Hades - problem with Internet card
Kroll
Postby Kroll » Fri Aug 18, 2017 10:01 am
Hi all,
As anyone could read in another thread, and my Hades less than two weeks ago he came back to me after almost 1.5 year break again I wanted to go back to the configuration from a computer crash. I use the same type of graphics card ATI MACH 64 (physically not the same card).
My first problem is with the network card, I use exactly the same as before the Realtek 8139C crash, I checked it on the PC is certainly working. I installed Easymint and DHCP, I configured the same as before, but when I called mydhcp on the screen I get this message several times and then launches the desktop but no connection is with the internet
DHCPDISCOVER on rtk0 to 255.255.255.255 port 67 interval 4 (several times)
Someone has an idea what might be wrong?
Re: Hades - problem with Internet card
Postby wongck » Fri Aug 18, 2017 12:41 pm
no dhcp server (your router?) replied to the dhcp client (your hades).
I suppose you should try a fixed ip address first.
Kroll
Postby Kroll » Fri Aug 18, 2017 2:12 pm
wongck wrote:no dhcp server (your router?) replied to the dhcp client (your hades).
To the same router I have also connected Falcon and TT with netusbee and in the same way and everything is OK, so I'm surprised
I tried it manually this way:
ifconfig rtk0 addr 192.168.1.14 netmask 255.255.255.0 up
route add default rtk0 gw 192.168.1.1
route add 192.168.1.0 rtk0
Is this OK ?
wongck wrote:I suppose you should try a fixed ip address first.
How should I do it ?
Postby wongck » Sat Aug 19, 2017 1:03 am
manual way is same as using a fixed ip address.
by using dhcp, the dhcp server can potentially give a different ip address every time.
if this has been working on your TT and Falcon, then it should not be any different and should work.
Kroll
Postby Kroll » Sat Aug 19, 2017 11:31 pm
Today I have test it on CT63/CTPCI with Realtek 3189D under MiNT 1.17 (look at other thread in section CT63) and in Conholio I set:
ifconfig rtk0 addr 192.168.1.13 netmask 255.255.255.0 up
and is working, FTP/Netsurf
On Hades I set almost the same but only other IP address
When logging to my router on PC computer I see falcon with static address 192.168.1.13, Hades is not visible, addtional when I tried to ping from Hades for example ping 192.168.1.1 or 192.168.1.16 (PC address) the system is crashed and have to switch of computer
What do you think ? is it a hardware problem ? :(
Kroll
Postby Kroll » Tue Sep 19, 2017 8:09 pm
I solved the problem with network on my Hades, I was able to buy an older card, which is also compatible with Hades, the Realtek 8029, I installed the driver and DHCP worked immediately, without any trouble.
Return to “Hades / Milan”
