NES core on MiST
Re: NES core on MiST
Postby Newsdee » Fri Oct 07, 2016 1:42 pm
I remembered Kevtris had some info on NES and found out a page on mappers that looks quite extensive. Does this help in any way?
http://kevtris.org/mappers/mappers.html
sebdel
Postby sebdel » Fri Oct 07, 2016 1:48 pm
NesDev wiki is better. It also cross-references kevtris site and the mapper.txt file you posted about earlier. I read them all and sometime they disagree with each other. That's where there is room for experimentation :)
edit: fun fact, Nintendo world championship actually works but you have to press Start on the controller 2 (which we support through the keyboard). I lost 2 hours on this.
Postby Newsdee » Fri Oct 07, 2016 10:47 pm
I was wondering... NWC booted and seemed ok. Maybe you need to add a special key to push all buttons at once :-D You could also try it on an emulator just to see what behavior you can expect (not that it's necessarily always accurate, but maybe it could have avoided spending time on it).
Anyway, great job on the improvements! It's great to see the game list growing!
vebxenon
Postby vebxenon » Sun Oct 09, 2016 1:37 am
Great job sebdel :-) Yes, it's a good idea to put Select and Start on keyboard and let visible the reset option.
Regards,
Salva
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Postby Newsdee » Sun Oct 09, 2016 11:55 am
I made a small change to palettes:
https://github.com/mist-devel/mist-bina ... f?raw=true
You can now switch between the FCEUX palette (default) and FirebrandX's Unsaturated-V6. The first is very common (used in the AVS) and warmer, better for cartoony games. The second is closer to the NTSC Composite standard (it reminds me a bit of the C64 colors). It's grittier and feels better for "serious" games, IMHO. More info here: http://www.firebrandx.com/nespalette.html
NML32
Postby NML32 » Sun Oct 09, 2016 3:25 pm
@Newsdee, thanks, I like the new look.
sebdel
Postby sebdel » Mon Oct 10, 2016 4:22 pm
For those who live on the bleeding edge, and provided you have Quartus, I pushed a first shot at Mapper16 (Bandai), enabling about half of these games: http://bootgod.dyndns.org:7777/search.php?ines=16. Japanese required.
I also added 512KB support for MMC1 (Dragon warrior 3 and 4).
Postby Newsdee » Tue Oct 11, 2016 12:03 am
I think I have a few of these with translation patches. I'll check.
The Bandai FC carts are pretty cool looking. I didn't pick them up because of the language, but I ought to try the games (I have a small FC collection).
vebxenon
Postby vebxenon » Tue Oct 11, 2016 6:36 am
Newsdee wrote:I made a small change to palettes:
Could be PAL modes be adapted for this core? (50 HZ, colours, etc...)
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Atmosfear
Postby Atmosfear » Tue Oct 11, 2016 9:40 am
Alot of PAL Games have graphical Glitches i.e. Asterix while the US Version runs fine. Thats why i change the Roms for the new RomVault Dat from EU to US/JAP. Some Pal Games run fine but the Music plays to Fast. Another Reason to use the US Roms. As far as i remember there is no Country Flag in the Header of the NES Roms.
sebdel
Postby sebdel » Tue Oct 11, 2016 11:33 am
Latest binary is available:
https://github.com/mist-devel/mist-binaries/blob/master/cores/nes/nes_161011.rbf.
Fixed:
Dragon Warrior III (U) [!]
Dragon Warrior IV (U) [!]
Added (Bandai mapper):
Dragon Ball 3 - Gokuu Den (Japan)
Dragon Ball - Daimaou Fukkatsu (Japan)
Dragon Ball Z Gaiden - Saiya Jin Zetsumetsu Keikaku (Japan)
Dragon Ball Z II - Gekishin Freeza!! (Japan)
Dragon Ball Z III - Ressen Jinzou Ningen (Japan)
Famicom Jump - Eiyuu Retsuden (Japan)
Meimon! Daisan Yakyuubu (Japan)
Nishimura Kyoutarou Mystery - Blue Train Satsujin Jiken (Japan)
Sakigake!! Otoko Juku - Shippuu Ichi Gou Sei (Japan)
Seb
sebdel
Postby sebdel » Tue Oct 11, 2016 12:15 pm
Newsdee wrote:That uses the MMC5 mapper which isn't fully supported.
In fact there is no hardware that will play it right now, because (like in The Legend of Link) they use bigger ROMs than what has ever been commercially available for the MMC5. Neither the Everdrive N8 or the Powerpak can run it.
In principle the MiST could make it work by allowing 1MB CHR and PRG roms, but that needs new development (its not a bug to be fixed).
The NES core actually allocates 2MB for PRG ROM and 1MB for CHR ROM. The problem with MMC5 > 1MB is that the prg bank selector is only 7 bit wide so by MMC5 spec, that should not be possible. If you find me where "they" put the extra bit, I'll give it a shot.
Postby Newsdee » Tue Oct 11, 2016 1:16 pm
Actually it has a custom mapper with extra features, based on MMC5. They cite the ROM size as the biggest limitation for Everdrives, but there's some other stuff that could make it too much work for now.
More info here:
http://www.romhacking.net/hacks/2136/
Postby Newsdee » Mon Nov 21, 2016 1:34 pm
Would it be difficult to support 4 players on the core?
I suppose it will need firmware changes too:
https://wiki.nesdev.com/w/index.php/Four_Score
vebxenon
Postby vebxenon » Mon Nov 21, 2016 9:07 pm
Any news on the core development? :)
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
sebdel
Postby sebdel » Tue Nov 22, 2016 7:51 am
Not really, but I still have a couple of months to work on the mist nearly full time, so in order to not get burnt out I switch tasks every now and then. Here's a list of things I work on:
- NES core: Persisted RAM. Status: I tried and it doesn't work. I'll try again eventually.
- YMSoC core: A core to experiment stuff. Contains a YM2149 and a YM2151 plugged to a Z80@4MHz with a hardware mouse cursor + a 320x240x2 bits video mode. I'll see if I can turn it into a nice soundchip tracker. I suspect an 8 bit system is not up to the task. We'll see. It's a work in progress, there's "something" in my github.
- Mattel Aquarius: Tape emulation. It's coming along. <== We are here
- TRS80: Tape emulation. Not started.
ericgus
Postby ericgus » Tue Nov 22, 2016 8:33 am
sebdel wrote:Not really, but I still have a couple of months to work on the mist nearly full time, so in order to not get burnt out I switch tasks every now and then. Here's a list of things I work on:
Thanks for your work on those things.. I would love to see some kind of tracker thingy that would be really neat..
Yea the TRS80 tape thing.. if you could pull that miracle off .. i'd be in heaven.. (or even if you did "program injection" ala c64 core .. but whatever works .. )
vebxenon
Postby vebxenon » Tue Nov 22, 2016 10:33 pm
Thanks for your work, Sebdel! :)
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
DrOG
Postby DrOG » Wed Nov 23, 2016 5:18 am
All of the above mentioned would be amazing!!
mahen
Postby mahen » Fri Jan 06, 2017 8:47 am
Hi everyone ! I have a little issue ! For the first time I'm trying the NES core with a 15 KHz screen. An old TV from my wife's teenager bedroom :)
I'm quite happy with the result !
However, NES games (both in PAL and NTSC mode) appear quite off-centered, and especially quite a few columns are missing on the left as you can see here : https://postimg.org/image/urw5d5h1b/ (yes pics are awful, I have an old phone :)
There is no such issue with the Amiga core (PAL 50 Hz here) :
- normal game : https://postimg.org/image/8m0i6r1gx/
- overscan game : https://postimg.org/image/vny1fj6o3/
Any idea ? Also, but this is O.T. so I can open a new thread, I did manage to disable the scandoubler for the menu, minimig, nes cores but no for the PCE and Atari ST ones... (this screen supports both 50 and 60 Hz modes as I could switch from the Amiga Early startup menu)
Edit : meanwhile I found the solution for the ST, I had to find a config file otherwise I couldn't get to the OSD to set the tos ; it then switched to the right mode.
sebdel
Postby sebdel » Sat Jan 07, 2017 4:37 pm
I think on these old monitor you have a setting to manually adjust the position and size of the image. I'm not surprised that it doesn't match the amiga core alignment by the way: all cores have slightly different clocks.
vebxenon
Postby vebxenon » Tue Jan 17, 2017 10:35 am
Yesterday I tested last Mojon Twins releases:
- Lala The Magical http://www.mojontwins.com/juegos_mojono ... gical-nes/
- MOJON TWINS GRAN SABIDURÍA – 31 in 1 REAL GAME! (A parody of most chinese multicarts) http://www.mojontwins.com/juegos_mojono ... -game-nes/
Both of them run perfectly on last NES core :D
Regards,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
mahen
Postby mahen » Fri Jan 27, 2017 10:02 am
Hi all ! Are you sure alignment is supposed to differ so much in 15 KHz with the NES core ? Those machines were supposed to be used with the same kind of TVs, and the other cores are perfectly centered. Here I'm missing a part of the picture on the left (I don't mind if it's not perfectly centered but it's a bit annoying to lose a part of the picture).
Also, I didn't remember it used to look blocky on a TV screen but it's true it was a while ago :-)
I'm using a 20 y.o. TV which has no horiz-vert alignment setting.
Cheers ! :-)
Postby Newsdee » Sat Jan 28, 2017 12:55 am
Try switching off the "hide overscan" feature. It's a simple overlay that hides part of the image, but doesn't recenter.
Some games do use the overscan well, for others its a mess so it's nice to hide it.
mahen
Postby mahen » Sat Jan 28, 2017 8:06 am
Yep, already tried, but even though, it's still missing a part of the picture on the left :)
Users browsing this forum: breiztiger and 6 guests
