MI-3: Image format converter and slideshow
Re: MI-3: Image format converter and slideshow
Postby rockyone » Mon Sep 09, 2019 3:52 pm
Thank you for your answers.
Not knowing anything about programming the system, it seems very complicated.
But I will still try. :mrgreen:
Postby rockyone » Wed Sep 11, 2019 11:32 am
New version after realizing that I created a bug with the functions of the "R" and "G" keys (One more! :mrgreen: )
Now the menu works well with SPU images.
I still have not done anything to manage the mouse with these images but the keyboard works well.
Postby rockyone » Wed Sep 11, 2019 8:17 pm
Sorry for those who downloaded, before realizing that I had not compiled the right version. :? :?
It's good now.
Postby rockyone » Thu Sep 12, 2019 1:32 pm
Adding a PDF file in French at the top of the topic. http://www.atari-forum.com/viewtopic.php?f=72&t=28191
Postby rockyone » Tue Sep 24, 2019 3:09 pm
Update
I added a test for image files in some routines, because I find too often images that crash the program.
Before, opening a file that returned an error closed the file selector.
This is now modified.
New function with a [Shift] key for access paths: "open" and "save"
example for "Open:"
[O] + [Shift] or right click on the "Open" button
The first use forces the path to the one used by the "Save" function.
2 ° use Restore the initial path.
Correction du PDF :mrgreen:
Postby rockyone » Fri Oct 04, 2019 12:36 pm
Small change to load IFF images created with ZZ-LAZY PAINT.PRG
After converting the color palette to 16 levels of gray with the G key, you can restore the color palette with the same key. Except for the spectrum images.
Update of the PDf in French.
Do I have to translate it into English?
Postby rockyone » Tue Mar 17, 2020 5:09 pm
rockyone wrote:04_10-2019
MI-3.PRG : http://www.mirari.fr/GuGa
Floppy disk 1440 Ko : http://www.mirari.fr/Uar6
Floppy disk 720 Ko : http://www.mirari.fr/iaAj
All files : http://www.mirari.fr/uAWC
DPF File in french : http://www.mirari.fr/5cGa
Tested on Steem v3.02 and Hatati 2.00 with the TOS FR 1.02, 1.04, 1.06,1.62, 2.05 and 512 Kb of RAM
Tested on Hatati 2.1.0 in STE mode with the TOS 1.62 FR, in mode MEGA STE with TOS 2.05 FR and 512 Kb of RAM
Image,Image,Image,Image
Image,Image,Image
Art-Director color cycles are not converted to other formats.
Converting a maximum cycle of eight Neo or Degas colors to Art Director is supported.
MI-3 can load the files ".PL1" and .PL2 -on the original plane- and save them again.
You can also open or save a file by clicking on the left side of the screen
Do not confuse the extensions
ART of: Artistic Director, GFA-Artist, The ArtiST
PG1-3 of: Graphics Processor with PG0-2 from Paintwork, Anivision and Apaint that are not loaded.
Postby rockyone » Wed Mar 18, 2020 2:33 am
MI-3 / Hataroid TOS 1.62, 1 mb of memory
Return to “Other BASIC”
