MiST - new joystick/gamepad mapping
Televicious
Re: MiST - new joystick/gamepad mapping
Postby Televicious » Fri Feb 01, 2019 8:23 pm
firmware_190110
- Don't hardcode settings for Vid:0079, Pid:0011 controllers
Oh snap, thank you. Cannot wait to test this out. At least one pair of controllers I have should be fully functioning.
It works! Very well, all buttons can map now. You're my hero.
goran
Postby goran » Fri Feb 08, 2019 5:55 pm
I still can't map all buttons on my controller and I don't know what's the problem. Latest fw.
My mist.ini:
[mist]
scandoubler_disable=0
joystick_remap=0810,E501,1,2,4,8,100,10,20,200,400,800,0,0,40,80
joystick_remap=0810,0001,1,2,4,8,200,20,10,100,40,80,400,800,40,80,40,80
sel (40) mapped on button 5 works:
It also works on button 9:
start (80) works on button 6:
but not on button 10:
Also, last two buttons (hats) are also defined as select and start, but also shows as empty on test.
What am I missing here?
Best regards,
Goran
DanyPPC
Postby DanyPPC » Sat Feb 09, 2019 8:51 am
Check in Windows the real sequence of buttons as some may have been mapped as button 13, 14, etc...
goran
Postby goran » Sat Feb 09, 2019 1:46 pm
I checked with mapper.exe. Same thing. Mist detects the buttons but nothing is assigned to them despite the entry in mist.ini.
Lroby74
Postby Lroby74 » Sat Feb 09, 2019 3:12 pm
goran wrote:I bought Playstation to USB adapter and it's working on MiST. I just have a problem with buttons mapping.
I have the following line in mist.ini:
ME :
Please don't count numbers 1,2,4,8 like buttons, they are 4 directions movement, insted start to count from first number beyond, in your mapping above fire buttons numbers are only 10 and starts from 200, then try do don't put 2 times 40 & 80, in buttons that you don't need to use, put 0, for example :
joystick_remap=0810,0001,1,2,4,8,200,20,10,100,0,0,400,800,40,80
i am using a Psx to USB converter too and mapped only time then any PSX joystick i wish to use, it will use always correct mapping
goran
Postby goran » Sat Feb 09, 2019 4:08 pm
ME :
Well, this is my actual mapping:
joystick_remap=0810,0001,1,2,4,8,200,20,10,100,1000,2000,400,800,40,80
so there is no double mapping and button functions are defined (no matter if You call it button 9 or something else).I just did that for testing that select and start are working at all. And, as far as I know, nothing's wrong with putting the same function on multiple buttons, so that shouldn't be the issue. Still last two buttons, mapped as select and start, are detected but have no function assigned despite correct(?) mist.ini.
Best regards,
Goran
retrofun
Postby retrofun » Sat Feb 09, 2019 4:41 pm
goran wrote:but not on button 10:
Maybe you have to map the bit location of (the "dead") buttons in the USB HID message to the MiST internal software joypad with hid_button_remap option as described by Newsdee: viewtopic.php?f=115&t=28174&start=75#p359712
I've done that successfully with iNNEXT NES gamepad clones Y-D002-024 that didn't work with MiST firmware < 190110 (e.g. "dead" Y button): viewtopic.php?f=115&t=28174&start=75#p363850
On Linux hid-replay (https://github.com/bentiss/hid-replay) is helpful.
goran
Postby goran » Sun Feb 10, 2019 12:27 pm
Thanks. I installed linux, installed hid-replay.
Pressed SELECT on controller and one different entry in log was:
E: 1.647910 8 01 7f 7f 7f 7f 0f 10 00
For START it's:
E: 1.247623 8 01 7f 7f 7f 7f 0f 20 00
no buttons pressed is
E: 0.287869 8 02 7f 7f 7f 7f 0f 00 00
I don't understand how to use this info to map SELECT to button 9 and START to button 10 in mist.ini. :shrug:
Best regards,
Goran
retrofun
Postby retrofun » Sun Feb 10, 2019 2:59 pm
Hmm, when you press SELECT or START two bits change. In byte 0 and byte 6.
Anyway, you can try
hid_button_remap=0810,0001,51,9
hid_button_remap=0810,0001,50,10
This should map SELECT to btn 9 (default: L2) and START to btn 10 (default: R2) -> https://github.com/mist-devel/mist-boar ... lt-mapping which can then be remapped with joystick_remap (that's what you're trying to do!).
Hope this helps to understand the mapping of hid_button_remap:
Byte:   0        1        2        3        4        5        6        7
        00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Bit:    0        8        16       24       32       40       48       56
For SELECT and START with your USB adapter this is:
SELECT:
hex:    01       7f       7f       7f       7f       0f       10       00
bin:    00000001 01111111 01111111 01111111 01111111 00001111 00010000 00000000
        ^- bit 51
START:
hex:    01       7f       7f       7f       7f       0f       20       00
bin:    00000001 01111111 01111111 01111111 01111111 00001111 00100000 00000000
        ^- bit 50
goran
Postby goran » Sun Feb 10, 2019 5:03 pm
Thank You for instructions.
However, after inserting
into mist.ini, button 9 is still empty and button 10 is no longer detected.
Best regards,
Goran
retrofun
Postby retrofun » Mon Feb 11, 2019 8:25 pm
goran wrote:Thank You for instructions.
Best regards,
Goran
Aargh, button count starts at zero. Sorry. Try:
hid_button_remap=0810,0001,51,8
hid_button_remap=0810,0001,50,9
goran
Postby goran » Tue Feb 12, 2019 10:05 am
Done. Now neither START or SELECT button press is detected. :shrug:
Best regards,
Goran
Albator
Postby Albator » Sun Feb 17, 2019 8:40 pm
desUBIKado wrote:This is my setting for Hyperkin GN6 USB:
joystick_remap=0079,0011,1,2,4,8,10,20,800,100,200,400,0,0,40,80
Hello, I have the same hyperkin pad.
For mine, the correct mapping is:
Using your mapping, the "Mode" trigger and "C" button are swapped, this is annoying when playing Street Fighter 2 :D
desUBIKado
Postby desUBIKado » Mon Feb 18, 2019 9:47 pm
You're right. I've changed my configuration. Thanks a lot.
farvardin
Postby farvardin » Thu Feb 21, 2019 2:15 pm
I'm also stuck with the configuration...
I own a generic cheap SNES USB gamepad (from ebay or aliexpress), they work well, but I can't configure correctly the two extra buttons for playing with the Genesis core.
In my mist.in I have:
joystick_remap=0810,E501,1,2,4,8,20,10,20,10,400,800,40,80,40,80
It works OK, except the X (0x100) and Y (0x200) buttons are mapped to A (0x10) and B (0x20) (A and B buttons are working well too).
Select (0x40) and Start (0x80) are working fine too.
If I change only the 7the and the 10th values, assigning the X and Y buttons, then I get the X and Y buttons to work
joystick_remap=0810,E501,1,2,4,8,100,10,20,200,400,800,40,80,40,80
The problem is now my Start button is correctly detected when I press it (same place as before), but is no longer assigned to start.
I've tried to compile HID replay on Linux, but I get an error.
muppets4
Postby muppets4 » Sun May 05, 2019 8:03 pm
fury23 wrote:I created small utility for Windows which helps me to map joystick buttons.
Repository: https://github.com/loborec/mist_usb_joystick_mapper
Direct link to file: https://github.com/loborec/mist_usb_joystick_mapper/raw/master/mapper.exe
Great tool! Thanks for sharing!
gibs
Postby gibs » Wed May 29, 2019 7:46 pm
Hi guys,
Is it possible to map '1','2' on the joystick (To start with 1 or 2 players) ?
I tried to
joy_key_map=400,1E
joy_key_map=400,1F
To send 1/2 with my L/B button with no luck.
Televicious
Postby Televicious » Tue Jun 11, 2019 10:16 pm
Tried the new CD32 controller version of minimig 1.2.3. Button mapping is way off. R button maps to nothing, L maps to pause/menu. I and II are switched. X and Y are rewind/FF. Start and Select are III and IV.
Is this meant for DB9 only or does it need a firmware update?
slingshot
Postby slingshot » Wed Jun 12, 2019 7:22 am
Televicious wrote:Tried the new CD32 controller version of minimig 1.2.3. Button mapping is way off. R button maps to nothing, L maps to pause/menu. I and II are switched. X and Y are rewind/FF. Start and Select are III and IV.
Is your mapping works with Genesis 6-button support? I'm using the same joystick_remap line, and works both in Minimig and Genesis.
I've used this test when added the CD32 pad support: http://aminet.net/package/driver/input/joytest_CP.lha
slingshot
Postby slingshot » Wed Jun 12, 2019 7:29 am
gibs wrote:Hi guys,
I tried to
joy_key_map=400,1E
joy_key_map=400,1F
Some arcade cores are using F1 and F2. Also key 1's scan code is 16, key 2 is 1E
Televicious
Postby Televicious » Thu Jun 13, 2019 5:12 am
Yea, works with Genesis with a bit of a remap for that core specifically, but it's a bit different. I used the Workbench 3.10 Joytest program to confirm what was actually going on. Guess I can try the genesis map on minimig too, but it seems far different from that even.
slingshot
Postby slingshot » Thu Jun 13, 2019 8:01 am
CD32 pad buttons and MiST fire buttons internal numbering are mapped 1:1. But as CD32 buttons are not numbered, it's possible that your idea about button numbers and the CD32's are different.
vebxenon
Postby vebxenon » Sun Sep 15, 2019 12:41 pm
Just a question: my Mega Drive pad has this configuration:
joystick_remap=0810,E501,1,2,4,8,200,20,10,100,400,40,0,0,0,80
but my SNES USB pad...
joystick_remap=0810,E501,1,2,4,8,100,10,20,200,400,0,800,0,40,80
As you can see, VID and PID numbers are the same, so SNES pad overrides the global configuration I use by default.
How can it put SNES configuration, just putting [SNES] before the configuration line?
Regards,
Salva
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
hyperterminal
Postby hyperterminal » Sun Sep 15, 2019 1:46 pm
vebxenon wrote:As you can see, VID and PID numbers are the same, so SNES pad overrides the global configuration I use by default.
Yes, just add [SNES] in square brackets (mist.ini is case insensitive).
Here is an example for the iBuffalo SNES gamepad:
hyperterminal wrote:
[snes]
joystick_remap=0583,2060,1,2,4,8,10,20,100,200,400,800,40,80
lips2k15
Postby lips2k15 » Wed Sep 18, 2019 7:50 am
Hi guys I am using an 8bitdo SN30pro controller but am having trouble getting the buttons to map correctly - does anybody here have the mapping line for it so I can paste it into my ini file? thank you.
