SAM Coupe core for MiST
Gehstock
Re: SAM Coupe core for MiST
Postby Gehstock » Wed Aug 30, 2017 9:54 pm
jamesrc
Postby jamesrc » Tue Oct 31, 2017 10:17 pm
Can someone validate something for me before I post another issue on the MiST Sam Coupé Github?
Download Fred 82:
http://www.worldofsam.org/node/659
Insert the disk image to the virtual MiST Sam Coupé drive.
Boot the disk (is automatic from the startup screen, or press F9).
Press A for the Editorial.
I get a "File Not Found" *every* time, but if I then GOTO the line it's failing on (I think GOTO 490 but I'm not home to check) it launches.
It works properly on the Simcoupé emulator, as well as on a real SAM. (Okay, so I haven't tested it on my SAM in 2017, because I don't have an appropriate power supply or video cable here in the states, but it sure as hell worked on my real SAM when I received this issue of Fred back in the day).
danielb
Postby danielb » Thu Nov 02, 2017 8:39 pm
Seems to work OK for me, using the second newest Sam Coupe core.
The newest core (SamCoupe_20170206.rbf), as pointed out previously, is quite erratic. The Lyra demo, for instance, does not run all the way through. The second newest core (SamCoupe_20170112.rbf) appears to be stable and everything runs fine.
I've never used a real Sam, so I can't comment as to how close it to the real thing.
D.
SirDavid
Postby SirDavid » Sun Nov 26, 2017 8:43 am
Works OK with the newest core, too (20170206). Maybe jamesrc used older one? Or he has to update MiST firmware?
Higgy
Postby Higgy » Mon Sep 10, 2018 9:19 pm
@Sorgelig - I saw that you updated some of the Core parts (for MiSTER I think). I installed the Altera software and built a new Release from your sources and it works on my MiST. :D
Remember I had issues (RAM timing?) with the last Core Release.
To save you building the Core I could attach it to a post with the name of your choice - SamCoupe_201870910.rbf ? or will you build yourself?
Is it easy to add 'Reset' to the OSD menu? Saves having to get up and press 'Reset' on the actual MiST box :lol:
Postby Sorgelig » Mon Sep 10, 2018 10:10 pm
if you plan to work on cores, then i suggest to fork it to your own repository and then release from there.
desUBIKado
Postby desUBIKado » Tue Sep 11, 2018 8:56 am
@Sorgelig. Was there any reason why you did not create the binary version on 2018.08.10 that included the changes?
Postby Sorgelig » Tue Sep 11, 2018 9:21 am
i don't remember why.
Anyway, i've released the binary. But it's not tested.
desUBIKado
Postby desUBIKado » Tue Sep 11, 2018 9:36 am
Thanks a lot. Don't worry for that, I will test it and say you something if there is some issue.
DanyPPC
Postby DanyPPC » Tue Sep 11, 2018 1:57 pm
Tested with success this SamCoupè core, beautiful retro-system which I did not know.
Great !
DanyPPC
Postby DanyPPC » Tue Sep 11, 2018 3:16 pm
Does anyone know how to load Pang?
https://www.worldofsam.org/products/pang
And how can I create a disk directly with the game?
I have no experience with this system.
Thanks for the help
desUBIKado
Postby desUBIKado » Tue Sep 11, 2018 7:50 pm
Hello DanyPPC:
I have converted starsandsprites.dsk to MGT format disk with this tool: SAMdisk and I've created this sasprites.dsk that it works fine in Sam Coupé core.
sasprites.dsk.zip
I can't create a disk with only Pang game because I can't get colon caracter : with the keyboard :(
@Sorgelig: Could you please look at the definition of the keyboard and the reason why the colon character does not appear? Thank you.
--- ooo OOO ooo ---
EDIT: I tryed on my ZX-Uno with the Sam Coupé core by McLeod_Ideafix
On ZX-Uno
(with no SHIFT key pressed) n m , . -
(with SHIFT key pressed) N M ; : _
On MiST
(with no SHIFT key pressed) n m , . /
(with SHIFT key pressed) N M , . / <-- same characters
Postby Sorgelig » Tue Sep 11, 2018 10:25 pm
you need to use right shift, not left.
desUBIKado
Postby desUBIKado » Wed Sep 12, 2018 4:52 am
WTF! I tried left shift, left ctrl, left alt, Alt Gr, Windows key, right Alt and right ctrl, but never, never, tried right SHIFT :)
Thanks Sorgelig.
DanyPPC
Postby DanyPPC » Wed Sep 12, 2018 6:41 am
desUBIKado wrote:I have converted starsandsprites.dsk to MGT format disk with this tool: SAMdisk and I've created this sasprites.dsk that it works fine in Sam Coupé core.
Ok, I had also converted the disk formato to DSK, but after the demo ends how do you access the game ?
Higgy
Postby Higgy » Wed Sep 12, 2018 7:21 am
@desUBIKado - can you attach the 'Pang only' disk please :D
And if anyone has a good collection of converted Sam Coupe disks they could attach/upload... :wink:
It is a nice system, we nearly bought one when our Spectrum died but... in the computer shop they had an AMIGA 500 (jaw drop!). In the the age before internet and only buying CRASH or Sinclair User magazine we did not know that the AMIGA even existed! Certainly exciting times back then.
Anyway I digress, glad the latest Core seems to work with all MiST PCB's and we can enjoy this rare very capable retro computer. Nice work again sorgelig 8)
DanyPPC
Postby DanyPPC » Wed Sep 12, 2018 8:49 am
Success !!!
1 - use SAMDisk to create a Blank diskette from (SAMDisk CREATE Blank.mgt)
2 - launch SamCoupe Core with allowed disk access, press RETURN to enter Basic
3 - insert MasterDOS 2.3 in Drive 1 and Blank diskette in Drive 2
4 - Reset (CTRL+F11) and Press F9 to boot MasterDOS
5 - insert "Stars and Secret" disk in Drive 1
6 - from command line digit:
COPY "d1:secret" TO "d2:secret"
7 - now insert SAMflate Disk in Drive 1 and digit:
COPY "d1:samflate.O" TO "d2:samflate.O"
8 - now insert Blank diskette in Drive 1 and digit and run the following Basic Program:
10 CLEAR 32767: LOAD "samflate.O" CODE 16384*28+8192: LOAD "secret" CODE 16384*14
20 CALL 16384*28+8192, 16384*14, 32768
30 SAVE "auto" CODE 32768, 390781, 32768
9 - after all is ok you can boot from MasterDOS 2.3 in Drive 1, insert Blank "Pang" diskette in Drive 1 and digit from commandline "BOOT"
10 - Pang will boot !!!
DanyPPC
Postby DanyPPC » Wed Sep 12, 2018 9:22 am
If you want an autobootable disk you can use a SamDOS2 disk where copy the three files "auto", "samflate.O" and "secret",
then you have a Bootable disk with the following files:
samdos2
auto
samflate.O
secret
Hope it's useful
desUBIKado
Postby desUBIKado » Wed Sep 12, 2018 5:42 pm
Hi DanyPPC:
I had not seen your post, and had followed the instructions at the bottom of the page https://www.worldofsam.org/products/pang
and I created the disc with the game.
Here is the game (although it's more fun to do it yourself):
Pang.dsk.zip
vebxenon
Postby vebxenon » Wed Sep 12, 2018 6:38 pm
desUBIKado wrote:Hi DanyPPC:
Pang.dsk.zip
Wow! :cheers: Thanks very much! :D
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
desUBIKado
Postby desUBIKado » Wed Sep 12, 2018 7:57 pm
Sorgelig wrote:you need to use right shift, not left.
Sorry for not reading the instructions more carefully
I see that in the section of the keyboard it is not indicated that the EDIT key of the SAM is mapped to the left Windows key of the PC keyboard
On the other hand, could you map the CNTRL key of the SAM to both CTRL keys on the PC keyboard, and the EDIT key of the SAM to both Windows keys Left windows key of PC keyboard and change the EDIT key of SAM to right windows key?
The CNTRL key would be useful to map a series of graphic characters with keys 1 to 8.
Higgy
Postby Higgy » Sat Sep 15, 2018 7:36 pm
How does the Stereo SAM DAC on LPT1 work?
I tried the attached demo - astro2 It gives a list of sound options, if I select '4' which is Stereo DAC on LPT1 I don't get any sound out of the 3.5mm audio jack? The normal Sam sound chip works fine.
astro2_mgt.zip
desUBIKado
Postby desUBIKado » Sat Sep 15, 2018 9:08 pm
This afternon I tried Bunnik 2000 demo on simcoupe. I selected option 4)SAMDAC on LPT1. and the music didn't sound. On Parallel port i got "SAMDAC (8-bit stereo)". When I've changed to "DAC (8-bit mono)" the music has sounded. Now I tried astro2 demo and pass the same.
vebxenon
Postby vebxenon » Mon Sep 30, 2019 8:11 pm
Hi :D
I've been tested new games for Sam Coupé, and some games that boot correctly on SimCoupé Emulator, like Wubtris https://sam.speccy.cz/games/wubtris_mgt.zip don't boot :shrug: on MiST Core.
Can you please test it? Thanks!
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Postby vebxenon » Wed Oct 16, 2019 8:15 am
vebxenon wrote:Hi :D
Nobody?
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
