Internal Falcon Ethernet controller
Re: Internal Falcon Ethernet controller
Postby wongck » Thu Nov 19, 2015 2:22 am
Rajah Lone wrote:- Litchi tries to download/upload the file entirely in RAM to avoid writing on the disk during the transfer. It warns you in the console window if it can't allocate the required memory and will have to do it by parts.
[smilie=greencolorz4_pdt_01.gif] This is a good way of optimising by buffering to the max and reducing slow disk writes.
mghodge
Postby mghodge » Sat Nov 28, 2015 3:02 pm
An unhappy update on this project:
While probing around to work out interrupts the scope lead connected to EXPAND on the expansion header grazed the fuse clip on the PSU sending 120v into the Falcon. This incredibly stupid cockup on my part instantly fried the U63 GAL and the 1k pullup resistor on that line (at least). I've replaced both these components but the Falcon will no longer boot. If I can repair the Falcon I'll continue. If not, I'll have to put aside this project and post the design files for someone else to continue. I can't afford to buy another Falcon.
mghodge
Postby mghodge » Sat Nov 28, 2015 3:07 pm
Needless to say, there is no longer line voltage anywhere near my workbench ATM. Also, a moderator may want to move this thread from the "Professionals" forum to the "Blithering idiots" forum...
dml
Postby dml » Sat Nov 28, 2015 6:03 pm
Ouch! I suppose it's time to sit with the schematic and follow everything back from that pin :-(
You'll probably find it easier if you have a 2nd Falcon nearby (loan?) to compare signals with and maybe do some swaps for tests...
mghodge
Postby mghodge » Thu Dec 10, 2015 9:16 pm
Fortunately "EXPAND" only goes to U63 (GAL) and the 1K pullup on the mobo, and the CPLD on my board. I replaced the 1K and CPLD and ordered a new GAL from Best Electronics. The GAL, being NOS, was completely blank when it arrived and did not work. So I had to buy a GAL programmer and reprogram it from a .JDC file I found on the net.
Everything is fixed and working as it did before. I am very happy.
dbsys
Postby dbsys » Fri Dec 11, 2015 5:47 pm
mghodge wrote:Fortunately "EXPAND" only goes to U63 (GAL) and the 1K pullup on the mobo, and the CPLD on my board. I replaced the 1K and CPLD and ordered a new GAL from Best Electronics. The GAL, being NOS, was completely blank when it arrived and did not work. So I had to buy a GAL programmer and reprogram it from a .JDC file I found on the net.
That´s great news. I am glad you were able to fix your Falcon. It would have been a huge loss, considering Falcon´s prices out there.
Atari030
Postby Atari030 » Fri Dec 11, 2015 10:18 pm
Phew, another one saved. Good work.
Postby wongck » Sat Dec 12, 2015 10:40 am
Great to see another bird flying again :cheers:
tuxie
Postby tuxie » Sun Mar 27, 2016 8:34 pm
Any news ?
Postby Dal » Sun Mar 27, 2016 8:44 pm
mghodge wrote:Also, a moderator may want to move this thread from the "Professionals" forum to the "Blithering idiots" forum...
*Snigger*
Rustynutt
Postby Rustynutt » Sun Mar 27, 2016 8:48 pm
Wow, Brilliant, as they say across the pond :)
See the oscillator, is there any other timing taken from the expansion bus, or all independent?
That's about the cleanest board ever.
mghodge
Postby mghodge » Mon Mar 28, 2016 8:54 pm
The RTL uses a 20MHz crystal, but all communication with the Falcon is asynchronous through the Altera CPLD.
I have a second revision of the board built and tested. I was going to see about adding support for the "Boot ROM" function of the chip, but I can't think of a useful application for cumbersome, 8-bit, paged Flash chip access.
mghodge
Postby mghodge » Tue Apr 26, 2016 5:21 am
Quick update:
It looks like there will need to be one more revision on the PCB. The mag pack needs to be moved to the bottom of the board in order to clear the Falcon's RF shielding.
dbsys
Postby dbsys » Tue Apr 26, 2016 7:01 am
mghodge wrote:Quick update:
Thanks for your continuous work on this very sophisticated project!
I am looking forward to owning at least one of these devices when the time is right!
mghodge
Postby mghodge » Sat Jun 11, 2016 8:03 pm
I have two of these ready to sell. Anyone still interested?
Price is $200 ea.
mghodge
Postby mghodge » Wed Jun 15, 2016 2:19 pm
These are now going to eBay for buyer protection: http://www.ebay.com/itm/331882395421
catmando
Postby catmando » Wed Jun 15, 2016 3:24 pm
You've made a really nice job of these but I think unfortunately the production cost is not competitive enough with existing solutions out there. Good luck with your sale though and I hope you get what you want for them.
Atari STFM
mghodge
Postby mghodge » Wed Jun 15, 2016 4:06 pm
Here are the design files. The STING driver and source, DipTrace PCB design files and schematic, and Quartus 13 project folder for the CPLD.
Greenious
Postby Greenious » Wed Jun 15, 2016 5:14 pm
Most impressive, and great job!
An idea would be to have the ethernet-connector internally, and use a flat TP-cable to extend it out where one wants it with a female-female TP adapter, then you would not need to remove Joy-B port for it.
viewtopic.php?t=5040
mghodge
Postby mghodge » Tue Jun 21, 2016 10:42 pm
Let's try this. One is now up for auction. Interested to see just what the level of interest is.
http://www.ebay.com/itm/331887908127
Greenious
Postby Greenious » Wed Jun 22, 2016 10:14 pm
As much as I would like to bid on this, ebay is not an attractive trading platform anymore for many europeans.
The global shipping program has more or less killed it, since anything more than like $30 dollars or so get's taxed and fee'd the hell out of the buyer.
Current bid is $51, with all the fees, taxes and shipping it's already $100 for me.
rpineau
Postby rpineau » Wed Jun 22, 2016 10:34 pm
Well.. it's my bid ($51) and I'm in the US,. :)
But I agree that for European buyer it's a pain.
mghodge
Postby mghodge » Thu Jun 23, 2016 4:44 pm
I would support someone in EU manufacturing them for sale in EU. You can buy blank PCBs from OSH Park (https://oshpark.com/shared_projects/lxwCvpHJ) or use the attached Gerbers. You would then buy ISA Ethernet cards off eBay and transfer the parts. Adding the programmed CPLD is the only custom part.
Postby mikro » Sat Nov 19, 2016 4:23 pm
Happy to announce that I've built in and tested the card by myself, too. Neat piece of hardware. Will try to improve a few things, make a FreeMiNT driver and support for Sqwards uIP tool.
calimero
Postby calimero » Sat Nov 19, 2016 10:42 pm
Is it possible to bring price down?
