Steem SSE 3.9
Re: Steem SSE 3.9
Postby Steven Seagal » Sun Nov 26, 2017 2:08 pm
AtariZoll wrote:I would to ask what is situation, what are plans about Linux builds ? As I see latest v. for Linux is 3.7 . I'm aware that it is lot of extra work, so other platform has priority. And Linux distros make it not easy in fact. They make lot of changes, so old builds may not work as well. I experienced it myself with my SW.
Unfortunately I was not able to start 3.7 in Ubuntu - it says that file is not executable, although properties say that it is ???? Confused. especially as old Steem 3.2 started, only problem is that no sound (but it needs just installing Portaudio) .
Hi, I'd rather you had bumped the "Linux/Unix build" thread instead.
It's a question of fun, time and priorities.
The Linux build scores very low in all three aspects for me. More a drag than anything. :(
Beside the problems you mentioned, don't forget that when you release more builds, you must give some support too.
BlankVector
Re: Steem SSE 3.9
Postby BlankVector » Sun Nov 26, 2017 2:19 pm
AtariZoll wrote:Unfortunately I was not able to start 3.7 in Ubuntu - it says that file is not executable, although properties say that it is ???? Confused.
I recently hit the same issue on latest Ubuntu, and I finally got it working.
Key point is that Steem binaries are 32-bit, and your system is 64-bit. Hence "not executable" message.
You need to install the 32-bit executable support on your OS (i386), libc, and a few other libraries.
It is just a matter of adding a few additional packages. Unfortunately, I dumbly didn't take any note, so I can't help more precisely.
Re: Steem SSE 3.9
Postby AtariZoll » Sun Nov 26, 2017 2:23 pm
Ah, did not see that separated thread, it is very low (last post spring of 2016) .
"release more builds, you must give some support too." - well, I forgot about it totally, but maybe because my recent activity was about project where giving support to users is something at last place :D
I appreciate your straight and honest answers.
Re: Steem SSE 3.9
Postby AtariZoll » Sun Nov 26, 2017 2:25 pm
That makes sense. But Steem 3.2 is 32-bit too (and very old), and it worked ... Anyway, I will try to install suggested. Thanx.
Re: Steem SSE 3.9
Postby Steven Seagal » Sun Nov 26, 2017 2:31 pm
To be fair we all do what we can but giving support isn't much fun compared with improving emulation or introducing exciting features. I certainly didn't branch Steem to give support but that's the way it is. :mrgreen:
BlankVector
Re: Steem SSE 3.9
Postby BlankVector » Sun Nov 26, 2017 2:42 pm
BlankVector wrote:I dumbly didn't take any note, so I can't help more precisely.
By digging in my shell history, the following should be enough do get XSteem 3.7 working in recent Ubuntu 64-bit:
sudo dpkg --add-architecture i386
sudo apt install libstdc++6:i386 libxxf86vm1:i386 libasound2:i386
Re: Steem SSE 3.9
Postby Steven Seagal » Thu Nov 30, 2017 9:57 am
Steem SSE 3.9.4 was released on 30/11/2017.
v3.9.4 Features
_________________
- Dongles: Jeanne d'Arc (French).
- A DirectDraw build of the Boiler is now available.
- Notice:
Option 'Alt YM2149 emu' (MAME-like PSG emulation) moved to sound page.
Option 'Machine/Wake-up' is now persistent (and the default is STE
demo-friendly as requested).
v3.9.4 Emulation improvements
_______________________________
- CPU: STOP timing and behaviour (Audio Sculpture, thx ijor, npomarede and
troed).
v3.9.4 Bugfixes / Refactoring
- Can recover from a BLIT ERROR and from 6301 crash in some cases.
- Video rendering of STE hscroll with normal borders (We Were "distorter").
- Sound: STE DMA sound in 16bit mono.
Pro Sound Designer in 16bit (Wings of Death, Lethal XCess STF).
- CPU: RTE check new PC for crashes.
BTST timing (Phaleon/Chaotic Motion Interferer).
- GLUE: Timer B in shift mode 0 or 1 on a monochrome display (Audio
Sculpture).
No left border and no-prefetch hscroll (Hard as Ice)
- FDC: Only type 1 commands can be changed while the drive is spinning up
(Froggies Over The Fence).
Run commands even if current drive isn't connected (Audio
Sculpture STF).
- WD1772: Negate motor line on reset (Audio Sculpture SCP - undoubtly the star
program of this release if you see all the fixes it caused).
Reload first rev at first opportunity (Turrican SCP 2 revs).
- MFP: Reading a timer when it just looped (Froggies Over The Fence back to
menu after disk 2).
Make MFP timer latency one cycle longer (Sadeness on STF WU1).
- 6301: Mouse movement in high resolution and when the ST is much accelerated.
Option C1 compatible with non-English keyboards and key combinations.
Download
__________
http://sourceforge.net/projects/steemsse/
http://ataristeven.exxoshost.co.uk/Steem.htm
EDIT: the wrong build (64bit) was set as default in sourceforge yesterday.
lotek_style
Mod(ul)erator
Mod(ul)erator
Re: Steem SSE 3.9
Postby lotek_style » Sun Dec 03, 2017 9:16 am
Steven: I'm just trying out Steem V.3.9.4 and setting screenshots to PNG still gives me BMP... any setting that I missed?
Return to “Development”
