Falcon 15KHz (TV, RGB) capable flatscreen monitors
calimero
Re: Falcon 15KHz (TV, RGB) capable flatscreen monitors
Postby calimero » Tue Jan 26, 2016 12:46 pm
Faucon2001 wrote:Do you think this could be improved using the GBS 8220? I have not seen any usage with the Falcon.
I had GBS 8220: https://www.youtube.com/watch?v=pKfnsqwW9WY
and I asked on forum what can be done with this jerkying and Simbo gave me instructions: viewtopic.php?t=17153&start=125#p221079
Faucon2001 wrote:For the following NVRAM parameter :TV, NTSC, 80 col, 16 colors
Newdesk.inf set to overscan, 768x480 desk resolution
The monitor is set on : 640x240 H 15,6 Khz V 59,4 hz
The image is more stable, but hardly readable as pixels are missing.
yes, small font (8px) and small letters are completely unreadable coz pixel missing horizontal.
Faucon2001 wrote:What soft do you use to set your NVRAM? I never saw it. Where could I find it?
Hare http://milan.kovac.cc/atari/software/in ... er=/SYSTEM
Faucon2001
Postby Faucon2001 » Wed Jan 27, 2016 12:34 am
calimero wrote: Simbo gave me instructions: viewtopic.php?t=17153&start=125#p221079
:lol:
Thanks to both, I'll give a try
Philippe
belzrebuth
Postby belzrebuth » Fri Jan 29, 2016 4:24 pm
I got the same monitor (1970nxp) and I get the same vertical lines missing problem with my amiga 1200.
Any updates on this?!
It's really annoying because it's *almost* there so it should just be a matter of settings to make it work..
The problem seems to lie in the overscan settings.
calimero
Postby calimero » Fri Jan 29, 2016 4:33 pm
belzrebuth wrote:I got the same monitor (1970nxp) and I get the same vertical lines missing problem with my amiga 1200.
you talk about interlace mode?
This monitor does not support proper interlace mode - it simple, on same vertical line (same pixels), draw one frame odd and another even line from interlaced picture. It is how monitor works, you can not change this.
belzrebuth
Postby belzrebuth » Fri Jan 29, 2016 4:51 pm
Interlaced modes don't work properly.
I'm talking about hi res non interlaced at 640x240 or 256 or 512.
The bottom of the screen does not show whole at overscan.
The lower rectangles are cut at about 3/4.
I'll post some photos later when I get home.
It similar to the problem you post at the first page with your a500.
calimero
Postby calimero » Fri Jan 29, 2016 5:56 pm
ah, yes... "The bottom of the screen does not show whole at overscan." this is another problem (separate from bad interlacing...)
I am not sure how this could be solved. Internal logic of monitor decide what resolution to use depending of input signal - if Amiga could produce slice different signal maybe Nec would use some other resolution and display image properly? (my Amiga currently does not have permanent setup on my table so I can not experimenting :()
btw did you try both, PAL and NTSC signals (resolutions)?
belzrebuth
Postby belzrebuth » Fri Jan 29, 2016 8:12 pm
My 1200 is European so I thought that it only supports PAL but I'll check again and post back.
Here is a not so good photo of what I get:
https://www.dropbox.com/home/Camera%20U ... .48.57.jpg
Workbench stuff works fine but applications are cut off when in full screen.
belzrebuth
Postby belzrebuth » Fri Jan 29, 2016 8:16 pm
Ηmm,I'm not sure where I can change PAL to NTSC..
But I don't think there will be a difference.
Maybe using some kind of workbench replacement could solve the issue?
It's a shame because I just bought this monitor for my 1200 specifically only to find out that it isn't really flawless as I thought it could be..
Estrayk
Postby Estrayk » Wed Mar 22, 2017 7:14 pm
Hello, Anyone have test BENQ BL912 or BENQ BL702A Monitors in Falcon 15Khz PAL modes? The Amiga community uses them in Amiga native PAL and seems them works perfectly.
calimero
Postby calimero » Wed Mar 22, 2017 7:31 pm
Estrayk wrote:Hello, Anyone have test BENQ BL912 or BENQ BL702A Monitors in Falcon 15Khz PAL modes? The Amiga community uses them in Amiga native PAL and seems them works perfectly.
http://www.atari-wiki.com/index.php/Main_Page is currently down :( but there are infos about monitors...
Maeke
Postby Maeke » Wed Mar 22, 2017 8:06 pm
It's not down,it's a bug, and all the pages are affected, the datas are still here, just look the source, but the bug prevent them to be displayed.
proof with the monitors page: http://www.atari-wiki.com/index.php/Flat_Panel_Displays
leech
Postby leech » Tue May 09, 2017 7:45 am
I have a BL912, and it works great on my TT030 and 1040STe. Haven't tried the Falcon on it, I will mod the vga cable I have and see how well it works.
