CTPCI and Realtek 8139D
JoeAtari
Re: CTPCI and Realtek 8139D
Postby JoeAtari » Mon Dec 31, 2018 3:32 am
Latz wrote:
@JoeAtari: lspci (and other "MinT executables") are intended to run in a UNIX-like
environment, which is not part part of FreeMinT snapshot. E.g. lspci should be started
from a shell (sh or bash) and exepts the executable "gzip" in path /bin/ or /usr/bin/ for
extracting the database file "pci_ids.gz". Without this file (or if "gzip" is not found),
lspci only shows numerical values instead of the names and parameters found in database.
I don't know your current MinT installation, so perhaps i explained things you already know...
Latz
I have the full mint install with the UNIX-like environment (I think). I just don't know what I am doing :-)
Here is what I tried:
root@easymint:/home>exec /home/lspci -vv -i /home/pci.gz
bash: /home/lspci: Permission denied
bash: exec: /home/lspci: cannot execute: Success
JoeAtari
Latz
Postby Latz » Mon Dec 31, 2018 8:21 am
JoeAtari wrote:I have the full mint install with the UNIX-like environment (I think). I just don't know what I am doing :-)
No problem, my first MinT experiences weren´t much better... :shrug:
JoeAtari wrote:Here is what I tried:
Some issues:
- Place lspci in folder /bin/ (or in one of the folders(paths) which are defined in mint.cnf/environment variable PATH). All UNIX
executables are there, according to the users access rights (root or user).
- Check that lspci is set to "executable".
- In bash, you don´t need to type "exec", the first command calls the executable in $PATH.
- You are already in folder /home (root@easymint:/home>), so you don´t need to enter /home once again. So enter:
lspci -vv -i pci_ids.gz
-vv defines the output level (v, vv or vvv)
-i defines path to database file
- output is displayed in bash
With
lspci -vv -i pci_ids.gz > pcilist.txt
the output is written as file /home/pcilist.txt
More: With
man <command>
in bash you get documentation for most executables e.g. "man cp" or "man ping".
I can´t attach the full "pciutils.tar.gz" archive here in forum...
Latz
Postby wongck » Mon Dec 31, 2018 9:59 am
It's a Unix-like environment.... no one knows what they are doing.
Unless the GUI is like blocks of building as in Jurassic Park movie.... "it's Unix I know this"... LOL
JoeAtari
Postby JoeAtari » Tue Jan 01, 2019 5:45 am
I had actually tried all of this with the exception of making lspci executable. I'm learning!
00:00.0 Bridge: PLX Technology, Inc. PCI9054 32-bit 33MHz PCI <-> IOBus Bridge (rev 0c)
   Subsystem: PLX Technology, Inc. PCI9054 32-bit 33MHz PCI <-> IOBus Bridge
   Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
   Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
   Latency: 8 (250ns min, 8000ns max), Cache Line Size: 32 bytes
   Interrupt: pin ? routed to IRQ 255
   Region 0: Memory at ffffff00 (32-bit, non-prefetchable) [size=256]
   Region 2: Memory at 10d80000 (32-bit, non-prefetchable) [size=512K]
   Expansion ROM at <unassigned> [disabled] [size=64K]
   Capabilities: [40] #00 [0000]
00:01.0 VGA compatible controller: ATI Technologies Inc RV280 [Radeon 9200 PRO] (rev 01) (prog-if 00 [VGA controller])
   Subsystem: Hightech Information System Ltd. Excalibur Radeon 9250
   Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
   Latency: 0 (2000ns min), Cache Line Size: 32 bytes
   Interrupt: pin A routed to IRQ 255
   Region 0: Memory at 40000000 (32-bit, prefetchable) [size=128M]
   Region 1: I/O ports at <unassigned> [size=256]
   Region 2: Memory at 60000000 (32-bit, non-prefetchable) [size=64K]
   Expansion ROM at 60020000 [size=128K]
   Capabilities: [50] Power Management version 2
      Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
      Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
00:01.1 Display controller: ATI Technologies Inc RV280 [Radeon 9200 PRO] (Secondary) (rev 01)
   Subsystem: Hightech Information System Ltd. Excalibur Radeon 9250 (Secondary)
   Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
   Region 0: Memory at <unassigned> (32-bit, prefetchable) [disabled] [size=128M]
   Region 1: Memory at <unassigned> (32-bit, non-prefetchable) [disabled] [size=64K]
00:02.0 USB Controller: NEC Corporation USB (rev 43) (prog-if 10 [OHCI])
   Subsystem: Belkin Root Hub
   Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
   Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
   Latency: 8 (250ns min, 10500ns max), Cache Line Size: 32 bytes
   Region 0: Memory at 60040000 (32-bit, non-prefetchable) [size=4K]
   Capabilities: [40] Power Management version 2
      Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
00:02.1 USB Controller: NEC Corporation USB (rev 43) (prog-if 10 [OHCI])
   Interrupt: pin B routed to IRQ 255
   Region 0: Memory at 60041000 (32-bit, non-prefetchable) [size=4K]
00:02.2 USB Controller: NEC Corporation USB 2.0 (rev 04) (prog-if 20 [EHCI])
   Latency: 128 (4000ns min, 8500ns max), Cache Line Size: 32 bytes
   Interrupt: pin C routed to IRQ 255
   Region 0: Memory at 60042000 (32-bit, non-prefetchable) [size=256]
00:03.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
   Subsystem: Allied Telesyn International Device c10f
   Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
   Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR+ <PERR+ INTx-
   Latency: 0 (8000ns min, 16000ns max)
   Region 0: I/O ports at 0100 [size=256]
   Region 1: Memory at 60042100 (32-bit, non-prefetchable) [size=256]
      Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1+,D2+,D3hot+,D3cold-)
JoeAtari
piku
Postby piku » Tue Mar 12, 2019 10:44 pm
Is there any source code for this anywhere? I ordered an RTL8139 and was sent an RTL8169. Maybe it could work.
EDIT nevermind I see there is source included with the download I have
Postby wongck » Wed Mar 13, 2019 12:39 am
piku wrote:EDIT nevermind I see there is source included with the download I have
Was that from sometime in 2018?
IIRC, Mikro did another XIF that was working for us. Not sure if he changed any code.
piku
Postby piku » Wed Mar 13, 2019 12:43 am
Maybe. I do see someone else had an RTL8169 as well. I wonder what changed with the inclusion of gigabit ethernet. I've asked the seller to send me the proper card I ordered. We'll see if it happens
Postby mikro » Wed Mar 13, 2019 6:58 am
piku: the "fixed" (big quotes here) version is actually based on my work here: https://github.com/mikrosk/freemint/tree/rtl8139
I just shaved a few unnecessary bits but to this day I don't really understand how it could improve anything. ;-)
That reminds me that I should really include this driver into upstream. IIRC I wanted to include most of the calls in the freemint kernel interface but Alan was against it for some reason.
EDIT: Found it: https://mikro.naprvyraz.sk/mint/freemin ... 01206.html
IMHO, we shouldn't rely on some hypothetical futuristic plans and just implement the kernel interface.
Postby mikro » Thu Mar 14, 2019 7:32 pm
mikro wrote:That reminds me that I should really include this driver into upstream. IIRC I wanted to include most of the calls in the freemint kernel interface but Alan was against it for some reason.
Nah, what the hell. I have merged it into upstream as is -- clearly it works for somebody better than the original driver and I can always improve it later. So you should find the driver in freemint 020+ snapshots from 1-19-848 onward. Feel free to give it a try, thanks to gcc 7.4.0 I found a couple of minor bugs, too.
arf
Postby arf » Thu Mar 14, 2019 8:22 pm
That one was hilarious!
Postby wongck » Thu Mar 14, 2019 10:53 pm
mikro wrote:So you should find the driver in freemint 020+ snapshots from 1-19-848 onward. Feel free to give it a try, thanks to gcc 7.4.0 I found a couple of minor bugs, too.
Thanks Mikro.
Will try over weekend if I have the time.
One OT question about mint-848.prg... must I have it by this name or can I rename it ?
( i.e. does it uses that 848 to find the mint system folder ?)
I uses the old-school installation method.
Postby mikro » Fri Mar 15, 2019 6:46 am
wongck wrote:One OT question about mint-848.prg... must I have it by this name or can I rename it ?
Yes, it's a kind of protection against messing your working system up. :) But that applies only to mint.prg, you can copy any other part of the distro wherever you want.
But I do remember about fixing the old school builds. In fact, I'm about 70% done but it's such a boring task I can force myself to work on it only a few hours per week. :-P
piku
Postby piku » Mon Mar 18, 2019 11:24 pm
I still have to read through this thread but it's not working for me. The device is found in the PCI list, the driver loads and the rtk0 device is there. However, when attempting to connect to something after configuring it says that it autonegotiated 100mbps full duplex but otherwise doesn't work and the out-errors counter goes up.
Postby wongck » Fri Mar 22, 2019 1:31 pm
Finally got some time to update my Mint to 848. The rtl8139 .xif works great.
Tested with iPerf on the old 2018 build and new 2019 build, no difference in throughput.
Thanks Mikro :cheers:
mikro wrote:Yes, it's a kind of protection against messing your working system up. :) But that applies only to mint.prg, you can copy any other part of the distro wherever you want.
This new way of release is actually easier to update, than the old school method, I do not have to rename MINT.PRG in the AUTO. I used to encode versions & architecture in the name so that I can still select the version & 060/030 depending. I don't really know why I kept the 030 version as I don't even remember the last time I used Mint on 030 mode.
I wonder why I had issues with this new method previously.... may be not enough sleep back then.
Return to “CT60 / CT63 Area”
