MiSTer updates and changelog
Re: MiSTer updates and changelog
Postby Sorgelig » Thu Nov 15, 2018 10:55 pm
MiSTer:
- Support for scaler coefficient file loading at runtime (files should be put into /Filters folder).
- Improved analog stick to dpad conversion (as proposed by olin)
- Support for USB-MIDI
Genesis:
- Support for scaler coefficient file loading at runtime (Update MiSTer binary!).
- Adjust VDP timings (Toy Story)
- Workaround for some games using EEPROM/SRAM (NBA Jam TE, College Slam, Evander Holyfield, NFL Quarterback Club, Frank Thomas Big Hurt Baseball)
- Adjust FM/PSG volumes.
- Fix Space Harrier II sound.
P.S.: This release still uses old CPU!
Postby Sorgelig » Sun Nov 18, 2018 9:14 am
Genesis:
- Cycle accurate CPU from ijor
- Tweaks for new CPU.
- More workarounds for games using EEPROM, SRAM, J-CART
Postby Sorgelig » Sun Nov 18, 2018 10:48 am
NES:
- Support for Famicom Disk System (You need to load original FDS BIOS before use FDS dumps!)
- More palettes
- Support for scaler coefficients (put them into Filters folder)
- Use T65 as a most complete 6502 CPU
- Many fixes.
Postby Sorgelig » Sun Nov 18, 2018 11:40 am
SMS:
- Game Gear support (experimental)
Postby Sorgelig » Sun Nov 18, 2018 12:51 pm
Gameboy:
- A lot of fixes!
Postby Sorgelig » Sun Nov 18, 2018 1:43 pm
TurboGrafx16:
Postby Sorgelig » Tue Nov 20, 2018 11:32 pm
MiSTer:
- Automatic save file creation (on supported cores)
Postby Sorgelig » Sat Nov 24, 2018 4:53 pm
Genesis:
- new JT12 from José Tejada Gómez (Titan 2 music is perfect now)
- Workaround for Joe & Mac
- Fix Joystick port (Decap Attack)
- Some other tweaks.
Postby Sorgelig » Mon Nov 26, 2018 2:06 pm
Genesis:
- Minor updates in JT12.
- Minor update in PSG.
- Implement window bug (fixes Barkley Shut Up and Jam)
- Support for backup RAM save (only for SRAM games!)
- Supports for up to 14.5MB mapper-less ROMs (UMKT, UMKT+Tracks).
Postby Sorgelig » Wed Nov 28, 2018 3:44 pm
ColecoVision:
- Updates from MiST version: Megacart, YM2149
- This core requires SDRAM board from now.
Postby Sorgelig » Thu Nov 29, 2018 12:27 pm
New core: SNES
- Update the MiSTer binary!
MiSTer:
- Support for SNES.
- Fix KBD toggle key (auto-fire on/off for keyboard).
Postby Sorgelig » Fri Nov 30, 2018 2:37 pm
ColecoVision:
- fix the last sprites.
Postby Sorgelig » Fri Nov 30, 2018 4:50 pm
Gameboy:
- many audio fixes from brNX.
Postby Sorgelig » Sat Dec 01, 2018 12:39 pm
SNES:
- Fix BRK instruction (Equinox, dialogs in Seiken 3)
- Fix BCD (timers, counters in different games)
- Fix HDMA (Prince of Persia 2, Super Metroid)
- Fix in PPU (Far background in DK Country)
- Fix audio clock (Bad Apple)
- Fix OAM write.
Postby Sorgelig » Sat Dec 01, 2018 5:17 pm
Gameboy:
- Custom palette from file
Read the updated ReadMe about autoloading and palette usage.
Postby Sorgelig » Wed Dec 05, 2018 3:49 pm
Genesis:
- Use open source scaler.
Postby Sorgelig » Thu Dec 06, 2018 6:55 am
Genesis:
- Mouse support.
Postby Sorgelig » Thu Dec 06, 2018 11:19 am
SNES:
- Many fixes from srg320.
- Fix for games using 512/256 resolutions on the same frame.
- Clear RAM (fix hang on loading after some games).
- Switch to open source scaler from Grabulosaure.
Postby Sorgelig » Thu Dec 06, 2018 12:22 pm
NES:
- MMC5, VRC7 audio and many new mappers from Greyrogue (check the readme)
Postby Sorgelig » Fri Dec 07, 2018 8:38 am
Genesis:
- Fix HDMI VSync.
- VDP: tweaks and fixes in double-res mode.
- Force new video mode on load/reset.
Postby Sorgelig » Fri Dec 07, 2018 9:12 am
SNES:
- Fix HDMI VSync.
- Fix NMI after DMA (Wild Guns).
Postby Sorgelig » Fri Dec 07, 2018 9:49 am
NES:
- Fix HDMI VSync.
Postby Sorgelig » Fri Dec 07, 2018 5:42 pm
MiSTer:
- vscale_border option in MISTer.ini to set the border for TVs hiding the edges of screen).
- Per-core filter setting.
- Manual screen position adjustment for Minimig core.
Minimig:
- Fix high resolution modes.
- Manual screen position adjustment (Read the ReadMe and update MiSTer!)
Postby Sorgelig » Mon Dec 10, 2018 12:33 pm
Genesis:
- jt89 from Jotego as PSG to improve sound quality
- Fix distorted audio on SPDIF.
Postby Sorgelig » Tue Dec 11, 2018 5:44 am
Gameboy:
- Add full support for MBC5(8mb ROM and 128kb SRAM).
- Video fixes from brNX.
