MiSTer updates and changelog
Re: MiSTer updates and changelog
Postby Sorgelig » Sun Feb 10, 2019 10:19 am
Arcade: Ghosts'n Goblins:
- Fix imaginary ladder.
Postby Sorgelig » Sun Feb 10, 2019 5:24 pm
Atari 800:
- Disk write support.
- CPU fix to support illegal opcodes.
- Update to latest code.
- 4MB RAM option.
Postby Sorgelig » Tue Feb 12, 2019 12:44 pm
Atari 800:
- SDRAM is not required for memory config up to 320KB and if no Cartridge used.
- OSD option for Dual Pokey.
- BIOS option to choose different configs.
- Update disk emulator. Support for (some)ATX disk format (from upstream sources).
- Update reset behaviour to unmount all drives/carts.
- Back to old CPU (passes more acid800 tests).
Atari 5200:
- SDRAM is not required any more.
- Update to latest upstream sources.
- Update reset to reload the cart.
Postby Sorgelig » Wed Feb 13, 2019 6:57 am
Atari 5200:
- Add support for Bounty Bob Strikes Back cartridge.
- Trying to fix the joystick.
Postby Sorgelig » Wed Feb 13, 2019 8:19 am
Gameboy:
- Fix Xenon 2 (and probably other games) sprites.
- T80: fixed 16 bit DEC opcode timing
- sys: fix the audio
- sys: update the scaler.
- remove fast boot option. It's buggy.
Postby Sorgelig » Wed Feb 13, 2019 11:28 am
C64:
- Option to use User port for UART.
- Update the scaler.
Postby Sorgelig » Sat Feb 16, 2019 12:45 pm
C64:
- Update keyboard layout. Support for F2,F4,F6,F8 keys.
- Add readme with some important info.
- Adjust frequency difference between C64 and C1541 for PAL/NTSC for some picky fast loaders.
GreyRogue
Postby GreyRogue » Sun Feb 17, 2019 1:41 am
TI-99/4A:
- Fix the reset combo and the reset button.
- Add controller swap option, and additional common controls (enter, back, redo).
- Fix STCR status flag. It looks like it should be updating the Higher than, Greater than, Zero and Carry flags.
--Fixes controls for Ms Pac Man
--LDCR probably needs a similar fix.
Postby Sorgelig » Mon Feb 18, 2019 9:19 am
Genesis:
- Fix audio cracks.
- Update the scaler
- Update the scandoubler.
- Update FX68K to latest version.
Postby Sorgelig » Mon Feb 18, 2019 3:16 pm
TurboGrafx16:
- Support for Linux audio.
- Fix the audio cracks.
- Update the scaler and scandoubler.
Postby Sorgelig » Mon Feb 18, 2019 3:36 pm
MiSTer:
- OSD: adjust scrolling.
- input: analog stick: -128 is illegal value. Limit to -127..+127 range.
- input: use OSD button to finish remapping for game.
- input: 8bitdo PSC receiver: special combo handling as OSD button.
Postby Sorgelig » Tue Feb 19, 2019 7:23 pm
New core: Arcade: 1942
Port of Jotego's 1942 core.
Postby Sorgelig » Tue Feb 19, 2019 7:58 pm
C64:
- Support for cartridge autoload (read the readme)
- Autorun for PRG files.
Postby Sorgelig » Wed Feb 20, 2019 8:18 pm
Amstrad:
- PSG: fix the noise channel.
- Switch to open source scaler.
- Fix the audio crackles.
- other updates in framework.
Postby Sorgelig » Wed Feb 20, 2019 8:56 pm
Arcade 1942:
- Fix the wrong output buffer in rotated screen.
- Adjust the aspect ratio.
- Screen flip option.
Postby Sorgelig » Sun Feb 24, 2019 5:01 pm
Genesis:
- Adjust PSG tone registers.
- Adjust gamepad handling (Fix: MK1 and Comix Zone 6-button mode).
- VDP: clear VSRAM on ROM loading, adjust INT position.
- Update scandoubler.
Postby Sorgelig » Sun Feb 24, 2019 10:26 pm
SNES:
- Support for SA1 games from srg320
- Some internal update to improve the stability.
- Other sys updates.
Postby Sorgelig » Wed Feb 27, 2019 10:11 am
ao486:
- Joystick support (digital and analog)
- Update sys to latest version.
Postby Sorgelig » Fri Mar 01, 2019 11:10 pm
MiSTer:
- Update MidiLink options.
- 2 more backgrounds for Menu core.
- Fix volume control from OSD.
Menu:
- Update sys.
- 2 more backgrounds.
- Dim the video after 2 minutes of inactivity.
Postby Sorgelig » Fri Mar 01, 2019 11:14 pm
Linux:
- Update Midilink.
- Move MIDI soft synth folders to linux folder
- Move timezone file to linux folder
- Tweak MT7601u WiFi driver.
Postby Sorgelig » Sat Mar 02, 2019 7:36 pm
SNES:
- SA1 fixes
- PPU fixes (Uniracers)
- 128KB for BSRAM (used in some games hacks)
- sys: audio output rework
Postby Sorgelig » Mon Mar 04, 2019 12:37 pm
MiSTer:
- Archie: remove FDC/File I/O customizations.
- Archie: OSD option to swap mouse buttons 2/3
- Report image size 0 if no save available (may require update of cores).
- Other fixes.
Postby Sorgelig » Mon Mar 04, 2019 12:42 pm
Archie:
- FDC improvements from Gyurco with read/write support.
- RTC support with ability to load CMOS.DAT
- Variable pixel clock for correct refresh rates.
- Overall code tweaks and fixes to improve stability.
Postby Sorgelig » Thu Mar 07, 2019 7:03 am
Gameboy:
- Many CPU and Video fixes from brNX.
- Update the framework to latest.
Postby Sorgelig » Thu Mar 07, 2019 9:00 am
NES:
- FDS: allow to run unlicensed games.
- Other fixes.
