Hatari 2.0 beta to test for windows
npomarede
Postby npomarede » Wed Oct 12, 2016 4:58 pm
in order to prepare next release, I uploaded some beta binaries for windows. As for previous releases, there's a version for 32 bit (windows xp) and more recent 64 bit windows.
http://download.tuxfamily.org/hatari/test_2.0.0/
hatari-2.0.0_windows64.zip
hatari-2.0.0_windows.zip
For people using windows, could you try those binaries ? I tested the 32 bit version, but as I don't have a 64 bit windows, I would be interested in feedback too (ie does Hatari starts)
Re: Hatari 2.0 beta to test for windows
Postby Cyprian » Wed Oct 12, 2016 5:01 pm
hatari-2.0.0_windows64 doesn't work on my 64bit Win7 - error 0xc000007b
npomarede
Postby npomarede » Wed Oct 12, 2016 6:03 pm
Cyprian wrote:hatari-2.0.0_windows64 doesn't work on my 64bit Win7 - error 0xc000007b
did hatari 1.9 worked ?
do you see any error message if you run it from a "command" windows ?
Postby AtariZoll » Wed Oct 12, 2016 6:03 pm
Same here in Windows 10 64-bit.
BoNuS
Postby BoNuS » Wed Oct 12, 2016 6:39 pm
Same here, 64bit Win7 - error 0xc000007b.
1.9 does work !
http://bonus.home.xs4all.nl/
2 x Falcon 030 - a mint Atari TT - Mega STE - 2x STE - 1x Mega 2 - 2x STFM - 1 x STF - 3x SC1224 - 2x SM124 - 1x SM125 2x Portofolio+interface
- 3x 1435 monitor - 1 x Ult.Ripper cardridge - Mega 1,2,and 4 ( just to much Atari stuff)
npomarede
Postby npomarede » Wed Oct 12, 2016 7:04 pm
error 0xc000007b often means DLL error ; in that case I put a 32 bit version of a dll instead of the 64 bit version :(
Could you test again with hatari-2.0.0_windows64.zip (size 3681942 bytes) ?
OL
Postby OL » Wed Oct 12, 2016 7:09 pm
npomarede wrote:error 0xc000007b often means DLL error ; in that case I put a 32 bit version of a dll instead of the 64 bit version :(
Work for me on Win7 64!
It not fix my bugs ;-)
Olivier
OL
EvilFranky
Postby EvilFranky » Wed Oct 12, 2016 7:26 pm
New ZIP works for me on Windows 10 x64 :)
npomarede
Postby npomarede » Wed Oct 12, 2016 7:58 pm
OL wrote:It not fix my bugs ;-)
Olivier
I didn't follow the whole thread about your multitasking problem, but I'm sure Eero will be able to help with it.
npomarede
Postby npomarede » Wed Oct 12, 2016 7:59 pm
OK, thanks to all for testing ; I recently updated my mingw compiler chain and I needed to be sure compiled binaries were still correct.
Nicolas
helmut
Postby helmut » Wed Oct 12, 2016 8:36 pm
The win64-version crashes causes bombs (!) in MiNT, while 1.9 works.
To reproduce see:
viewtopic.php?f=51&t=29989&start=50#p302084
Also all supplied dlls from the archive should have the executable bit set, though that's easy to fix.
npomarede
Postby npomarede » Wed Oct 12, 2016 8:48 pm
helmut wrote:Also all supplied dlls from the archive should have the executable bit set, though that's easy to fix.
Are you sure of that ? I never experienced problem running under windows when dll came from a zip and had no exe bit (I'm not even sure this notion exists under Windows ? Only under Linux/OSX ?)
highway
Postby highway » Wed Oct 12, 2016 9:10 pm
Works fine for me too, with Win 10.
Great application !
Postby Cyprian » Wed Oct 12, 2016 9:13 pm
works fine now. thanks
highway
Postby highway » Wed Oct 12, 2016 9:31 pm
ST / STE version works fine
But I were unable to launch a Falcon ROM, is it compatible ?
npomarede
Postby npomarede » Wed Oct 12, 2016 9:47 pm
highway wrote:ST / STE version works fine
Yes, it works with Falcon too. Just open TOS4.04 for example and Hatari will switch to Falcon mode.
helmut
Postby helmut » Wed Oct 12, 2016 10:28 pm
I run it from a cygwin-shell. Maybe that causes it.
highway
Postby highway » Thu Oct 13, 2016 8:10 am
Thanks, it seems strange on mine : I tried with this TOS, and I have a screen with strange behaviour (colored line, Atari logo duplicated, ...)
Any ideas ?
npomarede
Postby npomarede » Thu Oct 13, 2016 9:29 am
highway wrote:Thanks, it seems strange on mine : I tried with this TOS, and I have a screen with strange behaviour (colored line, Atari logo duplicated, ...)
Any ideas ?
Do you have a screenshot of this ?
highway
Postby highway » Thu Oct 13, 2016 9:51 am
I'll do it tonight
npomarede
Postby npomarede » Thu Oct 13, 2016 9:55 am
Also, does it change if you press "F11" to toggle fullscreen on/off ?
squall
Postby squall » Thu Oct 13, 2016 11:42 am
Tested on Windows8-64bit. Mostly runs fine.
Only issue I've found so far is that fullscreen mono tries to span across multiple screens for some reason, color monitor is fine. (It worked properly in v1.90)
https://youtu.be/Q5Q3d60OIRI
Easier to see in action then explain :P
npomarede
Postby npomarede » Thu Oct 13, 2016 11:58 am
Very strange indeed :) Does it change if you start Hatari from the other (bigger) monitor before going mono ? But I'm not sure I can do anything about this at the moment, I don't have 2 monitors and I don't use windows :)
highway
Postby highway » Thu Oct 13, 2016 6:48 pm
Here is the result I got :
I'ts when trying to change atari resolution to 1024x768
When keeping the default one (but, small) it seems to work fine
squall
Postby squall » Thu Oct 13, 2016 9:48 pm
npomarede wrote:Very strange indeed :) Does it change if you start Hatari from the other (bigger) monitor before going mono ? But I'm not sure I can do anything about this at the moment, I don't have 2 monitors and I don't use windows :)
Yeah, still happens when I start from the other monitor.
I've done some more tests and it does not seem to be multi-monitor related and probably an issue with how the display surface is setup in mono mode as the screen is still zoomed in even with just one monitor. If I reduce my native resolution from 3840x2160 down to something like 1280x720, I can see the mono view correctly.
If I get some time, I might try to setup a dev environment for Hatari on windows and see what the problem is.
Return to “Hatari”
