Proper Atari ST gray and 3D printing
This is the gallery. It's where we put the pictures upon pictures of us all showing off our dens and collections.
Postby troed » Wed Feb 22, 2017 8:27 pm
"Hey Troed. You know that Mega ST of yours with Alan H's MonSTer? Without external switches for TOSSEL and FLASHSW you're not really making much use of its flash rom functionality"
"Oh, and don't cut any holes in the original casing. But make it look nice."
Lessons learned:
FS 36307 does seem to be a perfect match for original Atari ST gray (I picked up this knowledge from a thread at Atari Age and hunted down a source for the color locally). However, most cases are quite yellowed - so compare with the tiny non-yellowed patch of the original part, or the top housing which is almost not yellowed at all. Also, I should probably invest in an airbrush to get an even paint layer.
Oh, and yes, a 3D printer does make it possible to keep the original housings intact in some cases ;)
mpattonm
Re: Proper Atari ST gray and 3D printing
Postby mpattonm » Wed Feb 22, 2017 9:09 pm
To my knowledge, these are matching color codes for ST line: 260/520ST is RAL 7044, anything higher is RAL 7038. I am not familiar with FS color coding system, but RAL should be recognised worldwide.
As regards to yellowing, why do not you give your ST nice slow peroxide bath? Just dip it fully in 15-20% liquid peroxide for one or two weeks, your plastics will be unrecognisable from new. Unlike different retrobright recepies, I suggest NOT to use any kind of UV light or even expose the bath to direct sunlight. UV light generally accelerates the whitening process, but if you go this direction you could realize in the end that surfaces under direct UV light were overbleached while rest might still be yellow. In any case you do not need it afterall. Indirect daylight is sufficient and safe.
Two more very important recommendations: Use just pure technical grade peroxide, do NOT mix it with anything else. And before you start with peroxide, thoroughly CLEAN and DEGREASE all the plastic. I am lazy person so I simply throw that plastic to dish wash mashine first (low temperature cycle), that is unless wife is watching, but then I at least properly brush it with Fairy anyway. If possible last cleaning round is alcohol one.
Postby troed » Wed Feb 22, 2017 9:58 pm
RAL 7038 seems to be FS 36440
FS 36307 would then be RAL 7030
(according to http://www.brunelhobbies.com.au/lifecolor/comptable.pdf )
Regarding peroxide baths it's my understanding that the effect is only temporary.
mpattonm
Postby mpattonm » Thu Feb 23, 2017 1:56 pm
Well you decide. The floppy drive is taken out from 1040STF, the chassis is from 520ST. They are both in pretty original condition, well preserved.
http://www.imagehosting.cz/?v=wp20170223.jpg
http://www.imagehosting.cz/?v=wp2017fmf.jpg
http://www.imagehosting.cz/?v=wp2017uiu.jpg
Postby joska » Thu Feb 23, 2017 2:21 pm
Nice :)
I found another solution to the "don't want to modify the case"-problem. I'm snooping on keyboard traffic using a microcontroller, so I can switch TOS with the keyboard.
crashman
Postby crashman » Thu Feb 23, 2017 2:31 pm
Hi Troed,
could you share the 3D file?
Postby troed » Thu Feb 23, 2017 4:31 pm
crashman wrote:Hi Troed,
https://troed.ddns.net/f/7608d54a17/
I print on an Ultimaker 2, front face down, with supports. The holes are made to spec for these slide switches:
https://www.elfa.se/en/slide-switch-on- ... simi=88.37
/Troed
crashman
Postby crashman » Thu Feb 23, 2017 4:38 pm
Postby troed » Thu Feb 23, 2017 4:40 pm
crashman wrote:Thanks!
Actually I just assumed the .STL was enough - let me know if you want another format more suitable for your own editing :) I CAD in Autodesk Fusion 360.
/Troed
tzok
Postby tzok » Fri Feb 08, 2019 1:27 pm
I have painted ST case with RAL 7044 and it is far to bright. I think RAL 7032 is a better match.
Colors worth checking are (from lightest to darkest):
7044, 7032, 7038, 7030
Now I tried 7030 (as it was mentioned in a few threads), an it is way too dark (yet it looks nice).
Return to “Gallery”
