SAM Coupe core for MiST
SirDavid
Re: SAM Coupe core for MiST
Postby SirDavid » Sat Jun 11, 2016 11:47 am
Sorgelig wrote:Actually, this core is open source and anyone can add more features :) I prefer to focus on features giving some noticeable advantages.
I'd like to try, but first I have to learn how to build a core from your sources...
Postby Sorgelig » Tue Jun 14, 2016 4:59 pm
New release:
- FDC code has been greatly reworked. Now you can write to both EDSK and MGT images.
- Remove SDF support to reduce complexity of code. SDF is superseded by EDSK. Use SAMdisk utility to convert it into EDSK.
Read the updated readme for more info.
Postby Sorgelig » Tue Jun 14, 2016 5:10 pm
There is slight improvement in OSD when new firmware will be released. Instead Mount/Load *.DSK options, it will display Load Drive 1/2.
SirDavid
Postby SirDavid » Tue Jun 14, 2016 8:37 pm
Meanwhile I have added back AY to the newest core, this time with changed address. And It works, all the demos I have converted once work! Who would have thought, I had no idea about programing FPGA until today :D
schombi
Postby schombi » Wed Jun 15, 2016 6:19 pm
You´re crazy, guys! Thanks for your work.
Is there a way to learn FPGA programming resp. a guide and a list of what tools are needed?
Postby Sorgelig » Wed Jun 15, 2016 8:21 pm
For Altera FPGA programming, the only tool you need is Quartus II: http://dl.altera.com/13.1/?edition=web
I didn't see comprehensive guide about FPGA programming. Google may help you :)
ericgus
Postby ericgus » Wed Jun 15, 2016 9:25 pm
Sorgelig wrote:For Altera FPGA programming, the only tool you need is Quartus II: http://dl.altera.com/13.1/?edition=web
Sorgelig, Under your "My cores for MiST" I dont see the most recent FPGA64 core you worked on .. i'd like to take a crack and playing with/compiling my own to learn fpga programming (since I know the c64 best of all).
Postby Sorgelig » Wed Jun 15, 2016 10:12 pm
ericgus wrote:Sorgelig, Under your "My cores for MiST" I dont see the most recent FPGA64 core you worked on .. i'd like to take a crack and playing with/compiling my own to learn fpga programming (since I know the c64 best of all).
Because of author of FPGA64. He prohibit release the code.
Btw, how it's related to SAM Coupe topic?
ericgus
Postby ericgus » Thu Jun 16, 2016 1:53 am
schombi asked about learning to program FPGAs .. You suggested Quartus II and I was looking at your "my cores" to download one to try it with.. thats how.
Postby Sorgelig » Sat Jun 18, 2016 4:47 pm
New release:
- Support multiple file extensions for disks. Now you can use native extensions for different formats.
- Support for IMG format used on ZX Spectrum (will be supported in next release of my ZX core).
- Improved write support. Now you can format the disk.
- Add SID support.
You must update to firmware 2016-06-19 (https://github.com/mist-devel/mist-bina ... r/firmware) or later for correct work of this release!
Please read updated Read Me for more details.
NML32
Postby NML32 » Sat Jun 18, 2016 6:13 pm
@Sorgelig thanks a lot for all the hard work you've put in to your cores.
schombi
Postby schombi » Sat Jun 18, 2016 6:15 pm
Added SID support?!? Fantastic!
Postby Sorgelig » Mon Jun 20, 2016 5:07 am
SirDavid
i will check the game you've reported.
Postby Sorgelig » Mon Jun 20, 2016 6:41 am
The problem with keyboard in game Colony is unclear for me. Game simply has no any reaction on keyboard. I see there is keyboard scan, but why there is no reaction - i have no idea.
Game written in some high level language or in some game constructor - so it's extremely hard to find the source of problem.
If there any other game with keyboard problem then let me know. More games with similar problem - higher change to fix.
Postby Sorgelig » Tue Jun 21, 2016 3:39 pm
OMG. This game compare keyboard port data against whole byte value instead of check separate bits.
And since tape input bit in my code is 0 instead of 1, none of keys matched in this game.
Postby Sorgelig » Tue Jun 21, 2016 3:51 pm
New release:
- Fix disk formatting.
- invert RXMIDI and Tape-IN bits to suit some picky games.
vebxenon
Postby vebxenon » Mon Jun 27, 2016 2:11 pm
Sorgelig wrote:New release:
Thanks as always :cheers:
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
SirDavid
Postby SirDavid » Sat Jul 02, 2016 7:09 pm
Sorgelig wrote:Unfortunately, i cannot increase CPU speed due to MiST using SDRAM. Unlike in other my cores where i could use FPGA RAM for video cache, SAM Coupe uses whole 512kb for video. So i had to use SDRAM for video. Since SDRAM require significantly longer time than SRAM to access the data, there is no time left for increasing CPU speed (unlike in ZX core where i could achieve 56MHz).
So, the only thing i could do is to disable CPU Throttle to allow CPU work at full speed (6MHz) whole time.
So how Amiga core can use higher CPU clocks and 2 MB of chip (video) RAM?
Sorgelig wrote:Anyway, original SAM Coupe didn't have 20MHz, so there should be no big loss.
Original SAM didn't have external RAM either. And higher CPU clocks are more useful then external RAM. There is an accelerator for SAM (called Mayhem Accelerator) and new demos can use it. It has two clocks: 10 and 20 MHz. Even 10 MHz in SAM core would be great...
Postby Sorgelig » Sat Jul 02, 2016 11:39 pm
Full code is available on github. You are free to add higher CPU clocks and share with us.
SirDavid
Postby SirDavid » Sun Jul 03, 2016 10:13 am
I can share Quazar Surround soundcard (playing stereo) if you want, or anybody else wants, there are lots of software to play with it. For now my skills are far from enough to mess with RAM, CPU clock etc. I have tried but with no success. And I have no idea why. But if it works with Amiga core, it is not impossible.
ericgus
Postby ericgus » Sun Jul 03, 2016 4:28 pm
SirDavid wrote: But if it works with Amiga core, it is not impossible.
I don't know the Coupe that well but believe it uses a z80 type cpu whereas the Amigas use a Motorola 68K family processor so you can't really make that sort of assumption.. apples to oranges comparison here.. those techniques and the logic core for the M68K cpu core wouldn't work here, you would need a fpga z80 core that is purposefully designed to run at a fast clock rate. I know it would be nice to think its just simply changing some number in a source code file to whatever new speed you like but it doesn't work that way.
vebxenon
Postby vebxenon » Mon Jul 04, 2016 6:32 am
Sam Coupé uses a Zilog Z80B at 6 MHz.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Postby Newsdee » Mon Jul 04, 2016 7:22 am
There's all kind of side effects that could happen if one cranks up CPU speed without adjusting the rest; especially for these earlier architectures that weren't designed for it (unlike a modern PC designed to accomodate a very wide range of processor speeds)
Postby Sorgelig » Mon Jul 04, 2016 1:48 pm
I've added turbo 12MHz and 24MHz, but these two demos (SlowMotion 1,2) originally should benefit from turbo, in reality have problems.
I don't know HW details of that Mayhem Accelerator. If it replaces system memory by static RAM, then CPU can have very high clock without contention. In MiST we have only SDRAM which is much slower than SRAM and should serve the video as well. Thus turbo modes (i.e. 12MHz and 24MHz) cannot avoid contention. Although these turbos are faster than original 6MHz mode, they are not at 100% of their speeds (90% of 12MHz, 60% of 24MHz). May be this contention(throttling) confuses these demos if there are some timing calculation used inside.
SirDavid
Postby SirDavid » Mon Jul 04, 2016 3:39 pm
Great anyway! Can you share it?
