Hardware Overscan
Re: Hardware Overscan
Postby Steven Seagal » Tue Jul 25, 2017 8:55 pm
AtariZoll wrote:I posted those drivers just for case if it can help. I don't need overscan in Steem. Maybe if it will be 4K, less than it is not attractive :D
It's a fun feature though.
Right, in that case I'm happy to report that those drivers and this appliance will be UNSUPPORTED. :)
Greenious
Postby Greenious » Thu Jul 27, 2017 1:06 am
These are the latest autoswitch overscan drivers I have, dated september 1990.
I also got the english manual and I'll try to scan it soon. I posted a photo of the claimed resolutions earlier.
Still, this commercial version also uses the 2mhz clock and mono detect for the circuit, what difference it makes I don't know.
Lacescan is still the better driver though, with 2.06 support etc.
viewtopic.php?t=5040
Postby Steven Seagal » Sat Jul 29, 2017 6:54 pm
Thx. This one could be supported, it seems it was "popular".
It is activated the same way as LaceScan, but unless I missed something due to the mono detect or the clock, apparently Autoswitch overscan is less impressive than LaceScan overscan: 96 bytes/scanline in monochrome instead of 100, and only 224 bytes at 50hz, instead of 236!
Greenious
Postby Greenious » Tue Aug 01, 2017 1:59 pm
Steven Seagal wrote:Thx. This one could be supported, it seems it was "popular".
I finally got the manual scanned. Unfortunately I don't have the tools to make the pdf as orderly as I'd wanted... Perhaps someone with the proper tools/time could sort the page numbers properly.
Anyway, it's not unreadable.
The writer of lacescan is a friend of mine, who sadly left the scene a long time ago and is unlikely to come back, but I talk to him from time to time and I'll bring up lacescan next time. One reason for lacescan's ability to handle higher resolution than the Autoswitch overscan is that it also can work with virtual resolutions, and that way also is useable on STE aswell as STs without overscan hardware at all.
Postby Steven Seagal » Thu Aug 03, 2017 10:32 am
The control software looks very similar...
Contrary to Lacescan, Autoswitch fetches 224 bytes at 60hz or 50hz.
Gaiyan
Postby Gaiyan » Thu Aug 03, 2017 11:06 am
Very useful. Thanks. May I sort out the pages and host on my site?
I don't know if you noticed or if it's relevant but I made a small batch of LaceScans: viewtopic.php?f=33&t=31463#p323697
I hope I'm not breaking any copyrights that he asserted. I did my best to follow his requests. I supply a floppy with his LaceScan software totally unmodified.
Postby Steven Seagal » Thu Aug 03, 2017 4:29 pm
Steven Seagal wrote:apparently Autoswitch overscan is less impressive than LaceScan overscan: 96 bytes/scanline in monochrome instead of 100, and only 224 bytes at 50hz, instead of 236!
To correct a previous (hasty) statement...
96 bytes instead of 100 isn't a big difference, and at 96*8= 768, hires was also above monitor specs, not to mention the little HSYNC problem.
But apparently you get 480 lines max, compared with 500 for Lacescan.
224 bytes in colour mode are more than enough to reach the maximal resolution, which is still determined by HBLANK.
The fact that it's 224 (divisible by 4) at 50hz or 60hz is a big advantage: no GEM problems!
Probably the GLUE clock was needed to stop DE at the right time, there must be a counter in the circuit, with a different threshold for monochrome and colour, hence the mono detect line.
Postby Steven Seagal » Thu Aug 03, 2017 4:33 pm
Gaiyan wrote:I don't know if you noticed or if it's relevant but I made a small batch of LaceScans: http://atari-forum.com/viewtopic.php?f= ... 63#p323697
At last some pics.
I also found pics of Autoswitch in French ST Mag 050.
Gaiyan
Postby Gaiyan » Thu Aug 03, 2017 4:44 pm
I fixed the manual. It was too big to attach here so it's hosted on my site. Let me know if that's ok. http://www.atariancomputing.com/downloads/manuals
Greenious
Postby Greenious » Thu Aug 03, 2017 8:49 pm
Gaiyan wrote:Very useful. Thanks. May I sort out the pages and host on my site?
:) Sure you can! Eventually I would have done it myself, but I rather had the scanned manual out asap, since it would likely take me another couple of weeks to get around to fix the PDF...
I actually called Ronald today and talked with him a bit, he is happy that his work still is of any use to people and felt it flattering someone is making the lacescan mod. :cheers:
Greenious
Postby Greenious » Thu Aug 03, 2017 9:03 pm
As I mentioned in the previous post, I talked with Ronald, the maker of Lacescan today, but as I kinda expected, he didn't really remember much of the finer details of the mod...
But you are likely correct that the 2mhz clock is used to shorten DE to make it work in all resolutions and refresh rates. As the original overscan doc states, there's some problems with (lowrez) 60hz in particular. And lacescan has more in common with the original mod than the Autoswitch one when it comes to actually generating overscan.
The basic circuit is the same though, and I doubt lacescan actually achieved 500 lines in practice, although his driver probably took height for it to be possible on some monitors.
Greenious
Postby Greenious » Thu Aug 03, 2017 9:08 pm
At last some pics.
Oh, you want pics! Sorry, I didn't pick that up earlier.
There are some threads in the hardwareforum with some overscan pics, I'll dig around and see what I find, but here is one I happened to save the other day...
And when I get my ST set up again, I'll make sure to get some more pics for ya!
Greenious
Postby Greenious » Thu Aug 03, 2017 9:31 pm
Gaiyan wrote:I fixed the manual. It was too big to attach here so it's hosted on my site. Let me know if that's ok. http://www.atariancomputing.com/downloads/manuals
It's perfectly OK! And thanks for taking the time to fix it! :D
Btw, I did miss you were making the lacescan mod, I'm going to order one from you just because of the cute 3D printed enclosure... :mrgreen:
Gaiyan
Postby Gaiyan » Fri Aug 04, 2017 4:27 am
Thank you. My pleasure. I hope the enclosure doesn't disappoint. It's rather crude, but functional :)
Postby Steven Seagal » Fri Aug 04, 2017 9:59 am
Greenious wrote:Oh, you want pics! Sorry, I didn't pick that up earlier.
Seeing how it works on HW is always instructive. For instance, I didn't even know that borders are always black in high res.
There's also doubt on the exact positioning, not that it's so important.
Is the image distorted on the edges?, etc.
Also noticed there's a clock displayed on the top right in Autoswitch. In Steem, it's right but I think it's a hack.
A beta with support for both Autoswitch and Lacescan circuits is now available.
http://sourceforge.net/projects/steemsse/files/DevBuilds/
One question I have, as the setup program is almost the same, is Autoswitch an evolution of Lacescan?
Gaiyan
Postby Gaiyan » Fri Aug 04, 2017 10:19 am
There is a option in LaceScan to position the screen and some other options in the auto program. I'll send pictures when I get back home.
Steven Seagal wrote:Also noticed there's a clock displayed on the top right in Autoswitch. In Steem, it's right but I think it's a hack.
LaceScan is "inspired" by Autoswitch Overscan, so it's the other way around. It even says so in the boot screen I linked in the other thread.
Postby Steven Seagal » Fri Aug 04, 2017 12:21 pm
If I get this right...
There was the "original overscan", with 236 byte scanlines at 50hz and 234 at 60hz.
Later the same authors produced Autoswitch with 224 byte scanlines at 50 and 60hz, which is better for GEM.
Later Lacescan, by different authors, was based on the original circuit and also featured 234/236 byte scanlines.
Hence my confusion. :)
Gaiyan
Postby Gaiyan » Fri Aug 04, 2017 2:17 pm
Steven Seagal wrote:If I get this right...
I think that's correct as far as I know. Here are some more pictures.
Postby Steven Seagal » Fri Aug 04, 2017 7:46 pm
Thx, it's funny, the images are upside down in the forum (IE11), I thought you messed up, but OK in IrfanView :)
It's a VGA connection, I guess? The top lines are apparently missing. Unfortunately, there doesn't seem to be a way to shift the display down.
Greenious
Postby Greenious » Fri Aug 04, 2017 8:40 pm
Yes, that would be correct!
I'll download you beta and play with it a bit this weekend, thanks a million for your efforts!
Postby Cyprian » Fri Aug 04, 2017 9:06 pm
Steven Seagal wrote:Thx, it's funny, the images are upside down in the forum (IE11), I thought you messed up, but OK in IrfanView :)
also upside down in Firefox and Chrome
Postby ijor » Sat Aug 05, 2017 11:54 am
troed wrote:That's interesting (I'm sure the schematic is right). There's thus unnecessary logic in GLUE handling BLANK in mono without it actually being used (unless you trick the GLUE by triggering the BLANK position for mono while otherwise in color).
Yes, GLUE processes BLANK exactly with the same logic as DE, just with different values. Even when at the board level it seems that BLANK doesn't affect the mono output, there are specific comparators for HBLANK and VBLANK at 70Hz.
Steven Seagal wrote:In Steem currently it's supposed to be 3 scanlines in all frequencies, but it is true only for 50hz, not really tested at other frequencies.
It is 3 scanlines in color, 50Hz and 60Hz. But at 70Hz it's just a single scan, IIRC.
I posted full sync traces years ago: http://www.atari-forum.com/viewtopic.ph ... 68#p138049 That was at 50Hz IIRC, but I might possibly have traces for other frequencies if you want them.
It's easy to test because the video counter is reloaded when the MMU sees VSYNC changing. Guess I'll do a little test program...
MMU reloads the video pointer it at the falling edge of VSYNC only (start of VSYNC).
Postby Steven Seagal » Sat Aug 12, 2017 7:20 am
Yet, some programs seem to rely on the counter being reloaded again at the end of VSYNC, when the VBL interrupt is set pending, at least in Steem (so it could be something else). :shrug:
Example:
Beyond/Universal Coders
Postby ijor » Sat Aug 12, 2017 11:48 am
Steven Seagal wrote:Yet, some programs seem to rely on the counter being reloaded again at the end of VSYNC, when the VBL interrupt is set pending
Sorry, I was wrong. The video pointer is updated whenever VSYNC is asserted. But it is not exactly that it is reloaded again at the end of VSYNC, it is constantly being reloaded during the whole period that the signal is asserted.
Postby Steven Seagal » Sun Aug 13, 2017 8:38 am
ijor wrote:But it is not exactly that it is reloaded again at the end of VSYNC, it is constantly being reloaded during the whole period that the signal is asserted.
Another little mystery solved, thx.
So the emulator approach of reloading it twice was mostly correct (reloading it all the time would be a... load). ;)
We just need to make sure that any read in between returns the base address.
On the STE, someone could try to change the video counter during vsync for whatever reason.
Return to “Development”
