MiSTer updates and changelog
Re: MiSTer updates and changelog
Postby Sorgelig » Mon Mar 18, 2019 7:24 pm
MiSTer:
- Input: fixes, improve button mapping dialog.
Postby Sorgelig » Tue Mar 19, 2019 7:53 pm
MiSTer:
- Input: fixes, add DPAD test stage in joystick definition (Menu core).
Read the updated Wiki for understanding the joystick mapping stages:
https://github.com/MiSTer-devel/Main_Mi ... ck-mapping
Postby Sorgelig » Wed Mar 20, 2019 1:02 pm
C16:
- Add SID 6581/8580 support.
Postby Sorgelig » Wed Mar 20, 2019 9:10 pm
C64:
- Fix: keys could stick during reset.
alanswx
Postby alanswx » Wed Mar 20, 2019 10:40 pm
New cores:
Arcade: Canyon Bomber
Arcade: Dominos
Arcade: Sprint1
- 1 player version of sprint
Arcade: Sprint2
- 1 or 2 player version of sprint
Arcade: Super Breakout
Port of James' Atari/Kee cores.
Arcade: TraverseUSA
Port of Dar's TraverseUSA with help from Gehstock
- note graphics may require a reboot before/after using core. Not sure why yet.
Postby Sorgelig » Thu Mar 21, 2019 7:21 am
SAM Coupe:
- SAA1099: fix the mixer overflow.
Postby Sorgelig » Thu Mar 21, 2019 2:03 pm
NES:
- Many fixes from greyrogue
- FDS BIOS now must be placed as boot.rom
- FDS audio fixes from paulb-nl
- Update gamepad API - now all buttons (including power pad) can be mapped.
Postby Sorgelig » Thu Mar 21, 2019 3:46 pm
MiSTer:
- Fix per-core ini config.
- Input: show message if joystick not defined. Request to define the joystick in Menu core.
- Input: quirk for 8bitdo menu button in D-Input mode.
- Input: update the map filenames (old maps won't work).
- Fix video info HDMI pixel frequency.
Postby Sorgelig » Sun Mar 24, 2019 7:19 pm
NES:
- More improvements for FDS audio from Kitrinx.
- More boot.rom options from Greyrogue (read the readme!).
- Fix the scandoubler (absent pixel column).
Postby Sorgelig » Sun Mar 24, 2019 7:31 pm
MiSTer:
- Update the original font.
- Support for font loading through ini option.
- Input: relax max value for Stick 1/2 setup (some gamepads don't reach the max value).
Some fonts prepared by rikard-softgear: https://github.com/MiSTer-devel/Fonts_MiSTer
alanswx
Postby alanswx » Sun Mar 24, 2019 11:12 pm
New core:
Arcade: Berzerk
alanswx
Postby alanswx » Mon Mar 25, 2019 3:36 pm
Arcade: Centipede
New!
Arcade: Berzerk
Fixed the aspect ratio, should be correct in HDMI mode now.
Postby Sorgelig » Wed Apr 03, 2019 5:04 pm
MiSTer, Linux:
- Support for Bluetooth.
Read the Wiki: https://github.com/MiSTer-devel/Main_Mi ... /Bluetooth
Postby Sorgelig » Sat Apr 06, 2019 9:37 am
Linux:
- Simplified Dualshock3/Sixaxis pairing procedure (now the same as on PS3).
- Cleanup BT scripts, remove unused tools.
- Fake the Vendor ID on 8bitdo gamepad in Apple mode to not confuse dualshock 4 driver.
MiSTer:
- Improved support for Dualshock 4 gamepad. Touchpad now acts as mouse.
- use /dev/input/mice for mouse to support some non-standard input devices acting as mouse.
- some special support for 8bitdo gamepads over BT.
- Remove obsolete PS3 pairing procedure.
Updated info about Dualshock3/Sixaxis pairing: https://github.com/MiSTer-devel/Main_Mi ... /Bluetooth
Postby Sorgelig » Sat Apr 06, 2019 1:22 pm
Genesis:
- Support for Pier Solar game
- Fix Old Tower game
Postby Sorgelig » Sun Apr 07, 2019 7:36 am
Genesis:
- Fix SSF2 mapper's initial state.
- Speed fix for Titan Overdrive 2.
Postby Sorgelig » Mon Apr 08, 2019 1:47 am
MiSTer:
- Fix the mouse handling.
Postby Sorgelig » Tue Apr 09, 2019 3:43 pm
NES:
- Many fixes and improvements from Kitrinx
- fixes from paulb-nl
alanswx
Postby alanswx » Tue Apr 09, 2019 5:19 pm
New core:
Arcade: Frenzy
Postby Sorgelig » Thu Apr 11, 2019 1:00 pm
SMS:
- Fixes from theflynn49.
- sys: fix the scandoubler.
Postby Sorgelig » Thu Apr 11, 2019 6:29 pm
SNES:
- CPU, APU, PPU, SA1 fixes from srg320
- fix the scandoubler.
Postby Sorgelig » Fri Apr 12, 2019 6:31 pm
C64:
- Support for TAP files.
Postby Sorgelig » Sun Apr 14, 2019 5:31 pm
Genesis:
- Update FM + HiFi PCM from Jotego
- Fix 3-button compatibility mode in 6-button mode.
Postby Sorgelig » Sun Apr 14, 2019 11:01 pm
C64:
- Fix memory erase broken in previous release.
- Update CIA.
- Use different master clocks for PAL/NTSC.
Postby Sorgelig » Wed Apr 17, 2019 3:35 pm
C16:
- Update C1541.
- Adjust PAL/NTSC frequencies.
Users browsing this forum: djsquare and 5 guests
