW are synchronizing. Both are generating HSync/VSync and there should be a way to align them.
GreyRogue
Re: PC Engine core
Postby GreyRogue » Wed Sep 19, 2018 1:40 pm
Sorgelig wrote:Does anyone has schematics of SuperGrafx?
The VDC (6270) is capable of producing hsync and vsync, but I don't think any games use that mode. See CR register (05) bits 4 and 5 for the internal/external settings. Archaicpixels.com also has pics of the pinouts. The sync signals are coming from the VCE (6260).
Re: PC Engine core
Postby Sorgelig » Wed Sep 19, 2018 2:33 pm
GreyRogue wrote:The VDC (6270) is capable of producing hsync and vsync, but I don't think any games use that mode. See CR register (05) bits 4 and 5 for the internal/external settings. Archaicpixels.com also has pics of the pinouts. The sync signals are coming from the VCE (6260).
Are you sure 6260 generates sync for 6270?
As far as i understand, in original TGFX16 6270 generates sync for 6260, not opposite.
But in SGX the second 6270 should be in slave mode and receive sync from first VDC.
albconde
Re: PC Engine core
Postby albconde » Wed Sep 19, 2018 5:59 pm
The lastest changed, after the reléase , improved a Little after burner 2 , sooner or later the game crash but now you can start to play
BBond007
Re: PC Engine core
Postby BBond007 » Thu Sep 20, 2018 1:39 am
Sorgelig wrote:Released finally :)
So far this core seems like a very big improvement as far as compatibility and glitches.
Well done :)
albconde
Re: PC Engine core
Postby albconde » Thu Sep 20, 2018 5:46 pm
the latest comit fixed in addition to Coryoon crashes , random crashes in "jaseikin necromancer" and "f1 circus 92"
Re: PC Engine core
Postby Sorgelig » Thu Sep 20, 2018 6:49 pm
Add fix for black screen on Puzzle Boy. Together with previous fix it makes Puzzle Boy fully working.
albconde
Re: PC Engine core
Postby albconde » Thu Sep 20, 2018 9:18 pm
tested , puzzle boy Works great .
this change also fix flicker in Cadash ( again )
This change made the garbaje line in atomic robo kid back , i I think this line is the real machine too , but is outside of the screen, the same for side arms ,there is text cut at the bottom of the screen, if you press run this text goes up and is completely visible.
In my first test with this version , the only games with big problems are :
After burnes 2 : crash
Andre Panza kick boxing : sprite problems
Davis Cup Tenis : flicker , a lot in SDRAM , less in DDR3
Some other little things in a few games , but all I tested is playable
GreyRogue
Re: PC Engine core
Postby GreyRogue » Fri Sep 21, 2018 1:18 am
albconde wrote:In my first test with this version , the only games with big problems are :
Found the issue (IRQ Vector Address Race Condition).
Fixed in latest pull request.
Re: PC Engine core
Postby Sorgelig » Fri Sep 21, 2018 5:07 am
About Side Arm lower toolbar: is it supposed to be visible? In Mednafen emulator this bar is completely hidden below the visible area.
Asmith
Re: PC Engine core
Postby Asmith » Fri Sep 21, 2018 5:49 am
Sorgelig wrote:About Side Arm lower toolbar: is it supposed to be visible? In Mednafen emulator this bar is completely hidden below the visible area.
Hi ,
if you're talking about the weapons bar this one is only visible when you press run (or select don't remember well) to pause and change weapons , on real hardware ; with a crt ; it's most of the time cut in the middle at best .
A_s
Re: PC Engine core
Postby Sorgelig » Fri Sep 21, 2018 6:58 am
Looking at games in Mednafen i understand that core uses too narrow vertical blanking. Some games output the garbage or wrapped lines - all this is supposed to be hidden.
I wrongly assumed that 240pSuite test pattern should be fully visible while it shouldn't.
Re: PC Engine core
Postby Sorgelig » Fri Sep 21, 2018 9:08 am
Adjusted VBlank, so games affected by upper and bottom garbage should be fixed. Madou Granzort also looks proper with non-floating panel.
Re: PC Engine core
Postby Sorgelig » Fri Sep 21, 2018 3:02 pm
Adjusted the RCR IRQ which fixes background shaking on Side Arms (if SDRAM is selected).
Re: PC Engine core
Postby Sorgelig » Fri Sep 21, 2018 4:08 pm
Fixed VBlank IRQ, which fixes Cadash screen flickering.
Re: PC Engine core
Postby Sorgelig » Fri Sep 21, 2018 5:39 pm
Implemented LFO in PSG. Hanii in the Sky music gets vibrato sound.
albconde
Re: PC Engine core
Postby albconde » Fri Sep 21, 2018 5:50 pm
tested a Little , After Burner 2 Works great
The new option vertical Blank is very good , remove all garbage , only find a case "final lap twin" with 1 line of grabage at the botton of the screen, the game is perfectly playable.
Some of the bad lines in playable area are solved too, like last line in pac land , but the first line is wrong
thanks to both of you
Re: PC Engine core
Postby Sorgelig » Fri Sep 21, 2018 6:00 pm
albconde wrote:only find a case "final lap twin" with 1 line of grabage at the botton of the screen
it's the same on Mednafen. Actually it's possible to increase bottom blank by 1 line. I've just followed Mednafen.
albconde
Re: PC Engine core
Postby albconde » Sat Sep 22, 2018 8:59 am
With the latest changes before the release we have a few new problems , but only one big in my test.
"Order of Griffon" not work , Violet screen when you start to play, the music work.
others:
"Jackie chan" have problem in the status bar in game ( playable)
"Operation Wolf" has problem with 1 line , the first in status bar (playable)
Users browsing this forum: reflex and 19 guests
