Powering options for the CosmosEX Mini/MicroCosmos?
Postby simonsunnyboy » Fri May 12, 2017 3:21 pm
As my CosmosEX Mini/MicroCosmos was recently delivered, what ways are there to power the device properly?
There is a Mini USB port near the ACSI connector but as Jookie already told me, it is a very tight fit for most cables.
Is it possible to power the device through the Micro USB of the RaspPi? A friend said, I should work as it is 5V on top and below. But I want to ask first ;)
Are there more options? As the floppy emulation is missing, I am usure if the 4pin flat connector on top is for a floppy power cable or for something else?
A pictured guide would be awesome! :D
Re: Powering options for the CosmosEX Mini/MicroCosmos?
Postby simonsunnyboy » Mon May 15, 2017 5:53 pm
Addendum after the first test run, powering through the MicroUSB seems to work.
itaboy
Postby itaboy » Mon May 15, 2017 6:21 pm
It works, but there is no way to turn it off... unless unplugging it...
I must say I do not like a single bit the design of the main power, being so close to tha acsi port as to prevent the insertion of any cable... Should have been warned about this issue
leech
Postby leech » Fri Jun 09, 2017 8:44 pm
itaboy wrote:It works, but there is no way to turn it off... unless unplugging it...
https://www.amazon.com/LoveRPi-MicroUSB ... JXNKZT9BFY
These are great for that.
I have the full CosmosEx and still haven't figured out where/how I want to mount it yet.... but the UltraSatan has held me off from needing it too much.
nanard
Postby nanard » Thu Jul 06, 2017 7:44 am
Indeed the location of the miniUSB connector on the minicosmos should be revised in future versions.
It could be placed near the on/off switch, there is plenty of space there
ScreamingJoeBlade
Postby ScreamingJoeBlade » Thu Sep 21, 2017 8:51 pm
I know this is an old thread but another option is to find a switchable powerbar - I use an 8 outlet switch in a rack setup - I use my ataris with my music setup - I plug my ataris and CosmosEx devices into different power ports. This allows me to turn my CE units on first so they bootup and then I switch on my Atari units. Works like a charm plus you can talk through the whole process and sound like a NASA flight engineer! "Powering up CE" "CE is engaged and booting" We have a visual on boot lights -CE is booted" "Powering on STE" "We have a visual of STE boot process on the monitor!" Atari setup is go!" "Commence CUBASE session!"
Return to “CosmosEx”
