MSX core
MSX core
Postby Sorgelig » Mon Sep 25, 2017 6:45 pm
I'm in process of porting MSX core.
Since i'm not familiar with MSX and its software i need some help.
1) I need game which uses PCM sound
2) I need game/app which uses interlaced video mode
Re: MSX core
Postby Sorgelig » Mon Sep 25, 2017 7:09 pm
3) game/app where i can test/use the mouse
Gehstock
Re: MSX core
Postby Gehstock » Mon Sep 25, 2017 8:54 pm
1.
Golvellius II
Gorby's Pipeline(patched version)
Rune Master II
2.
http://marmsx.msxall.com/msxvw/oldmsxvw/msxvwe.php
3.
Carmen Sandiego
Shoot the Flying Windows
Bejeweled
Breaker
Operation Wolf 48K
Match Maniac
Quattro
Re: MSX core
Postby Newsdee » Tue Sep 26, 2017 9:55 am
For SCC there is a version of Knightmare that support it. It is in the "starter pack" that I made for the MiST long ago:
http://newsdee.com/mist/msx_sd_card_0.5.zip
Re: MSX core
Postby Sorgelig » Tue Sep 26, 2017 11:04 am
Newsdee wrote:For SCC there is a version of Knightmare that support it. It is in the "starter pack" that I made for the MiST long ago:
music in Knightmare works fine, but doesn't look like PCM. It looks like OPLL.
Re: MSX core
Postby Sorgelig » Fri Sep 29, 2017 4:56 pm
Released: https://github.com/MiSTer-devel/MSX_MiSTer
Note: This is the first core requiring a secondary SD card. So either you need I/O board v5.x or make your own breakout SD board according to I/O board 5.x schematic.
May be later i will add support the loading from primary SD card (from images), but no ETA yet.
Core requires SDRAM board as well.
Gehstock
Re: MSX core
Postby Gehstock » Sat Sep 30, 2017 5:00 pm
Thank you
Re: MSX core
Postby Newsdee » Sat Sep 30, 2017 11:24 pm
Can't try it yet, but great work!
bazar77
Re: MSX core
Postby bazar77 » Sun Oct 01, 2017 11:49 am
Thank you :cheers:
weirdocollector
Re: MSX core
Postby weirdocollector » Mon Oct 02, 2017 9:04 am
Thanks a lot for your work ! :cheers:
This project is simply awsome ! 8O
Re: MSX core
Postby Newsdee » Tue Oct 03, 2017 1:14 am
I'm curious about whether the ZPUFlex was removed from this core, and replaced with the standard menu? I guess it's still there otherwise the porting work would be much harder?
Gehstock
Re: MSX core
Postby Gehstock » Tue Oct 03, 2017 8:35 am
Core has Standart Core Menu
Re: MSX core
Postby Sorgelig » Tue Oct 03, 2017 11:33 am
No ZPU in this core. The version with ZPU was a separate branch for MiST and few other boards. It had no SDHC support.
The version i've ported is more advanced and newer. With SDHC support.
DanyPPC
Re: MSX core
Postby DanyPPC » Tue Jan 23, 2018 7:38 am
Is it possible to port this new updated core on MiST platform ?
Old MSX core has never worked well on newer MiST.
silverfox0786
Re: MSX core
Postby silverfox0786 » Mon May 07, 2018 12:06 pm
Can someone help me set up msx. I cant get sdcreate to work and manually adding files in correct order is not working for me
Fat16 formmated 2gb sd card in secondary slot
Cebion
Re: MSX core
Postby Cebion » Mon May 07, 2018 12:55 pm
Did you use SDcreate with Administrator rights?
What error did you get?
BlueLightning
Re: MSX core
Postby BlueLightning » Mon May 07, 2018 2:27 pm
Open cmd navigate to the sd create folder and start sdcreate from the command line ! Don t use double click from explorer that doesnt work.
silverfox0786
Re: MSX core
Postby silverfox0786 » Mon May 07, 2018 10:14 pm
BlueLightning wrote:Open cmd navigate to the sd create folder and start sdcreate from the command line ! Don t use double click from explorer that doesnt work.
this seems to have worked. but now i hit a new snag, how do i actually use the core, i cant see how to mount anything to it. all i get is a blank screen of which i can press F12 and get a menu.
silverfox0786
Re: MSX core
Postby silverfox0786 » Mon May 07, 2018 10:43 pm
scratch that its all working, i love MSX its such a cool computer.
my sd card was one MSX didnt like a new SD card and mm works now
awesome
MisterTailor
Re: MSX core
Postby MisterTailor » Mon Aug 06, 2018 8:51 pm
yeah.... i make at first the mistake, that i do not open CMD as admin
now, it works... :cheers:
MSX world,.. i love it :)) :mrgreen:
thank you
Indcsion
Re: MSX core
Postby Indcsion » Wed Oct 24, 2018 5:09 pm
Do you still need the secondary sdcard? Im playing fray without but im not sure how to get past this part.
Re: MSX core
Postby Sorgelig » Wed Oct 24, 2018 6:37 pm
floppy mounting in MSX is done by MSX utilities, not by core.
So, how they support multi-disk games - i have no idea. It's MSX machine-specific question. Probably you need to dig in MSX forums to find the answer.
nico24
MSX setting for large MegaRoms
Postby nico24 » Thu Jan 03, 2019 3:30 am
Anyone tried to get the game Sword of Ianna working? this rom is >700kb so not sure how it's supposed to work. This is a general question to any forum about MSX really, since I haven't been able to get it working on the real hardware either.
DanyPPC
Re: MSX setting for large MegaRoms
Postby DanyPPC » Thu Jan 03, 2019 6:38 am
Here works.
You have to launch the game with MGLOCM command:
mglocm ianna.rom
my setup is:
SLOT1 MegaSCC+
SLOT2 MegaRam 2MB
enginesol
Re: MSX core
Postby enginesol » Fri Jan 04, 2019 11:33 am
Hi!
Where are the rom or dsk games stored?
In wich folder?
Thnx
Users browsing this forum: No registered users and 15 guests
