New Internal Falcon PSU for CT60, CT60e, CT63...
Re: New Internal Falcon PSU for CT60, CT60e, CT63...
Postby joska » Mon Feb 05, 2018 9:30 pm
Have you seen this?
Postby troed » Mon Feb 05, 2018 10:05 pm
I had forgotten all about it :D Will print and see - thanks for the reminder!
/Troed
Atari74user
Postby Atari74user » Mon Feb 05, 2018 10:16 pm
That skipped me by, that's pretty cool too, thanks! I just spent 5 mins moving the STL around on my laptop because it looked so nice!
I think I might need to get out more 8O
alexh
Postby alexh » Mon May 20, 2019 10:10 am
Did this project get completed? I would really like a good quality internal PSU in my falcon 060
GoldenGrahams
Postby GoldenGrahams » Mon May 20, 2019 11:08 am
Hi, I remember reading this thread last year and thinking what a great project it was. So did 10p6 ever...
a) Release the 3D printable files for the PSU mount and the power/switch mount...?
b) Clarify exactly which PSU (or pico power brick) can be mounted to his 'PSU mount'. I'm sure the power brick that came with my genuine Pico PSU had no mounting points that match the 4 screw mounts on the 'PSU mount' pictured at the start of this thread. Please explain.
leech
Postby leech » Mon May 20, 2019 4:22 pm
GoldenGrahams wrote:Hi, I remember reading this thread last year and thinking what a great project it was. So did 10p6 ever...
I thought Joska posted something; http://atari-forum.com/viewtopic.php?f= ... 25#p316663 I've printed this, it fits nicely.
GoldenGrahams
Postby GoldenGrahams » Sat May 25, 2019 7:43 am
Yes I've printed Joskas plastic psu/switch cover and am taking a look at that now, but what about the metal PSU (brick) mount and psu/switch cover combo by 10p6 at the start of THIS thread?
It is the idea of securing the PSU brick of the PicoPSU INSIDE the Falcon that really interests me.
leech
Postby leech » Sun Jun 09, 2019 2:51 pm
Has 10p6 disappeared? He also had designs of a ne Jaguar controller that looked fantastic.
mpattonm
Postby mpattonm » Sun Jun 09, 2019 8:55 pm
I hate to dissapoint you guys, but its physically impossible to fit original PSU in CT60 accelerated Falc. Besides, original PSU is not compatible with CT60/e and while there are 3rd party COTS internal PSUs that might eventually fit inside and provide compatibble voltages, they do not work. Making a sutable bracket is actually the most simple part.
alexh
Postby alexh » Mon Jun 10, 2019 9:05 am
mpattonm wrote:I hate to dissapoint zou guzs, but its phzsicalz impossible to fit original PSU in CT60 accelerated Falc. Besides, original PSU is not compatible with CT60e
This thread is about the design of a new internal PSU compatible electrically and physically with the Falcon030 desktop case and CT60e. It is NOT about using the old one.
mpattonm wrote:while there are 3rd party COTS internal PSUs that might eventually fit be compatible, they do not work.
What does that mean?
jd
Postby jd » Mon Jun 10, 2019 11:09 am
Personally when my Falcon PSU died I never replaced it but took the internal PCB power connector outside the case and had a flying lead with a plug on it. I could then plug any ATX PSU into it. Extenal PSU I know but I could just extend the wires and hide it but I knew I would always have a rock solid easily replaceable PSU and that is something the Falcon needs to have.
Also frees up space in case for future upgrades etc.
mpattonm
Postby mpattonm » Fri Jun 14, 2019 6:47 am
Right. What I meant is there is no COTS AC/DC power supply that is known to be compatible with CT60. Basically, none of them (to my knowledge) works.
Postby joska » Fri Jun 14, 2019 7:29 am
GoldenGrahams wrote:Yes I've printed Joskas plastic psu/switch cover and am taking a look at that now, but what about the metal PSU (brick) mount and psu/switch cover combo by 10p6 at the start of THIS thread?
That design does not work, simply because the CT60 will not power on by switching on the PSU as that design does. Also, finding an ATX PSU small enough to fit inside the Falcon case is not easy.
GoldenGrahams wrote:It is the idea of securing the PSU brick of the PicoPSU INSIDE the Falcon that really interests me.
While I appreciate the original look of such a solution (I like my Ataris to look as standard as possible) there are two big advantages in an external power brick - it frees up space inside for the future SuperVidel and it moves the main heatsource out of the Falcon. But if you really want an internal brick I think the easiest solution is a PicoPSU and a small, internal 12V PSU.
