How to Test Mouse Buttons in Assembler
Postby rockyone » Mon May 08, 2017 4:17 am
How to do this test in assembler ?
As I still have not found, I retrieve the mouse address in the database.
Re: How to Test Mouse Buttons in Assembler
Postby AtariZoll » Mon May 08, 2017 6:38 am
There is no separated/specific mouse address. You can test it at low level by accessing ACIA for IKBD chip - address is $FFFC02. There is protocol for sending information about any change at mouse - movement, button press and release. First goes header, then status bytes. All it is well described in Atari ProfiBuch for instance.
Easier will be using BIOS function 11 Kbshift .
Postby rockyone » Mon May 08, 2017 8:10 am
Bios 11 returns the state of the keyboard, not the mouse buttons ???
Postby AtariZoll » Mon May 08, 2017 10:19 am
rockyone wrote:Bios 11 returns the state of the keyboard, not the mouse buttons ???
Well, that's is what Atari ProfiBuch says. Maybe that works only in mouse keycode mode.
May use AES call GRAF_MKSTATE (AES 79). There is VDI call too, but only for left button.
Here can DL test program with ASM source: http://atari.8bitchip.info/astopensw.php
Mouse and joystick tester.
seedy1812
Postby seedy1812 » Mon May 08, 2017 10:59 am
You can use Line A to get mouse buttons. Intitialise the table using $A000 and you get back the address of the table. MOUSE_BT which has the offset -596 ( word ) should contain a bitmap of the current mouse buttons
Postby rockyone » Mon May 08, 2017 3:31 pm
I tested at a low level, but I bug the mouse every time ......
thank you for your answers,
I had not thought about line A
The test I do currently works well, but well it's to find out ... :coffe:
move.w 4(sp), a0,.....VARPTR (MOUSEBUT) +6
tst.b 1(a0)
beq.s no_button
Postby czietz » Mon May 08, 2017 4:10 pm
I think that even it doesn't say so explicitly in ...
http://toshyp.atari.org/en/About_the_BIOS.html#Kbshift
... these bits only reflect the status of the mouse buttons emulated by Alt+Insert and Alt+ClrHome:
Bit Meaning
5 Right mouse button
6 Left mouse button
Postby czietz » Mon May 08, 2017 4:19 pm
Postby rockyone » Mon May 08, 2017 4:26 pm
czietz wrote:... these bits only reflect the status of the mouse buttons emulated by Alt+Insert and Alt+ClrHome:
Of course, the simulation of the buttons by the keyboard works well as well
Greenious
Postby Greenious » Mon May 08, 2017 5:16 pm
rockyone wrote:How to do this test in assembler ?
I did write a mouse/keyboard routine in assembler once. Pity I have no access to my sources or I would give it to you.
But what I remember is, if you are doing this by directly accessing the hardware, there is a special header coming from the IKBD indicating it's mousedata, followed by movement and/or buttonclicks. Movement can also be defined as either relative or absolute, ie, the movements either is direction/distance, or absolute position, you instruct the IKBD which way you want it.
viewtopic.php?t=5040
Postby rockyone » Mon May 08, 2017 8:40 pm
Too bad .. I would see this weekend, I think I had inverted $fc00 and $fc02.
I will also test with line A
joefish
Postby joefish » Fri May 12, 2017 3:50 pm
I haven't done it in years, but I seem to remember first you register an interrupt routine to respond to a signal from the keyboard chip.
Then you send a BIOS message to tell the keyboard chip to operate the mouse in either 'absolute-position' or 'relative' mode.
To read it, you use another BIOS call to poll the keyboard chip. Then about 5ms later your interrupt routine gets triggered with a report, and it can copy the mouse buttons and position status from a particular address.
I seem to remember you read the joystick(s) the same way. And it's a real nuisance as if you poll the mouse on the 50Hz interrupt, it responds with a high-priority interrupt when the first few lines of the screen are being drawn, which can interfere with your nice pretty raster colours on the line counter interrupt!
You'd have to look up the relevant BIOS calls yourself though.
Postby AtariZoll » Fri May 12, 2017 5:03 pm
joefish wrote:I haven't done it in years, but I seem to remember first you register an interrupt routine to respond to a signal from the keyboard chip.
That's only approximately accurate what you write. I can give here complete low level code what works on that base:
1. Setting ACIA MFP interrupt to own code - may with BIOS call or just simple write to $118
2. For relative mode no need to send anything , it's default. And since we talk about buttons, relative or. abs. mode is irrelevant.
3. To poll IKBD chip no need for special call - that's hob of our ACIA interrupt code.
Yes, joystick read is very similar. Actually, all it can be read with same interrupt routine, Together with keyboard read. That's what many SW does.And TOS too.
There is no high priority interrupt for ACIA actually - you can set IR level 7, and it will not interfere. And trigger delay is not 5mS, but whole time needed to read mouse is about it - because it must send 4 bytes in 4 steps for mouse. Datarate is some 7.8 Kbits/sec. So, little more than 1mS for 1 byte.
But much simpler is to do with help of TOS. Like it is done in given src code. (link above)
Parts of it:
  * Doing mouse pos displaying:
* AES call used
   graf_mkstate   *Get mouse cursor pos and button states
* here will get back all you need, following is only for displaying
   move.w  intout+2(pc),d1   *X pos
   cmp.w  lastx(pc),d1    * Skip if  not moved. otherwise cursor flashes
   beq.s  seeyp
   move.w  d1,lastx
   lea   text9(pc),a1
   bsr  decpri
* Redraw it:
   moveq  #HPOS,d0
   bsr   obdr
seeyp  move.w  intout+4(pc),d1   *Y pos
   cmp.w  lasty(pc),d1
   beq.s  drawmbs
   move.w  d1,lasty
   lea   text8(pc),a1
   bsr  decpri
* Redraw it:
   moveq  #VPOS,d0
   bsr   obdr
* Draw mouse button states only when changes:
drawmbs
  move.w  intout+6(pc),d1
  move.w  mouprev(pc),d2
  cmp.b  d1,d2
  beq.s  samemoub
* Setting joystick monitoring rutine :
   move.w  #34,-(sp)   *Kbdvbase
   trap   #14
   addq.l    #2,sp
   move.l  d0,a1
   lea 24(a1),a1   * Joystick vector
   move.l  (a1),joymorg  *Save original one (which is just an rts)
   move.l  #moni,(a1)
   joystol
  move.w  joyc(pc),joyst   *Store latest state
joytex
   rts
joyst  dc.w  0   *Latest joystick state
moni     * Joystick monitoring, very simple:
  * it is at joyvec address set with   XBIOS 34
    addq.l  #1,a0   *a0 is odd
    move.w  (a0),joyc    * first byte is for joy 0, second for joy 1
    rts
Doing it (mouse read) with Line-A table is simplest way, as some suggested.
Greenious
Postby Greenious » Fri May 12, 2017 5:28 pm
Atari Compendium, section 5:10
http://dev-docs.atariforge.org/files/Th ... endium.pdf
Every nitty gritty detail you need.
dhedberg
Postby dhedberg » Fri May 12, 2017 6:30 pm
This is probably overkill, but here's my custom ACIA handler. It can be used to read the keyboard, mouse and joysticks. It's pretty well documented. Feel free to use it... or ignore it! :-)
; Custom ACIA Interrupt Handler v1.3
; Custom ACIA handler for MIDI and IKBD. MIDI data is discarded. IKBD data is stored
; in custom data buffers.
; Functions:
; installAcia   Installs the custom ACIA interrupt handler. No registers modified.
; uninstallAcia   Uninstalls the custom ACIA interrupt handler and restores the old handler.
;               No registers modified.
; flushIkbd   Removes unread IKBD data from the ACIA. No registers modified.
; flushMidi   Removes unread MIDI data from the ACIA. No registers modified.
; Data:
; aciaKeyboardData   128 bytes
;         One byte is used for every key scan code. All bits of a byte are
;         set while the corresponding key is being pressed. Once the key is
;         released, all bits of the byte are cleared again.
; aciaMouseData      2 words + 1 byte
;         First word is the accumulated relative x position of the mouse,
;         second word is the accumulated relative y position. The byte
;         contains the most recent mouse button status, bit 0: left button,
;         bit 1: right button.
; aciaJoystickData   2 bytes
;         First byte is joystick 0 data, second byte is joystick 1 data.
; Author: Daniel Hedberg, daniel.hedberg@gmail.com
; Last Modified: 2014-01-07
   SECTION TEXT
; Function: installAcia
; Installs the custom ACIA interrupt handler.
installAcia:   movem.l   d0/a0,-(sp)      ; Save registers
      ; Clear keyboard buffer.
      lea   aciaKeyboardData,a0
      moveq   #128/4-1,d0
.clear:      clr.l   (a0)+
      dbf   d0,.clear
      bsr.s   flushAcia      ; Uses registers: d0.b
      ; Save current ACIA interrupt handler and install custom handler.
      move.w   sr,d0
      or.w   #$700,sr      ; Disable all interrupts
      move.l   $118.w,oldAcia      ; Save ACIA interrupt vector
      move.l   #acia,$118.w      ; Set ACIA interrupt vector
      move.w   d0,sr
      movem.l   (sp)+,d0/a0      ; Restore registers
      rts
; Function: uninstallAcia
; Uninstalls the custom ACIA interrupt handler and restores the old handler.
uninstallAcia:   movem.l   d0,-(sp)      ; Save registers
      move.w   sr,d0
      move.l   oldAcia,$118.w      ; Restore ACIA interrupt vector
      move.w   d0,sr
      move.l   (sp)+,d0      ; Restore registers
      rts
; Function: flushAcia
; Removes unread MIDI and IKBD data from the ACIA.
; Modified registers: d0.b
flushAcia:   move.b   $FFFFFC04.w,d0
      btst   #0,d0
      bne.s   .readMidi
      move.b   #0,$FFFFFC06.w
      bra.s   .flushIkbd
.readMidi:   move.b   $FFFFFC04.w,d0
      bra.s   flushAcia
.flushIkbd:   move.b   $FFFFFC00.w,d0
      btst   #0,d0
      bne.s   .readIkbd
      move.b   #0,$FFFFFC02.w
      rts
.readIkbd:   move.b   $FFFFFC02.w,d0
      bra.s   .flushIkbd
; ISR: ACIA
; Custom ACIA interrupt handler (main).
acia:      movem.l   d0-d1/a0,-(sp)      ; Save registers
; MIDI HANDLER
aciaMidi:   move.b   $FFFFFC04.w,d0
      btst   #7,d0         ; MIDI interrupt request?
      beq.s   aciaIkbd      ; No, check for IKBD interrupt requests
      btst   #4,d0         ; Framing error?
      bne.s   .midiError
      btst   #5,d0          ; Receiver (Rx data register) overrun?
      bne.s   .midiError
      btst   #6,d0         ; Parity error?
      bne.s   .midiError
      btst   #0,d0         ; Receiver (Rx data register) full?
      beq.w   aciaExit      ; No, nothing to read
      move.b   $FFFFFC06.w,d0      ; Read and throw away MIDI data
      bra.w   aciaExit
.midiError:   ; Make sure MIDI Rx data register is empty
      btst   #0,d0
      beq.w   aciaExit
      bra.s   .midiError
; IKBD HANDLER
aciaIkbd:   move.b   $FFFFFC00.w,d0
      btst   #7,d0         ; IKBD interrupt request?
      beq.w   aciaExit      ; No, nothing to do.
      bne.w   aciaIkbdError
      bne.w   aciaIkbdError
      bne.w   aciaIkbdError
      beq.s   aciaExit      ; No, nothing to read
      move.b   $FFFFFC02.w,d0      ; Read IKBD data
      cmp.b   #$F6,d0
      bcs.s   .readKeyboard
      cmp.b   #$FD,d0
        blt.s   .readMouse
.readJoystick:   and.w   #1,d0
      move.w   d0,ikbdIdentifier
      ; Set ACIA interrupt vector to handle joystick data
      move.w   sr,d1
      move.l   #aciaJoystick,$118.w   ; Set ACIA interrupt vector
      move.w   d1,sr
      bra.s   aciaExit
.readMouse:   and.b   #%11,d0
      move.b   d0,aciaMouseData+4
      clr.w   ikbdIdentifier
      ; Set ACIA interrupt vector to handle mouse data
      move.w   sr,d1
      move.l   #aciaMouse,$118.w   ; Set ACIA interrupt vector
      move.w   d1,sr
      bra.s   aciaExit
.readKeyboard:   btst   #7,d0
      seq   d1
      and.w   #$7F,d0
      move.b   d1,(a0,d0.w)
aciaExit:   bclr   #6,$FFFFFA11.w      ; Interrupt not in service
      movem.l   (sp)+,d0-d1/a0      ; Restore registers
      rte
aciaResetAndExit:
      ; Reset ACIA interrupt vector to main ACIA handler before exiting.
      move.w   sr,d1
      move.w   d1,sr
      bra.s   aciaExit
aciaIkbdError:   ; Reset ACIA interrupt vector to main ACIA handler.
      move.w   sr,d1
      move.w   d1,sr
      ; Make sure IKBD Rx data register is empty
.emptyRx:   btst   #0,$FFFFFC00.w
      beq.s   aciaExit
      bra.s   .emptyRx
; ISR: ACIA
; Custom ACIA interrupt handler (joystick).
aciaJoystick:   movem.l   d0-d1/a0,-(sp)      ; Save registers
      beq.s   aciaResetAndExit   ; No, reset ACIA interrupt vector and abort
      bne.s   aciaIkbdError
      bne.s   aciaIkbdError
      bne.s   aciaIkbdError
      lea   aciaJoystickData,a0
      move.w   ikbdIdentifier,d0   ; Joystick ID (0 or 1)
      move.b   $FFFFFC02.w,(a0,d0.w)
      bra.s   aciaResetAndExit
; ISR: ACIA
; Custom ACIA interrupt handler (mouse).
aciaMouse:   movem.l   d0-d1/a0,-(sp)      ; Save registers
      bne.s   aciaIkbdError
      bne.s   aciaIkbdError
      bne.s   aciaIkbdError
      beq.w   aciaResetAndExit   ; No, reset ACIA interrupt vector and abort
      move.b   $FFFFFC02.w,d0      ; Relative mouse position
      ext.w   d0
      lea   aciaMouseData,a0
      move.w   ikbdIdentifier,d1   ; Mouse axis (0 = x pos, 2 = y pos)
      add.w   d0,(a0,d1.w)
      tst.w   d1         ; More mouse data?
      bne.w   aciaResetAndExit   ; No, reset ACIA interrupt vector and exit
      move.w   #2,ikbdIdentifier   ; Mouse y axis is next
      bra.w   aciaExit
; SECTION DATA AND BSS
; IKBD DATA BUFFERS
   SECTION BSS
      even
aciaKeyboardData:   ds.b   128      ; Keyboard data
aciaMouseData:      ds.w   1      ; Relative mouse X position
         ds.w   1      ; Relative mouse Y position
         ds.b   1      ; Mouse button status
aciaJoystickData:   ds.b   1      ; Joystick 0 data
         ds.b   1      ; Joystick 1 data
; INTERNAL IKBD BUFFER
ikbdIdentifier:      ds.w   1
; SAVE DATA BUFFERS
oldAcia:      ds.l   1
   SECTION TEXT
seedy1812
Postby seedy1812 » Fri May 12, 2017 6:31 pm
If you look at 5.9 in compendium you can intercept the mouse vector and read the packet yourself ( then pass it onto the OS ).
Return to “680x0”
