[Solved] MiST Hardware Revisions? MSX-Core-Problem
guidol
Postby guidol » Mon Dec 19, 2016 11:07 am
Does anyone got informations about differnt hardware revisions on the MiST?
I got a MiST-MIDI which I did buy in April 2015 and one MiST-MIDI which I did buy in September 2016.
Booth have now the FW (Firmware) s/w ver. ATH160721 - but
the MiST out of 2015 does load the MSX2-BIOS for the MSX-Core and the MiST out of 2016 keep hung at loading the MSX2-BIOS
and Iam using the same SC-Card and Cables.
Now I have sent a Mail to Lotharek - asking if he changed the mainboard or mainboard-components... if I get an answer you will read it here :)
guidol
Re: MiST Hardware Revisions? MSX-Core-Problem
Postby guidol » Mon Dec 19, 2016 11:23 am
a small Info in MiST-GitHub
https://github.com/mist-devel/mist-boar ... ingStarted
The pre-installed firmware version
The MIST board uses a permanently installed firmware in on-board flash as well as the called FPGA core file on SD card. Since both parts evolve over the time they need to be from roughly the same time. If the versions of the firmware and the core differ too much then the core may not boot (but no harm will/can be done).
Up to now two firmware versions have been installed in MIST boards before shipment.
If you purchased your board before May 2015 or if you got an older board from the third party you need to use the early core mentioned for your first tests.
Since May 2015 Lotharek started to flash boards with a firmware from April 2015. That version requires a more recent core. You need to rename this core to core.rbf before placing it on the SD card.
Postby Newsdee » Mon Dec 19, 2016 1:09 pm
Firmware isn't hardware though? I'd expect both hardware to behave the same given identical fw?
guidol
Postby guidol » Mon Dec 19, 2016 2:11 pm
Newsdee wrote: I'd expect both hardware to behave the same given identical fw?
I did also expect the same behavior, but the newer one doesnt do that - with the same firmware - what the older one did/does.
sebdel
Postby sebdel » Tue Dec 20, 2016 9:43 am
Might just be an unstable core. From my experience the smallest glitch in certain clock signals can make the core startup completely random. I would not be surprised if the NES core never booted on a certain number of MiST for example but I can't prove it and I also don't know if I fixed it :)
The RAM is also not always in the same state at core startup, that can have an effect. Did you try cold boot on both ? And by cold I mean at least a minute without power!
jotego
Postby jotego » Tue Dec 20, 2016 1:37 pm
sebdel wrote:Might just be an unstable core. From my experience the smallest glitch in certain clock signals can make the core startup completely random. I would not be surprised if the NES core never booted on a certain number of MiST for example but I can't prove it and I also don't know if I fixed it :)
I agree. I wouldn't be surprised if timing is not constrained with enough detail in this core, or maybe constrains are not being met at all... Sadly, implementation is somehow disregarded in open source hardware projects.
My Patreon page here.
guidol
Postby guidol » Tue Dec 20, 2016 7:00 pm
Lothrek did answer "nothing has changed since beginning..bill of materials is the same".
But MasterOfGizmo (Till Harbaum) did answer me also, telling that core like the MSX-Core do overclock some parts of the FPGA.
Some FPGA-Chips could be more overclocked as other ones (like some Motorola-Chips in AMIGAs or the CPU ony some Raspberry Pi) and run stable.
The overclocking will not damage the FPGAs, but the core will hang.
Her did also write:
"Building the same core another time results in slightly different cores.
In simple words: Sometimes the software can choose which of the many wires
inside the FPGA to use for what and it randomly chooses one. And if a core is
close to the edge then these minor differences may again make a difference."
So there would be a chance that one of the other versions of the MSX-Core will run your MiST.
The 3 MSX-Cores are at
https://github.com/mist-devel/mist-bina ... /cores/msx
ocmsx_141010_r356.rbf
ocmsx_141012_r359.rbf
ocmsx_141022_r364.rbf
Asmith
Postby Asmith » Wed Dec 21, 2016 7:45 pm
Tried the 3 Msx cores , still no luck , it seems the MSX core is not for my MIST ...
A_s
DrOG
Postby DrOG » Wed Dec 21, 2016 8:32 pm
The same result at me...
ManuFerHi
Postby ManuFerHi » Fri Dec 23, 2016 1:27 am
I´m made some PCB mist boards, the problem is DRAM memory, the original reference MT48LC16M16A2P-75 is obsolete and replacement like MT48LC16M16A2P-7E or other similars are differents timings, all cores running OK, except MSX core crashes before load bios file.
DrOG
Postby DrOG » Fri Dec 23, 2016 3:37 am
Actually besides the MSX core the Acorn Archimedes is problematic too, dont't know if it's for the same reason or not, but the Archie is very picky in aspect of SD-cards...
dhester
Postby dhester » Fri Dec 23, 2016 7:18 pm
I don't know if it will help but I got an msx core to work on a ZX Uno with various sd cards and loading the core on the ZX Uno, I also have used various SD Cards and got it working on the MIST.
ManuFerHi
Postby ManuFerHi » Fri Dec 23, 2016 8:58 pm
DrOG wrote:Actually besides the MSX core the Acorn Archimedes is problematic too, dont't know if it's for the same reason or not, but the Archie is very picky in aspect of SD-cards...
Can you see reference of DRAM memory?
MT48LC16M16A2P-75 >> MSX core works perfectly
MT48LC16M16A2P-7E o other memory don´t load bios file.
DrOG
Postby DrOG » Sat Dec 24, 2016 3:48 am
Nothing similar:
hynix 948EA
H57V2562GTR-75C
On my Turbo Chameleon 64 the MSX core works flawlessly.
The ZX Uno is not bad either, but it has only one joystick port, i need more! ;-)
ManuFerHi
Postby ManuFerHi » Sat Dec 24, 2016 9:53 am
DrOG wrote:Nothing similar:
hynix 948EA
H57V2562GTR-75C
That is the cause, that memory has different timings to the previous ones and it is necessary to modify the core.
Zx-Uno only supports MSX1.
ManuFerHi
Postby ManuFerHi » Sat Dec 24, 2016 10:04 am
hynix 948EA
H57V2562GTR-75C
That is the problem, for some strange reason the MSX core only works with the memories MICRON MT48LC16M16A2P-75
Zx-Uno only support MSX1.
ManuFerHi
Postby ManuFerHi » Mon Dec 26, 2016 9:05 pm
New core published today, fix SDRAM memory problem, i´m tested in various sdram models and work in all fine. Problem fixed.
Sinclair
Postby Sinclair » Mon Dec 26, 2016 9:33 pm
This is very good news because it gave me the impression that the project was dead for the time it took without updating. :cheers:
© 1982 Sinclair Research Ltd
guidol
Postby guidol » Tue Dec 27, 2016 7:13 am
ManuFerHi wrote:i´m tested in various sdram models and work in all fine. Problem fixed.
Also on my newer 2016 MiST the new MSX-Core does load the MSX2-BIOS without problems :)
So sometimes we have only to ask the right people :)
Thanks to Alastair Robinson and Till Harbaum :)
Asmith
Postby Asmith » Tue Dec 27, 2016 10:25 am
What a great Xmas present ! Thanks everybody for this effort ! :)
A_s
DrOG
Postby DrOG » Tue Dec 27, 2016 11:56 am
Thanks everybody who was involved to fix the memory bug!
It runs now flawlessly on my new MIST, boots for the first time with MSX3BIOS.SYS!
It would be nice to improve the Acorn Archimedes core in the same aspect...
Thanks again this nice Christmas present!
vebxenon
Postby vebxenon » Tue Dec 27, 2016 2:23 pm
Great news! :D
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Re: [Solved] MiST Hardware Revisions? MSX-Core-Problem
Postby vebxenon » Tue Jan 10, 2017 7:37 am
Well, new core doesn't work well to me. I'm using again previous version.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Sinclair
Postby Sinclair » Tue Jan 10, 2017 10:23 am
The latest version gives me problems accessing the disk.
I went back to the previous version.
I am one of those who have the original RAM.
vebxenon
Postby vebxenon » Tue Jan 10, 2017 4:00 pm
Sinclair wrote:The latest version gives me problems accessing the disk.
Same here :shrug:
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Users browsing this forum: No registered users and 13 guests
