Steem.SSE.3.9.2.Win32.D3D crashes
Bug reports and support area for Steem
Forum rules
All bug reports must include:
Steem version
Host operating system version
TOS ROM version
Copy of steem.ini
Reference to or copy of disk image being used
Brief description of steps performed
Description of desired outcome
Description of actual outcome
Re: Steem.SSE.3.9.2.Win32.D3D crashes
Postby Steven Seagal » Fri Aug 11, 2017 3:41 pm
Forum management should really change those labels.
Some feedback on the bug:
We disabled Multimedia joystick support because joyGetDevCaps (or joyGetPos
and joyGetPosEx for that matter) returns unexpected value JOYERR_PARMS or
crashes on recent systems, reason unknown.
On my system, it doesn't crash but it returns a bad value. WinUAE doesn't use those functions. I couldn't find on the internet if that's a general problem.
This was the original joystick handling way in Steem but then Steem authors added optional DirectInput support.
So now it's DirectInput (better) or nothing, spares some code too.
Thx for all your tests.
MartinVogel
Postby MartinVogel » Fri Aug 23, 2019 11:32 pm
I have the same problem with Steem SSE 3.9.4 (all versions). Every time I activate Midi In Steem SSE crashes. Is there a fix? that would be nice because I want to use Steem SSE because of the ASCII drives.
Thank You für your help
Martin Vogel
Return to “Support”
